    Dismiss Notice
Garmin Zumo XT
Discussion in 'Mapping & Navigation' started by VCheng, Feb 25, 2020.
  1. amyroukai
    amyroukai Adventurer
    May 8, 2015
    45
    GR
    Seems the server error is no more, just updated the firmware.
  2. mrmagloo
    mrmagloo Been here awhile
    Jun 24, 2020
    107
    NW Chicago Burbs
    Yeah I noticed this yesterday, but seeing a number of the support pages were still down, I held off thinking the download/upgrade might be tainted. Imho, I'm waiting until we get the all clear from Garmin, just to be safe.
  3. Triplog
    Triplog Adventurer
    Aug 20, 2017
    47
    Co. Antrim
    The above was posted a few months ago - but I've just found it as I've taken delivery of my XT and find the track lines are too thin. I've successfully edited the track width but what I can't find is how to switch between the two files. Can anyone help please?
    thanks
  4. boulet_boulet
    boulet_boulet Long timer
    May 14, 2018
    1,460
    Maine
    Make sure that the file you edits doesn't have a hidden *.txt file extension and that it ends in *.kmtf. Double check that you gave it a new name like ThemName_Thick.kmtf. Triple check that it is placed in the correct location on your Garmin.
    Also, using this tool makes editing themes much easier IMO: https://www.javawa.nl/zumocolors.html.
    Triplog likes this.
  5. mrmagloo
    Jun 24, 2020
    107
    NW Chicago Burbs
    Fwiw, I have three versions of the file. The original, one edited for 2.0 width, and one edited for 3.0 width, all existing simultaneously. I can easily on the road, drill down and select which to display at any given time. Pretty easy, and frankly how the XT should have came from the factory. That 1.0 is pretty ridiculous.
    JS_racer and Triplog like this.
  6. Triplog
    Triplog Adventurer
    Aug 20, 2017
    47
    Co. Antrim
    I've just found it - under Map Themes on the XT
    DOH!
    Thank you for the help.
  7. boulet_boulet
    May 14, 2018
    1,460
    Maine
    Speaking of themes, I would like to find a theme that emulates the Montana's display. I checked with a buddy to see if his Montana had any *.kmtf files, but no dice. If anyone has any tips, they would be most appreciated.
    Thanks.
    Triplog likes this.
  8. Triplog
    Triplog Adventurer
    Aug 20, 2017
    47
    Co. Antrim
    Great idea on the Montana display - I miss the Shortcuts. Or any hacks which make the banners semi transparent (like the +/- banner). I remember reading about this on an earlier Nuvi but have never seen it for the Zumo's
  9. JS_racer
    JS_racer Adventurer
    Oct 15, 2010
    62
    Twin Cities MN
    Nice... What is your thoughts on the width?
    Still stock, but if i use the aqua color, under the purple guide one, it is easier to see for me... Thinking a bit wider would be better..
    I was able to sync my explorer, and tracks came back... So thats good.. Glad it wasn't me on my end.
  10. SAM13
    SAM13 Been here awhile Supporter
    May 1, 2017
    412
    MOronic Activity Base
    Sorry if this has been covered, I searched and found nothing......
    Charged my XT the other day, plopped it into the charging mount on my bike, it was turned off, went to go for a ride today, three days later, and the unit was dead, didn’t even charge from the cradle during my ride. Anyone have the power cradle discharge their unit? I have a Gas and leave my Nav 6 in the cradle and it too goes dead in a couple days.
  11. boulet_boulet
    May 14, 2018
    1,460
    Maine
    My XT stays in the mount and doesn’t go dead for a week or so at a time while it is in standby. The power to it is independently switched and I leave the power supply off.
    You might try turning it fully off instead of on standby.
    SAM13 likes this.
  12. SAM13
    May 1, 2017
    412
    Thanks, I didn’t even know it had standby, thought it was off , I’ll give it another try. Guess I could read the online manual instead of just doing the “man thing” and playing with it.:doh
  13. wheel2wheel
    wheel2wheel Adventurer Supporter
    Mar 22, 2008
    84
    SoCal
    Interesting, I am going to keep my eye on the charge status of my unit.
    Like you, my XT is kept in the mount. So far I have not noticed any significant discharge. I am assuming (maybe incorrectly) that the unit turns fully off by default. The reason I say this, is because the User Agreement usually, but not always, comes up whenever I turn the ignition key on to start the bike.
  14. mrmagloo
    Jun 24, 2020
    107
    NW Chicago Burbs
    I typically leave my history off so I don't really see them. But I do leave mine set at 2.0. nice middle ground when I turn it on, imho.
  15. JS_racer
    JS_racer Adventurer
    Oct 15, 2010
    62
    Twin Cities MN
    got ya, thanks....
    i almost always have a track of a trip planner route i want to follow. so i have that track display, then let the trip planner route direct me... adds a layer of double checking my desired roads to travel...
    i'll set up one for 2.0 and keep the original as well.... thank you again
  16. mrmagloo
    Jun 24, 2020
    107
    NW Chicago Burbs
    Fwiw, go ahead and do the two additional versions so you can switch back and forth. It only takes 2 extra minutes.
    When I look in my folder, I see:
    Garmin
    Garmin 2.0
    Garmin 3.0
    Pick one, try it and depending on the map layer, you can quickly change as needed.
    The reason why I leave it off is, I'm a street guy, and all my Trips/Routes start from home. So over time, virtually all streets in a few miles radius are highlighted so at that point, it doesn't offer much help and it just clutters things.
    Now if I was interested in saving a single Track, I'd just log that one route and save it, with the history off.
    JS_racer likes this.
  17. JS_racer
    JS_racer Adventurer
    Oct 15, 2010
    62
    Twin Cities MN
    makes sense, thanks. i'll do that... seems easy enough
    i only have 1 track displayed, just for that route that day.... i could imagine the cluttered mess of all the tracks displayed all the time...
  18. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,165
    Georgia, Vermont (that's one town, not two states)
    If it makes you feel any better, the Montana is even lower priority...!
    --mark
  19. mrmagloo
    Jun 24, 2020
    107
    NW Chicago Burbs
    LOL, I'll settle for tied for last place.
  20. AliveDK
    AliveDK Long timer
    Sep 8, 2013
    1,148
    Denmark
    Cru Jones and Rofor like this.
