GasGas Raga Marzocchi Fork Factory Setting?
Discussion in 'Trials' started by SherpaT, Sep 3, 2018.
  1. SherpaT
    SherpaT Adventurer
    Jul 31, 2008
    85
    York, PA
    The 2011 Raga manual shows that the right fork clicker is rebound, and left is compression, and there are 25 clicks each, but doesn't say what the default settings are. Anyone know the 'standard' settings for the forks?
  2. mung
    mung Been here awhile
    Apr 18, 2008
    882
    Idaho
    If you have stock oil and oil level the middle of the range will be good.
    Hoss Cartright and SherpaT like this.
  3. Sting32
    Sting32 Trials Evangelist
    Oct 27, 2009
    1,869
    Minneapolis, Ks
    Everything I have read (thanks to stuff HOSS posted to the internet over the years) bikes shipped from factory were set as close to middle as possible.
    I had the 11, 12 & 13 raga, the settings I recall before I made any mods are (according to notes I took, hopefully you get it) 14 clicks to fully closed was stock.
    Ill share this too. Rear reiger was 14 from closed (that big adjuster you use the batt shaped tool on) bottom screw was 32 clicks from screwed all the way IN. Seems I tried 6 more clicks open, then had to back that off to 2 clicks from stock. Just FWIW I have no idea what to do with the shock and seemed it was same on the TRS....
    SherpaT likes this.
  4. SherpaT
    SherpaT Adventurer
    Jul 31, 2008
    85
    York, PA
    Thanks a lot guys, that makes perfect sense. I appreciate the info! :thumbup
  5. motobene
    motobene Motoing for 46 years
    Mar 9, 2013
    5,396
    Wichita Mountains SW Oklahoma
    Bear in mind the number of clicks really doesn't mean much. It's not an absolute setting. The forks will be much slower in cold weather, for example.
    Play with the extremes and set them for the conditions and your preferences. If you don't yet have preferences ride more. You will :-)
