Giant Loop Moto - Adventure Proof Packing Systems & Gear
Discussion in 'Vendors' started by OlafofOregon, Jan 2, 2015.
  1. floalex
    floalex Adventurer
    Jun 17, 2018
    78
    Munich
    Hi @OlafofOregon
    I try to mount the GL RTW with the quick release panniers on the new version of the Givi racks.
    The new on the Givi racks is that they have one “neutral” frame where you could add the mounts for Monokey or Cam-Side (Trekker Outback).
    Having mounted the RTW on the Quick release plates I notice that one nut on the top is getting in contact with the Givi frame. I tried a shorter screw but it’s the nut.
    Do I need to use the screw or are 3 screws on the top enough?
    My other solution would be to put a washer between the upper holder and the plate to extend the space.
    What’s your opinion?
    Once completed I’ll post pictures how to mount on the KTM 790 Adv R.
    OlafofOregon likes this.
  2. OlafofOregon
    OlafofOregon Long timer Super Supporter
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Dang, I guess we need to see the new design. Have you tried reversing the bolt through the framesheet and Pannier? I’m thinking the bolt head is lower profile than than the nut, which can go inside.
  3. STLR
    STLR Been here awhile
    Jan 21, 2017
    379
    SoIL
    Will someone give me the equivalent saddle depth measurement on the Great Basin por favor? I’m trying to see if it will work for my intended purpose before pulling the trigger. Thank you!
  4. floalex
    floalex Adventurer
    Jun 17, 2018
    78
    Munich
    Yes reversing works. The shorter screw (16mm) has an even lower profile.
    I’ll post more details in the coming days. I’m still perfecting the setup.
    New design:
    Also the holes of the new Givi frame design can get in the way.
  5. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Hopefully the hook and latch positions can be adjusted to work around the holes, bends, etc. Thank you very much for sharing the info.
    Do you switch back and forth between soft luggage and the Givi hard cases? Mostly wondering, because some other racks avoid these complications.
    But the feedback is super helpful, so we can help other customers solve new issues.
    Remember to use blue thread lock when everything is assembled and adjusted.
    Can we send you a t-shirt as a thanks for the info and help?
    Happy New Year!
  6. floalex
    floalex Adventurer
    Jun 17, 2018
    78
    Munich
    It does fit around the holes, but you don’t have much space. I’ll share pictures the next days.
    So far I don’t have Givi panniers. I had the V35 in the past.
    I choose the Givi racks because I had good previous experiences. Also they are affordable in Europe (148€), versatile, detachable and have a low and narrow fit on the 790 Adv.
    Now with their new idea to make a “basic rack” where you can buy kits to fit either the MonoKey or the Camside (Trekker Outback) it makes things easier for their customers buy harder for anyone else.
    I’m very sure that this is the way for all future Givi racks.
    Overall I’m happy with the racks and as I share my knowledge it will be a solvable solution to everyone who wants to go with the new Givi racks.
    But I agree, there are racks out there, that fit the GL pannier racks easier.
  7. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Hello and Happy New Year!
    Here are the Specs & Features listed on our website - the dimension you're looking for is 14 inches:
    • Weight: 6 lbs with all included components
    • Dimensions (fully packed):
    56″ – From the bottom of pannier, across the top to the bottom of the other pannier.
    10″ – height of bag in top center
    6″ – distance from inside to outside lower saddle bag legs
    14″ – front to back in top center
    Which bike are you trying to fit? The Great Basin Saddlebag is compatible with virtually every motorcycle designed to carry a passenger:
    https://www.giantloopmoto.com/product/great-basin-saddlebag-roll-top/
    STLR likes this.
  8. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Are you able to position the locking clasp, so the bend in the top middle does not interfere?
  9. STLR
    Jan 21, 2017
    379
    SoIL
    Thank you and I had seen those top center measurements on the website.
    It is for the BMW GS and here is what I'm trying to accomplish: https://advrider.com/f/threads/soft-luggage-no-rack.1283659/#post-39076765
    I am trying to make sure that I will still have adequate room to sit/move on the seat with the bag in place, and ideally without having to move the tail bag.
    I really appreciate the help.
