Garmin Zumo XT
Discussion in 'Mapping & Navigation' started by VCheng, Feb 25, 2020.
  1. BronNowo
    BronNowo Been here awhile
    Jan 2, 2018
    561
    Kraków
    damn, I was about to order one when I saw how it mounts, WTF ?
    it will fall off the bike when bumpy off-road....is it really marketed as all-terrain device??? deal breaker for me.
  2. Barak
    Barak adventure photographer
    Apr 28, 2006
    255
    Albuquerque, NM
    The mount is solid. Have had it for 2 1/2 months and put around 2,000 miles with it, on mostly off road bumpy trails with no issues.
    But the electrical contact on the mount side is a weak point - not reliable.
    Schussboelie likes this.
  3. shearboy2004
    shearboy2004 KIWIINUSA Supporter
    Jun 28, 2007
    4,922
    Ft Collins ,Colorado
    I'm pretty sure I'm an idiot and each day seems to confirm this more and more but how do you get rid of the wee lock in Garmin Explore for the XT ?
  4. yoohah
    yoohah Been here awhile
    Jun 5, 2012
    281
    Is the Zumo XT integrated with the BMW? The same functionality than Nav V?
  5. simon crewe
    simon crewe Been here awhile
    Sep 27, 2007
    193
    Haslemere, UK
    No, none of the Garmin units integrate with BMW software, only BMW branded units.
  6. BronNowo
    Jan 2, 2018
    561
    Kraków
    ok, so it won't come off? good to know but looks flimsy.
  7. simon crewe
    Sep 27, 2007
    193
    Haslemere, UK
    I have seen this problem reported on other forums, you need to contact your supplier for a warranty replacement.
  8. simon crewe
    Sep 27, 2007
    193
    Haslemere, UK
    I know what you mean about the mount, the 595 & Montana mount do look a lot sturdier. I suppose they have to save money somewhere!
    I have put a small stick on tether on the back of mine just in case. I would not normally bother, but when Touratech come out with a mount, I will be purchasing.
    I will be sticking with my Montana for off road use, as I feel it is a lot more robust in that type of environment. The XT has a speaker on the rear which I don't think will stand up well to mud & dust in the long term.
    BronNowo and Schussboelie like this.
  9. Schussboelie
    Schussboelie Kicking up dirt Supporter
    Jul 22, 2013
    1,039
    Belgium
    I guess we shouldn't judge a book by it's cover.
    I toppled over with my bike into a ditch last Saturday.
    The bike turned 360° laterally and the XT didn't move at all.
    The mount is more than sturdy enough.
    Maybe it doesn't have anything to do with "saving money" but more with new insights and developments.
    AugustFalcon, dunc and ADVer like this.
  10. third eye
    third eye back road loon Supporter
    Sep 2, 2010
    401
    Concord, CA
    new to this thread, will this fit on the bmw gs cradle?
  11. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    3,054
    Atlanta, GA
    Tiger is not FCC compliant?
  12. Barak
    Apr 28, 2006
    255
    Albuquerque, NM
    Done, and done. A new cable will be sent when they become available July 9th.
    Barak
  13. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,004
    Georgia, Vermont (that's one town, not two states)
    It does not come with the cable. But my original cable also had the pins loose (one actually fell out), and I got a warranty replacement by calling Garmin support.
    That's interesting. I wonder if that delay means they're redesigning the cable as well.
    --mark
  14. simon crewe
    Sep 27, 2007
    193
    Haslemere, UK
    If you mean a cradle for a BMW navigation unit - No.
    The only mount that fits the unit is the Garmin XT mount (at the moment).
  15. third eye
    Sep 2, 2010
    401
    Concord, CA
    thanks, next bad question:
    Can I adapt the Garmin mount to the GS bracketry?
  16. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,004
    The Garmin mount is a RAM mount, so I guess it depends on what the GS bracketry is. If it's RAM-compatible, then yes. If not, just ditch it and use the supplied mount.
    --mark
  17. third eye
    Sep 2, 2010
    401
    Concord, CA
    thanks, I'm a navigation mounting noob. just thinking of what to do with this fancy gs oem mount. I'm ordering one then
  18. simon crewe
    Sep 27, 2007
    193
    Haslemere, UK
    It will probably fetch good money on ebay, if it is the version with buttons as I believe it may fit the Garmin 660 (or 590/595) - someone on here will probably confirm.
  19. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    8,163
    48°58′18.9″N, 89°57′39.1″E
    The BMW Navigation Prep' Mount will hold a zumo 660/5 device but definitely not a zumo 590 series. If it has buttons (doubtful) they will not work with a zumo 660/5 - only BMW Navigators have the code for that.
  20. simon crewe
    Sep 27, 2007
    193
    Haslemere, UK
    Thanks for clarifying that.
