Genuine Motorcycle G400C
Discussion in 'Thumpers' started by conchscooter, Nov 7, 2015.
  1. rjmorel
    rjmorel Dual Sporticus
    Oct 31, 2005
    542
    Walla Walla, WA
    Any one put heated grips on their G400c? Tis the season.
    Anyone know what amps the stator is putting out if it could handle heated grips , jacket, etc?
    thanks rj
  2. boyjeenyus
    boyjeenyus Adventurer
    Feb 16, 2017
    78
    Alrighty! Finally back to my welding machine, so I finished up my exhaust system with all the cl350 heat shields. The fit isn't exactly factory-quality, but I'm very happy with the results. Lots more power than stock with the bigger exhaust, and finally has the looks I wanted. I left the pipe-wrap on there behind the front heat shield to add more thermal protection. I may eventually remove it, but happy as-is for now:) YAY!
    Stephen
  3. rockt
    rockt Long timer
    Oct 13, 2003
    3,068
    Canada
    Very cool, nice job Stephen. How many miles on the beast now?
  4. boyjeenyus
    Feb 16, 2017
    78
    I'm at 2,230 miles today. I couldn't be happier with this bike. Next levels of mods will be an upgraded braided front brake line, and most likely some higher-quality fork springs.
    Stephen
  5. NJ-Brett
    NJ-Brett Brett
    Sep 8, 2010
    10,464
    Southern New Jersey
    Looks heavy, no kick start?
  6. boyjeenyus
    Feb 16, 2017
    78
    I actually think that it's lighter than the OEM one. Probably lighter steel, lighter mufflers, and no catalytic converter. The kick start lever is strapped in above the air intake. I can unstrap it, and put it in place if I need to use it....still works, just not bolted in place.
    Stephen
  7. Rosetwig
    Rosetwig n00b
    Jun 14, 2019
    6
    Philadelphia
    I did, last fall. A pair of Oxford HotGrips (Adventure type). They fit great and really work well. I also upped the battery to get more cranking power, as we've all learned that the factory standard one is a bit wimpy. I probably could have done it all at home, but my buddy runs a small vintage British bikes garage, so I swapped him a six-pack for some help.
  8. boyjeenyus
    Feb 16, 2017
    78
    Rosetwig, Which battery did you go with? I could use a little more cranking power sometimes.
    S
  9. Ginger Beard
    Ginger Beard Instagram @motopossum Super Moderator
    Jun 24, 2008
    14,451
    FLAT Lander
    That turned out great man!
  10. Rosetwig
    Rosetwig n00b
    Jun 14, 2019
    6
    Philadelphia
    I went with a WestCo 12V12-B battery, which I purchased from Apex Battery. Here's a direct link to the product page on their site: https://www.apexbattery.com/westco-12v12-b-battery-201632.html
  11. cpazambrana
    cpazambrana Adventurer
    Apr 29, 2020
    17
    Miami
    Guys. I’ve been having problems starting the bike. Although the battery is fully charged is still very lazy to start and hesitates a lot. The stock battery is only 50 CCA. I got this one from Battery Plus which is a perfect match for the space and has 130 CCA. It works very nice and now the bike doesn’t hesitate to start. Just some information.
  12. runpet
    runpet Been here awhile
    Jul 12, 2011
    553
    Sconsin
    Thanks, I've experienced the same problem. Does the battery just slip in or does something have to be modified? It is really bad the colder the temperature outside.
  13. cpazambrana
    Apr 29, 2020
    17
    Miami
    This one just slips in without the need for modification. Just plug and play. Earlier in this thread a battery from ebay was recommended but when I got it, it was too big and required some modifications.
  14. runpet
    Jul 12, 2011
    553
    Sconsin
    Excellent! I will have to try it. Thanks
