Go Sportsters
Discussion in 'Road Warriors' started by Bloodweiser, Dec 20, 2010.
  1. Jarlaxle
    Jarlaxle Bregan D'Aerthe
    Nov 2, 2014
    12,765
    New England
    Appearance. The button-head Torx bolt looks better than the nut.
  2. c1skout
    c1skout Long timer
    Sep 29, 2009
    1,652
    Western PA
    No biggie removing the muffler on my solid mount. One bolt and a clamp, so my axle is in the factory position. My beef is why put the schrader valve on the KICKSTAND side?
    That's just dumb!
  3. Ginger Beard
    Ginger Beard Instagram @motopossum
    Jun 24, 2008
    13,582
    FLAT Lander
    I've owned 3 Sportsters and have never seen one set up that way. That is odd.
    Dirt Road Cowboy, Webman and Traxx like this.
  4. victor441
    victor441 Long timer
    Jul 27, 2009
    2,763
    Sonoma Co., Calif.
    The 04-13 rubbermounts are a PITA because the crossover pipe connects to the muffler rather than the head pipe, more plumbing to deal with.
  5. rd400racer
    rd400racer Long timer
    May 14, 2013
    4,239
    Louisville, Ky
    Yep, that was my take on it when I diagnosed removing the exhaust last night. Way too much work. I'm biting the bullet today...stopping at Harbor Freight to buy the motorcycle jack, a bead breaker and a pack of big ass zip ties and doing my own tires. I'm getting sick and tired of the money I spend to have tires mounted. While this might not be the perfect setup it's a start. I'll rig a shade tree balancer for now.
    Richy, Traxx and Webman like this.
  6. victor441
    Jul 27, 2009
    2,763
    Sonoma Co., Calif.
    I always use zip ties when doing tubed tires (nearly impossible to pinch a tube that way) but I don't bother when I'm doing tubeless. FWIW two things that make DIY tire changes MUCH easier for me are a fixture to hold the wheel securely at waist level and a gallon of Ruglyde tire mounting lube from Napa. (dish washing soap works but some types can be corrosive to aluminum). The MC wheel balancer from HF is OK if you get a good one (I was lucky and did) but from what I've read many come with bent axles, poorly machined cones, etc.
    Also made a crude DIY bead breaker (tacked it on to a bicycle work stand) and that is a big help when doing tubeless tires, especially on rear wheels...
    JRowland, Richy, Traxx and 2 others like this.
  7. HapHazard
    HapHazard Waiting for Gudenov
    Dec 30, 2009
    5,352
    Central CT
    AND the rotor has a bigger diameter than the pulley so it's harder to access the valve, so it's even stoopid-er!:dirtdog
    c1skout, Dirt Road Cowboy and Traxx like this.
  8. Webman
    Webman Been here awhile
    Jan 5, 2016
    764
    Arizona
    That’s a slick setup! If you have dimensions and details of how you made the bead breaker and your stand, I’d really appreciate it. I can weld ok, and would love to be able to change tires myself, but I have no idea how to make the tools you showed.
    Ginger Beard, victor441 and Traxx like this.
  9. blackstone0514
    blackstone0514 Adventurer
    Mar 4, 2015
    32
    Boise, Idaho
    Finally, no bikes on the lift. Just choose one and ride. Might post the dyna up for sale soon. Dont ride 2 up much anymore and the sporty scratches the harley itch for now.
    Mykola, LuciferMutt, JRowland and 8 others like this.
  10. victor441
    Jul 27, 2009
    2,763
    Sonoma Co., Calif.
    Thanks! but I winged it on both and the dimensions, geometry, etc. are much less than ideal, you would be better off getting some rough dimensions from a commercial unit and making a drawing (what I should have done) I used a cut down bucket for the wheel fixture but need to make a new one using a steel car rim.
    However can highly recommend the Jawhorse, I use mine for tire mounting, wheel balancing, welding, all sorts of stuff...
  11. Webman
    Jan 5, 2016
    764
    Arizona
    Wow, I’ve gotta get one of those! I hadn’t seen one before. Just looked them up, and looks like an amazing tool. Much easier than clamping stuff to sawhorses!
    JRowland likes this.
  12. Dirt Road Cowboy
    Dirt Road Cowboy I aim to misbehave.
    Feb 19, 2011
    1,387
    Tyler, Texas
    Might I suggest tire lube?
    So much better than Windex or soapy water! I didn't even need to use zip ties, because the tires slid right onto the rims!
    Richy, HapHazard, Webman and 2 others like this.
  13. johnwesley
    johnwesley wanta be
    May 11, 2006
    3,314
    mena, Ar
    good looking bikes, both good models. I especially like the dyna
  14. blackstone0514
    Mar 4, 2015
    32
    Boise, Idaho
    Whats the consensus on Hagon shocks nowadays? Anyone have first hand experience? I'm looking at their Nitro 14.6" in particular.
    Webman likes this.
  15. Webman
    Jan 5, 2016
    764
    Arizona
    Agreed, although I'm partial to the Sportster! :D
  16. HapHazard
    Dec 30, 2009
    5,352
    Central CT
    A few years back, I replaced the awful stock shocks on my '93 with a set of their basic "Girling look-alikes" and was impressed with the improvement in ride and handling for a little over $200. I'd imagine that the higher models would give more adjustability, which can be a good thing.
    Oilleaker, Webman and Traxx like this.
  17. victor441
    Jul 27, 2009
    2,763
    Sonoma Co., Calif.
    Definitely worth it, especially for welding....since you operate the clamp with your foot both hands are free to position the work. One more gratuitous mostly off topic Jawhorse photo but I promise it will be the last ;-)
  18. Richy
    Richy Long timer
    Sep 9, 2005
    3,408
    Deadbury FL
    Someone told me long ago that it was to keep the schrader valve out of the chain goo.
  19. Oilleaker
    Oilleaker Ne’er do well tinkerer Supporter
    Nov 20, 2019
    192
    Bronx NY
    Might just be because they use the same wheel on big twin where the belt is on the right side
    Richy and Dirt Road Cowboy like this.
  20. Webman
    Jan 5, 2016
    764
    Arizona
    Just ordered one, it'll be great for fabrication work. Thanks!
    Traxx and victor441 like this.
