Getting into trials?
Discussion in 'Trials' started by Sting32, Mar 22, 2010.
Can we VOTE for a Sticky?
  1. Yes
  2. Nah
Multiple votes are allowed.
Results are only viewable after voting.
  1. OzCr0w
    OzCr0w She'll be right mate!
    Feb 15, 2016
    225
    Royalla NSW
    Can I ask a question. Do you guys set up the bars in a similar way to other dirt bikes inline with the forks or very slightly either side as preffered?
    I'm spending lots more time on my firts bike a Rev3 and am un decided on what is correct or more comfortable to be starting to get used to?
    Its a bit of a different world and I don't want to get comfortable on what may place limits later, if that makes sense, thanks..
    Huzband likes this.
  2. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,461
    Cowford, Fl.
  3. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,483
    Pittsburgh PA
    As with the video @Huzband posted, the bars should be forward and the levers should be pretty high, it will feel awkward for a while but you will get used to it. You will find yourself moving your dirtbike levers up too.
  4. BikePilot
    BikePilot Long timer
    Jul 5, 2005
    11,930
    Golden CO
    Mine are setup the Ryan Young way, seems to work well.
    jonnyc21 and Huzband like this.
  5. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,461
    Cowford, Fl.
    jonnyc21 and Yinzer Moto like this.
  6. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,461
    Cowford, Fl.
    In those two vids Ryan talks about bunny hops, zaps, nose wheelies & such. Things that, if you're new to trials, you won't be thinking about so much. All the same, bars forward is still where you want to be. Everything just works better. Levers up, too. Imagine dropping off a ledge or steep down & your wrist rolls back ever so little, giving you throttle just when you didn't need it. If your levers are down in a position where they're comfortable for standing, you have zero chance getting to them before things get ugly. Keep them up, you'll adapt much quicker than you might think.
  7. BikePilot
    Jul 5, 2005
    11,930
    Golden CO
    Yep levers up is key. In his class Ryan begins by setting everyone’s bars and levers up properly.
    Yinzer Moto, jonnyc21 and Huzband like this.
  8. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,462
    Dubuque, Iowa
    I preach this to all the dirt bike guys who show up on their new to them trials bikes. Rotate the bars forward, move the levers up, which we do while they are here. And then the first thing they do when they get home is move them back to dirt bike style...:confused
    Huzband and Norman Foley like this.
  9. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,461
    Cowford, Fl.
    Last year I took my mountain bike in for some maintenance I wasn't comfortable doing myself. When I picked it up the tech had repositioned my levers down where "he thought" they should be. :bluduh
  10. BikePilot
    Jul 5, 2005
    11,930
    Golden CO
    Is changing the rear tubeless tire on a trials bike (external spokes so no rim strip / spike seal to worry about) materially different from a dirt bike or street bike tire? I need to put some fresh rubber on my bike ASAP. I’ve done probably hundreds of dirt bike tires but haven’t done a trials bike yet.
  11. Bluetonguejak
    Bluetonguejak Pretend racer
    Sep 16, 2009
    3,103
    Gippsland
    Same process, just a lot easier than an Enduro tyre - especially with UHD tubes and dual rim-locks.:thumb
    BikePilot likes this.
  12. Ditch
    Ditch Long timer
    Sep 9, 2004
    1,713
    abq,nm
    Some take a bit to seat the bead. Throw the tire in the sun for a bit and use your favorite tire lube. Might need a strap around the outer circumference to squeeze the bead out to the rim on each side.
  13. BikePilot
    Jul 5, 2005
    11,930
    Golden CO
    Thanks guys! I'll have a go at it here shortly. I have a pair of fresh Dunlops to spoon on. Should improve my backyard trials situation while we are in lockdown :D
    Norman Foley likes this.
  14. Yinzer Moto
    Jun 13, 2008
    36,483
    Pittsburgh PA
    I put a tube in the new tire and inflate it to stretch the tire out. This will make getting the bead to seat an easier process. Getting it to fully seat can take a lot of PSI. I inflate to 50 or 60 and leave it for a while, maybe even overnight.
    Mow-ree likes this.
  15. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,369
    nm
    The Dunlops are usually the easiest to mount. It takes 80 PSI plus to bead. Best if you have the clip type chuck connection so you can control the air at a distance. I have never seen a trials tire blow apart, but have seen tires blow and it is scary.
  16. BikePilot
    Jul 5, 2005
    11,930
    Golden CO
    Thanks yes 80psi in that squishy tire would be pretty scary. I like the tube idea to stretch it out and might do that.
  17. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,236
    New York... The Finger Lakes
    With a mounting doughnut he can do it with a hand pump....
    fprintf, Ditch, jonnyc21 and 2 others like this.
  18. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,369
    nm
    No, just a lots, and lots of lube. And each rim is different. It was not long ago the rims would not keep a bead with a Dunlop. The doughnut just starts the bead, not some magic vodoo. Having done spilt rims on trucks and I have seen multiple tires explode, trucks, cars, atv`s and motorcycles. Caution with a remote valve is even safer than a tire cage.
    jonnyc21 likes this.
  19. Asphalt Assault
    Asphalt Assault Been here awhile
    Dec 14, 2008
    275
    Tustin, CA
    I recently picked up a 16' Beta 300 and have only managed to go out and ride about 6 or 7 times so far. I was really surprised at just how challenging it is to ride a trials bike halfway proficiently which makes it far more appealing to continue to learn. There is a great group of folks here in SoCal who have given me some pointers along the way. Here is the one photo of me not falling on my head over the weekend.
    DyrWolf, Metal_JD, Buschog and 6 others like this.
  20. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,369
    nm
    Trials riding is also easier with the correct tire pressure. 3-4 rear, 6-7 front.
