Google maps, display your gpx
Discussion in 'Mapping & Navigation' started by ohgood, Aug 20, 2017.
  1. ohgood
    Sep 21, 2010
    7,809
    alabama
    I was playing around with Google maps (beta!) and noticed some of the tracks I uploaded to Google My Maps showed up in the regular maps application.
    hmm, well that's neat. guess I'll have to stop bashing Google maps as a possible guidance source. cool.
  2. Tripped1
    Tripped1 Welp
    Aug 6, 2009
    22,398
    Nippon
    Wait, You can activate Navigation?
  3. Myway
    Myway Long timer
    Jan 2, 2007
    6,286
    Knobby country
    Once uploaded a gpx track, does it stay my own property?
    What is in the license of the app?
  4. ohgood
    Sep 21, 2010
    7,809
    alabama
    you can use navigation, but it does not follow the track you uploaded, yet
    it was displaying the track, until navigation started. (corrected this, thanks)
  5. ohgood
    Sep 21, 2010
    7,809
    alabama
    you can set the privacy in my maps, but I would bet that Google uses it for calculations without letting everyone see it.
  6. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,038
    Central Mn
    I have been experimenting with an Android app I found called "Geo Tracker". It's mostly a one-trick pony, just hit one button and it starts dragging a line on a screen. At the end of the day or "route" there are a couple format-options for exporting once you get home and connect to a PC. One of the exports is certainly dot-GPX files.
    A few more steps to it later, and some "import" experimenting in "My Google Maps" and I ended up with a test-route that could be e-mailed or shared, or I could pull it up later on my Android phone and see my current position in relation to the line or path the app saved. Just in the experimenting stage, but a couple of us took a ride and it logged the afternoon- with my phone shooting the signal through my aluminum top box to get the job done (testing it to see if it would work that way).
    It cut out in a couple spots where I assume the signal was weak, but the app kept running and continued with the logging of the afternoon. Kind of fun to fool with.
    At one point we ran into construction and had to turn around and back-track (road closed) so one leg of the ride has a chunk missing cause of that.
    Upon importing the file in "My Google Maps" there was also an option to have it say how long the route was, and in this case it was a 122 mile test ride.
    I could go out again now, pull up this route, zoom in or out on my Android phone and I would see my current position in relation to the blue lines and easily re-follow them or share them. I'm new to much of this but it was fun to be able to trace the day as a test.
    ohgood likes this.
  7. petertakov
    petertakov Been here awhile
    Jun 19, 2012
    132
    Until you hit "start" and then it disappears. Likewise when you are in "driving" mode.
    For whatever reason Google allows us to make our own ittenaries in My Maps but do not want us to be able to follow them in Google Maps.
    ohgood likes this.
  8. ohgood
    Sep 21, 2010
    7,809
    alabama
    weird, ain't it ?
    #8
  9. Ogre_fl
    Ogre_fl Long timer
    Oct 13, 2004
    4,027
    Cook Bayou, FL
    How do you upload a gpx to google my maps app?
    #9
  10. chrisjk
    chrisjk Been here awhile
    Jun 30, 2007
    631
    NW Kent, UK
    This site uses Google maps onto which you can simply drag your gpx files in order to display them. I have used this to display really large files of lengthy trips. There are also some handy editing capabilities that allow you to split and join different tracks to create new ones.
    #10
    ohgood likes this.
  11. Ogre_fl
    Ogre_fl Long timer
    Oct 13, 2004
    4,027
    Cook Bayou, FL
    Yea thanks, tried that and another similar one GPX2KML , but they are clunky to use (viewing, not the actual conversion) on my tablet compared to the goolge apps.
    #11
  12. FenceJumper09
    FenceJumper09 Been here awhile
    Oct 2, 2014
    460
    Birmingham, AL
    #12
  13. ohgood
    Sep 21, 2010
    7,809
    alabama
    #13
    FenceJumper09 likes this.
