good idea or bad idea?
Discussion in 'GS Boxers' started by tallbaldrider, Sep 17, 2019.
  1. tallbaldrider
    tallbaldrider still a n00b Supporter
    Oct 28, 2014
    465
    Northern VA
    Fellow inmates, I saw this ad in the FM for a Dan Moto exhaust. Other than the weight saving, which does it really make a difference on these huge bikes, why do riders do this? Would this be a bad thing to do to my R1150GSA with 64K miles? Thanks in advance for your opinion. 2019-09-17_10-13-41.jpg 2019-09-17_10-14-02.jpg
  2. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,930
    Villa Maria Sanitarium, Claremont, CA. USA
    Lighter weight. Better looks if you are in to that. You could either lose or gain one or two horsepower....but you for sure won’t gain any significant hp. A lot of guys do it for the sound. I do.
    rg sw wa. and tallbaldrider like this.
  3. PaulBarton
    PaulBarton Long timer Supporter
    Apr 14, 2015
    2,116
    Seattle
    I thought that was pretty cool...
    I have the Dan Moto Y-pipe (and Jesse's) that this would feed into "perfectly". I've always heard that the DM exhaust with Y-pipe is too loud but one or the other is good. I like the sound/function of the Y-pipe with stock exhaust. I've run it with just a down pipe (too loud).
    I think the cat restricts it more than the muffler but YMMV.
    tallbaldrider likes this.
  4. wellcraft
    wellcraft Been here awhile
    Aug 31, 2008
    841
    PA
    Not my cup of tea but if it fits your needs why not? Plus for $125 I don't think you can go wrong, don't like it put it up for sale and recoup your money.
    AZgman and tallbaldrider like this.
  5. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,894
    Is that just an extension to move the exhaust pipes out past your bags? Of is that a header replacement that removes your cat and and muffler and stuff?
  6. PaulBarton
    Apr 14, 2015
    2,116
    Seattle
    it replaces the muffler. It has an extension to move it out past the end of the bags. Without the extension, the bracket would mount to the stock muffler location and the exhaust pipe would be lower (as shown in the pics) but not all the way extended to the rear.
    So, it would connect to the rear side of the cat converter.
  7. tallbaldrider
    Oct 28, 2014
    465
    Northern VA
    Appreciate the feedback. I think it looks good with cases on but not without and I go back and forth with those set ups.
  8. Dan-M
    Dan-M Long timer Supporter
    Aug 21, 2007
    3,291
    US 550 & I-25
    Take your muffler off and start it up. You'll get an idea of just how loud it will be before you buy.
    #8
    PaulBarton likes this.
  9. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    5,983
    Zer0-Zer0-Zer0-Zer0
    That's a good suggestion and it may actually work even better with turn-down muffler tip ie. completely without slip-on... Added benefit is running full size LH bag too! :deal
    #9
  10. tallbaldrider
    Oct 28, 2014
    465
    Northern VA
    Remembered I had done this a couple of years ago. I did not post it because there was an error in my method. I had the meter and the motorcycle in the same place for both tests, but after removing the muffler, the point at which the sound was being produced (the end of the muffler vs. the end of the cat) was about 18 - 20 inches further away from the meter, so the readings can't be exactly compared. The reading appeared to be lower with the muffler removed, but i bet it would be higher if I had moved the meter a muffler's length closer.
    Muffler installed:
    Muffler removed:
    #10
  11. tallbaldrider
    Oct 28, 2014
    465
    Northern VA
