1. eNewsletter Sign Up
GatosBros
Discussion in 'Vendors' started by jesusgatos, Aug 11, 2012.
  1. soupknotzee
    soupknotzee Been here awhile
    Nov 4, 2008
    262
    The LBC / Summit County
    Looking to order one of your universal damper mounts. Are they in stock? If so, can I PM you with a my info and PayPal payment? Thanks!
  2. RobertoGatos
    RobertoGatos Go-Go-GatosBros!
    May 10, 2010
    122
    Chico, Ca
    In stock and ready to ship. No need for paypal, here's a link, can checkout right on the site.
    Gracias!
  3. soupknotzee
    Nov 4, 2008
    262
    Thanks !
    One other question... So if I decide to go taller or even just keep it at the no spacer height, wont I need longer riser bolts?
  4. RobertoGatos
    May 10, 2010
    122
    Chico, Ca
    Yes, you will need loner hardware as your bar height increases.
  5. soupknotzee
    Nov 4, 2008
    262
    That's what I figured. Now the trick is too find the longer riser bolts as I am running the discontinued Easton EXP bar system. The risers did come in different configurations (various D bolt lengths in 58mm-90mm) I am currently at 70mm so if I can locate a 90mm set I should be good to go. If not I may have to rethink how to make it happen.
  6. RobertoGatos
    May 10, 2010
    122
    Chico, Ca
    Ah, know exactly what you mean. Used to run those bars myself. I'd usually buy the right length hardware and introduce it to my bench grinder...
  7. jesusgatos
    jesusgatos fishing with dynamite
    Nov 17, 2006
    2,593
    on the road
    dieselcruiserhead and BT4Stroke like this.
  8. Alleta
    Alleta n00b
    Aug 3, 2016
    4
    Thanks for the link
    marcin_gda2 likes this.
  9. dieselcruiserhead
    dieselcruiserhead Long timer
    Jul 25, 2008
    1,678
    Park City, Utah
    like! Rad guys, looks gorgeous too as always...
  10. Wallawalla
    Wallawalla n00b
    Mar 28, 2017
    4
    Is Gatosbros still in business?? Havent been able to get a hold of anyone ?
  11. jesusgatos
    Nov 17, 2006
    2,593
    on the road
    Absolutely, have you left any messages? We've been spending most of our days way out in the mountains, with spotty reception, but we'll get right back to you!
  12. Wallawalla
    Wallawalla n00b
    Mar 28, 2017
    4
    I did, got a email last week asking for pics that I sent, no reply.
  13. Wallawalla
    Wallawalla n00b
    Mar 28, 2017
    4
  14. RobertoGatos
    May 10, 2010
    122
    Chico, Ca
    Just bounced an email back to 'ya.
  15. Wallawalla
    Wallawalla n00b
    Mar 28, 2017
    4
    You're correct about the similarity with the sxs, these clamps are off a 13 Husaburg and are adjustable from 22mm to 19mm. They bolted right up to my 16 250xc. Problum is the stock clamps have a 5mm cap and the nut and cap on the blue clampe are 15mm reducable to 12mm by fliping the nut cap upside down. Also the bar perch bolt holes are 2 sets of 3 holes (6 total).
    Do you think you will have a mount ?
    As it stands im looking at a stock KTM PHDS Scott mount with a bar riser block as a spacer under the stock mounts. They will need to be machineddown to 5mm. I would rather have your sick ass mount !
  16. jesusgatos
    Nov 17, 2006
    2,593
    on the road
    No, sorry, the tripleclamps with three holes use different spacing between sets of holes so our mounts won't work and there's aren't enough of those out there to justify making custom parts to fit them.
  17. TBR
    TBR One Life ~ Live It...
    Jan 31, 2013
    2,339
    Cruisin' China since '89..
    thebigman likes this.
  18. jesusgatos
    Nov 17, 2006
    2,593
    on the road
    Yeah, we just accidentally let our ssl certificate expire, whoops
  19. thebigman
    thebigman XR's all the way . Big Thumps or V-twins
    Jul 9, 2010
    3,964
    Texas Gulf Coast
  20. msowsun
    msowsun n00b
    Dec 16, 2016
    1
    I am still getting the certificate error message. Is there a problem?
    I'd like to order some side triple clamp mounts for my WR450F. Is there a phone number I can call to order?
    Benduro likes this.
