Go Sportsters
Discussion in 'Road Warriors' started by Bloodweiser, Dec 20, 2010.
  1. trumpet
    trumpet Group W Bench
    Aug 2, 2008
    5,074
    Connecticut
    Looks kind of new to be not running. What's up??
  2. Ginger Beard
    Ginger Beard Instagram @motopossum Super Moderator
    Jun 24, 2008
    14,952
    FLat Lander
    According to the code b2203, ignition is toast. Bike's a 2019 with 16k miles.
  3. Kevm
    Kevm Eternal Optimist
    Feb 18, 2018
    5,912
    Medford, NJ
    Hold on, toast is a bit of an overstatement.
    That code is Ignition Switch Input Shorted Low - you have a pinched or bare wire that is shorting the ignition switch input signal.
  4. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    17,133
    the hills
    B2203-Ignition switch input shorted/low
    Look for pinched/cut wiring/maybe even backed out from connector. Try under tank and where handlebar harness goes under brake MC perch and switch housing.
    Cogswell and Ginger Beard like this.
  5. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Definitely an overstatement but understated when sitting in 90 degree weather!:rofl
    Was able to get it bump started with the help of a friend and limped it home. I'll get into the wiring and ignition switch tomorrow. It's intermittent and the issue completely went away during a big thunderstorm as I rode home. Came back when the sun came out, so that's a new one to me.
    frog13, Webman, merc16 and 1 other person like this.
  6. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Thanks, will do!
  7. Kevm
    Feb 18, 2018
    5,912
    Medford, NJ
    Yup, an intermittent short in rain sure sounds like connector or insulation.
    RedDogAlberta and Ginger Beard like this.
  8. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Started right up this a.m. and promptly tossed 2 more codes.
    spokester likes this.
  9. Kevm
    Feb 18, 2018
    5,912
    Medford, NJ
    spokester and Ginger Beard like this.
  10. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Thanks Kev. Got into it this morning. Found corrosion on the brake switch connector, on the contacts in the ignition switch and extremely dirty run/kill/starter switch. All cleaned up and no codes. Going to do a short ride today.
    One thing I never did on this bike, which I've done on every other bike I've ever owned, was to go through the bikes electrical connections with dielectric grease. Rookie mistake on my part. Lesson learned.
    frog13, Bors, JRowland and 6 others like this.
  11. vntgmx
    vntgmx Been here awhile
    Jun 5, 2007
    568
    South Jersey
    Hopefully you're all good as I couldn't imagine it being anything too major with that age and miles as Sportster are usually pretty dang hardy and reliable.
    frog13, JRowland and Ginger Beard like this.
  12. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Seems good after a 30 min ride. No codes and multiple solid starts. I was pretty surprised that it happened. I've put over 200k miles combined on a few different Sportsters and the only issues I've had didn't show up until 98,000 miles and that on a bike that's seen the Dalton and has lived 30% of its life on dirt roads and trails.
    frog13, vntgmx, JRowland and 2 others like this.
  13. anotherguy
    Jun 18, 2009
    17,133
    the hills
    As the systems become more complex that's the kind of goofy shit you'll experience. Fortunately they're fairly simple to chase down.
    It's like the pin that wasn't installed completely in my Road King's ECM connector that lit the dash up like a Christmas Tree at 500 miles. You automatically think yer screwed but after a little poking and prodding guided by the codes it's cured. Haven't seen that in the ensuing 34K miles.
  14. c1skout
    c1skout Long timer
    Sep 29, 2009
    1,906
    Western PA
    Stopped to see the
    "Smallest church in 48 states" today.
    PhiRR, alpina, Cogswell and 17 others like this.
  15. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,700
    mena, Ar
    Saw this little sporty at the rally formerly known as bikes blues and bbq.
    spokester, Cogswell, Richy and 5 others like this.
  16. ag_streak
    ag_streak Tiene Ruta Cuarenta? Supporter
    Aug 9, 2006
    8,079
    Blue Ridge/Blairsville, GA
    ^ ^ ^ Abomination! :deal
    The antithesis of a 'Go Sportster'...
  17. Ginger Beard
    Jun 24, 2008
    14,952
    FLat Lander
    Well, code b2223 came back during my commute. Looking like I've got a bad rear brake light switch. No bare wires and a clean connector.
    merc16 likes this.
  18. natez1
    natez1 Gear Head Deluxe
    May 14, 2009
    147
    kitsap county, Washington
    I know you're a knowledgeable guy but if I was faced with multiple codes and varying circumstances I would be seriously looking at grounds, starting at the battery and working out till I get every one. Just a suggestion. Hope it gets fixed soon as a sporty is such a unique ride in todays sanitized world.
  19. anotherguy
    Jun 18, 2009
    17,133
    the hills
    b2223-rear brake switch shorted/low. Is the brake lamp working? Is it stuck on? These are all BCM codes. Do you have access to an Electrical Diagnostics Manual?
    Ginger Beard likes this.
  20. anotherguy
    Jun 18, 2009
    17,133
    the hills
    Hows that? It's being ridden. Just 'cause it's not for you means nothing.
    c1skout, johnwesley and Trackjunkie21 like this.