  10. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    The Great Basin Saddlebag is designed to occupy the space a passenger would, so it should mount in front your tail bag and fit on the pillion seat.
    STLR likes this.
  11. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Tillamook Dry Bag is back in stock! https://www.giantloopmoto.com/product/tillamook-dry-bag/
    Tillamook Dry bag features access to gear from both ends without unstrapping, air purge valve, integrated quick-release anchor straps, two carry straps and D-ring attachments to convert to a backpack, rugged Giant Loop grab handles, additional lash points, 48 liters, two-tone design.
    WYO George and Mordster like this.
  12. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Have a great weekend everyone!
    #golightgofastgofar
    #giantloop
    @donniredphotos
    ________________________________
    #adventurebike #ktm #adventureride #motorcycletrip #advrider #overland #motorcycle #adventuretravel #adventuremotorcycle #adventuretouring #dualsport #adventuremoto #adventurelife #dualsportlife #advlife #motorcycleadventure #motorcycletravel #wanderlust #advrider #dualsportlife #advmoto #explore #motorcycletour #motorcyclecamping #bigtrail #motor_adventure
    floalex likes this.
  13. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
  14. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Buckin’ Roll Tank Bag – 20% OFF PRE-ORDER, SHIPPING APRIL 2020
    USA MSRP
    $99.00
    Pre-Order Special
    $79.00
    NOW AVAILABLE FOR PRE-ORDER – SHIPPING APRIL 2020! Our slim, trim minimalist Buckin’ Roll Tank Bag has been completely redesigned for 2020, featuring 1.5 liters of packable volume, RF-welded waterproof construction, electronics pass-through, clear vinyl phone pocket — and designed to stay completely out of the way, with no buckles in knees or crotch, even when riding the most technical off-road terrain.
    https://www.giantloopmoto.com/product/buckin-roll-tank-bag-2020/
  15. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Registration is now open for our 2020 Giant Loop Ride! Secure your spot at the 9th Annual GL Ride today with a refundable $100 deposit (half price for non-riders for those who wish to bring a partner):
    https://www.giantloopmoto.com/produ...p-ride-2020-crystal-crane-hot-springs-oregon/
    Last year, 120 riders joined us, as well as a handful of vendor friends.
    9th Annual Giant Loop Ride, June 5-7th, 2020 at Crystal Crane Hot Springs, Oregon
    What’s included with your $300 (more details below):
    * Two nights of no-hookups camping and hot springs access
    * GL drinkware and 2020 GL Ride t-shirt
    * Two catered dinners, two catered breakfasts, snacks and beverages
    * Extensive GPS tracks library with routes to suite all bike types and riders – four-plus years of collecting and confirming routes
    * Games and prizes
    * On-sight medical support provided by Adventure Medics
    LexJeeper likes this.
  16. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    WYO George likes this.
  17. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    40% OFF OVERSTOCK SALE! 22" XL PRONGHORN STRAP NOW JUST $14.40/PAIR ($24 MSRP) WHILE SUPPLY LASTS
    We're clearing out our current stock of Pronghorn Straps, because we have NEW 2020 fully Giant Loop designed and manufactured Pronghorn Straps coming this spring!
    https://www.giantloopmoto.com/product/pronghorn-straps/
    “These versatile cargo straps are a traveler’s best friend and perfect for securing all sorts of stuff to your bike.” — Motorcyclist magazine
  18. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    New 2020 Pronghorn Straps available for pre-order - 20% OFF!
    As Giant Loop has grown over the past 12 years, we are increasingly able to design exactly the products we want without being constrained by manufacturing. Giant Loop introduced stretch polyurethane straps to the powersports market in 2014, but this new version is completely Giant Loop designed and manufactured to our spec. Features: Stamped aluminum buckles, length indicated on strap, arrows line up for easy fastening, metal buckle sheathed for scratch protection, buckle prong holds strap in place for pre-fitting and easy chaining together of straps. Color coded by length. Limited lifetime warranty. Go light. Go fast. Go far.
  19. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
  20. OlafofOregon
    Jan 17, 2011
    3,212
    Bend, Oregon, USA
    Need help packing? Let us help you lighten up and slim down, with our adventure proof packing system. Go light. Go fast. Go far.
    Photo: Scott Rabeneau in Vietnam
