GPS for Android-based Smartphones
Discussion in 'GPS 101 - Which GPS For Me' started by GravelRider, Nov 8, 2012.
  1. BKMLWR
    BKMLWR Wondering around...
    Feb 25, 2009
    5,337
    North Carmel
    the manual tells how to pick wpts and build a route but I get a "direct" route from wpt to wpt which does not follow the road. It does talk about importing files...
    #61
  2. ohgood
    Sep 21, 2010
    9,693
    alabama
    here is the normal way of picking pints on a road...
    direct routing, fast and simple: http://youtu.be/O5qOQ0Wvldk
    and waypoint routing:
    waypoint routing with locus: http://youtu.be/_gZ2cOD5GpM
    #62
  3. BKMLWR
    Feb 25, 2009
    5,337
    North Carmel
    I did get Broute setup and got it working with Orux to make routes....
    need to understand BRoute better now....when I zoomed in on the world map and chose my area the squares have an 'X' but if you click on one of the lines forming the 'X', it goes away and the size of download decreases...
    #63
  4. ohgood
    Sep 21, 2010
    9,693
    alabama
    the brouter interface for choosing and downloading data sets is not exactly fantastic. for that reason, now i just point people to this-
    ...the full list
    http://h2096617.stratoserver.net/brouter/segments2/
    of data points. to me, it's much easier to look up a LAT / LON area i want to have available, and just download it via a browser.
    if they're aware enough to know LAT/LON of their general areas, they can handle choosing the files to download to the sdcard. if not, refering them to "mapquest" as a source for routing information is the fall back. usually, the same people that don't 'get' the brouter setup process won't actually need offline routing data sets anyway. (not being a wise ass, just being practical :clap )
    #64
  5. David_Moen
    David_Moen Long timer
    Apr 23, 2006
    1,691
    Salmon Arm, B.C. Canada Eh!
    I have planned out a week long trip on Google Maps on my PC. I can't find an option to save the route, copying the URL from the address bar and pasting it into a shortcut or text file seems to be the only way I can save the route. I'd like to be able to plan a long trip like this on my PC, and transfer the route to an Android phone.
    I've been looking at the website for CoPilot, it doesn't seem like that will import routes.
    BTW, we are leaving Saturday morning so I need something I can get my brain around in a hurry!
    Your thoughts?
    #65
  6. ohgood
    Sep 21, 2010
    9,693
    alabama
    Download oruxmaps, osmand and locus pro NOW, and play with each one for two hours.
    The one that doesn't make you mad, pick and use. Download maps for the area, and we'll have a tutorial for importing ROUTES in a minute.... But you really need to find the app that fits your personality now.
    #66
  7. worwig
    worwig Long timer
    Nov 30, 2009
    1,947
    Hog Mountain
    I do this.
    Export the KML data from Google Maps.
    On the PC, use ITN converter (Google that) to read the KML. Convert that to a CoPilot TRP file with ITN converter.
    Copy the TRP file to you phone. Put it in the "com.alk.copilot.namarket.premiumusa/NA/save" directory.
    In CoPilot go to 'plan and edit route', options, load.
    Thoughts. Sure, stop procrastinating. :rofl
    #67
  8. doggitter
    doggitter Long timer
    Jan 4, 2014
    2,159
    Elmira, Oar-agin
    The planning frustration you posted here is a big part of why I dl'd ViewRanger on the pc and android. It works good to plan trips on the pc and getting it to and using it in the phone good too.
    #68
  9. Chisenhallw
    Chisenhallw Avowed Pussbag
    Feb 15, 2007
    7,740
    Conover, Nawth Cackalacky
    Orrrrr you could just skip all that and use OSRM to plan your routes. Click on 'download as gpx file'. Bam. Done.
    http://map.project-osrm.org/
    #69
  10. EmmEff
    EmmEff Long timer
    Oct 21, 2008
    2,179
    Innisfil, Ontario, Canada
    Have you seen it work on the device as well? I tried using OSRM as the routing engine in Locus and it gave an error that indicated that routing information wasn't available for here (Ontario, Canada)
    Edit: just used the website to generate a route and importing that into BaseCamp resulted in a 30km ride having hundreds of via points. Pretty useless :(
    #70
  11. Chisenhallw
    Feb 15, 2007
    7,740
    No.
    I design my route online using OSRM, just the same as you would in google maps. I click 'download as gpx file', and download it to my computer. Then I upload it to my dropbox account, which my Nexus 7 is connected to. I open Osmand, and open the gpx file. Voila!
    #71
  12. alma1759
    alma1759 Nothing
    Jun 8, 2010
    144
    Anyone using My Tracks? I'm running it on a Galaxy S5 and have downloaded a couple of different gpx files, but I can't seem to get My Tracks to find them? Keep getting a "folder doesn't exist" prompt?!
    Thoughts, advice, suggestions?
    #72
  13. doggitter
    Jan 4, 2014
    2,159
    Elmira, Oar-agin
    Try going to the file in your download foulder and opening it there. It might open My Tracks when you do.
    #73
  14. alma1759
    alma1759 Nothing
    Jun 8, 2010
    144
    It gives me an "app not available to open this file message?!"
    The files and the app just aren't taking? I'll try to down load a couple of different gpx files later.
    Thank you for the suggestion, it was worth trying.
    #74
  15. alma1759
    alma1759 Nothing
    Jun 8, 2010
    144
    It starts with "suc" for a reason...
    The folder the gpx files are stored in has the have the exact name of "mytracks/gpx" WITHOUT ANY SPACES!
    And it has to be on the device, not on the SD card. Which is odd because I though the SD card WOULD be the external storage?
    So, it seems to be working, now just need the base maps?
    #75
