Garmin Zumo XT
Discussion in 'Mapping & Navigation' started by VCheng, Feb 25, 2020.
  1. mrmagloo
    mrmagloo Adventurer
    Jun 24, 2020
    82
    NW Chicago Burbs
    Fwiw, I very highly recommend folks to orientate the face DOWN for the cleanest and most accurate print. (the surface with the Zumo XT print) While I'm glad your's fit well, printing it on the side is rather unstable and allows a greater degree of distortion. I just wish that Thingaverse allowed you to adjust the orientation of the uploads.
  2. AliveDK
    AliveDK Long timer
    Sep 8, 2013
    1,148
    Denmark
    I did, in the 2ND try :-)
    Btw my first 3D print ever !
  3. HeliMark
    HeliMark Long timer Supporter
    Jun 23, 2013
    1,084
    Tennessee
    It does not turn completely off, just standby. I noticed the User Agreement coming up from standby now, unlike the last Zumo I had, which did not.
    wheel2wheel likes this.
  4. mrmagloo
    mrmagloo Adventurer
    Jun 24, 2020
    82
    NW Chicago Burbs
    Looks like a very nice printer!
  5. Bobo
    Bobo Are we there yet? Super Supporter
    Jan 11, 2011
    396
    Golden, CO
    I haven't read the last 50 pages yet so pardon me if my reply is redundant.
    On the 660 if you bypass a shaping point it will recalculate to the next waypoint(announced) or shaping point (unannounced). Easy peasy. Not so on all GPS after the 660. Now it will recalculate to the next waypoint and ignore shaping points.
    I usually put a couple waypoints in the first mile or two so that if I happen to miss one then I can skip it and the next one is nearby and I am good. Also I put various waypoints along the way. Shaping points are merely a suggestion - you can't count on them once it if forced to recalculate. Also, something I noticed on my 590, is that if you put a waypoint right on the intersection where you are turning, you will hear "you have arrived at xxxxxx" but you will not also get the instruction to turn. For that reason, I always put the waypoint a few hundred feet from the actual turning spot. Just my 2 cents.
  6. mrmagloo
    mrmagloo Adventurer
    Jun 24, 2020
    82
    NW Chicago Burbs
    To your point, I too am running into some strange and unexpected behaviors with the XT, primarily centered on the fact that it seems to discriminate against imported Trip/Routes, by refusing to let you edit or move shaping points, even though the feature is present. And, as you mentioned, sometimes Basecamp Routes are not cleanly imported, making the first point even tougher. Frankly the entire inclusion of Explorer is a friggin joke for them to add to an incoherent 'solution', that even further exasperates the problem by bring another, not very compatible app into the picture that is pretty crappy anyway. Frankly, for such nice hardware, the software is pretty bad and hard to excuse.
    sati8d likes this.
  7. moseven
    moseven Adventurer
    Apr 4, 2020
    17
    anywhere
    Sorry if this has been asked before, searched and couldnt find anything.
    So I finally got around to installing the power from cradle direct to the battery.
    When I dock the XT it obviously turns on and stays on without starting the bike.
    Does anyone know if by going direct to the battery this discharges the battery enough to cause problems? I was going to connect to a switched circuit but I like the idea of the XT staying on when I turn off the ignition. I would obviously take the XT off the mount when I'm away from the bike for any time just dont want to try and start the bike the next day only to find the bikes battery is dead.
    cheers
  8. simon crewe
    simon crewe Been here awhile
    Sep 27, 2007
    276
    Haslemere, UK
    If I leave my Montana, even powered right off, overnight on my KTM 990, It wont have enough juice to start next morning. I think that unless you have a can bus equipped bike, that shuts down after a period of time, wired direct to the battery is risky.
    moseven likes this.
  9. mrmagloo
    mrmagloo Adventurer
    Jun 24, 2020
    82
    NW Chicago Burbs
    The Zumo will absolutely run down your battery over time. YOU need to find a 'Switched' power source so that the cradle no longer gets power when the ignition is off.
    moseven, R2k and simon crewe like this.
  10. Bobo
    Jan 11, 2011
    396
    Golden, CO
    To be clear, this behavior started with the 590 and BMW Nav 5. Also I never mentioned that it is a Basecamp import problem, I don't think that it is. I find that just adding the extra waypoints as I described makes it a very minor issue. I'm still reading this thread and have not even used my XT yet, so I don't know if things are any different with the XT.
  11. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,610
    Central Ohio
    If the 590 recalculates, it will do so from your current position to the next via point, ignoring any shaping points prior to that via point. This is a big problem if the route only has shaping points between beginning and end points. The route can be salvaged if you determine the closest shaping point and edit it to be a via point. If you then restart the route using that new via point as the beginning, the remaining original shaping points will be used. I understand that if you get off route using the XT, there is an new option to get back to the original path using a "Nearest Entry" choice.
    If you drag the route into an intersection, a shaping point will be created rather than a via point - the point is not announced, but any turning instructions will be heard. If you have placed a via point in the intersection you can get the same result by changing it into a shaping point in Basecamp or by editing it on the 590.
  12. CrazyCooter
    CrazyCooter --Crazy MoFo-- Supporter
    Oct 9, 2004
    527
    Redding, CA
    Just got my XT and trying to pair to my Inreach mini....GPS says its incompatible?
  13. bradrh
    bradrh Been here awhile
    Sep 4, 2011
    761
    poncha springs, co
    I read every post in this thread with 'track' in the text & I learned how to make the current track line thicker with MAP_TRK_CLR in the theme. I'd like to change the color but it doesn't make sense. The hex color code that is in there is a blueish, but it shows up as red?? Anybody figure this out?
  14. Zave
    Zave ******
    Jun 16, 2014
    1,497
    BC Canada
    Thats what it came with when i tried to connect my se via bluetooth but it should connect your mini via ant
    CrazyCooter likes this.
  15. CrazyCooter
    Oct 9, 2004
    527
    Redding, CA
    So I can leave it paired with my phone and then ant will connect it to the XT? That would be cool.
    Sōul-ō likes this.
  16. moseven
    moseven Adventurer
    Apr 4, 2020
    17
    anywhere
    Thanks Simon - I'm going to go switched in the near future - all the best.
    simon crewe likes this.
  17. moseven
    moseven Adventurer
    Apr 4, 2020
    17
    anywhere
    Doing that as we speak - Thanks for help
  18. Smackit
    Smackit Life Is Good Supporter
    Jun 5, 2007
    1,050
    Reno, Nevada & Guangdong China
    And then there's the Monterra, abandoned 12 seconds after product launch.
    Eltjo, tsak8, OldKenny and 1 other person like this.
  19. jeffk
    jeffk n00b
    Jun 2, 2008
    8
    When external power is lost (turn off the key etc..), the XT will start its update and shut down function unless you press the big cancel button and then it stays on with its own battery power. Best of both worlds I think.
  20. HeliMark
    Jun 23, 2013
    1,084
    Tennessee
    I wish there was a way to stop it from always checking for an update. Maybe by disabling the WiFi? Everytime it has an update, you have to connect it to a power source anyway. Not interested in it checking at every gas station.
