GPS help
Discussion in 'GPS 101 - Which GPS For Me' started by jardine, Nov 5, 2011.
  1. jardine
    jardine 86
    Mar 18, 2009
    1,568
    Gippsland
    looking for some help please I have a Garmin 60cxs and just need to know what the difference is in planning a trip on the map in the computer in Basecamp to transfer to the unit - is it better to use the routes or tracks option? cant seem to find any simple expanation anywhere. Cheers
  2. Sleepy John
    Sleepy John Grumpy Adventurer
    Feb 2, 2010
    3,747
    Bris Vegas, Australia
    Google 'garmin routes or tracks'
  3. DrLewall
    DrLewall Master of bating
    Aug 20, 2008
    46,424
    Banned Camp
    I prefer trax over routes..routes will give you prompts to read and the 60csx screen is too small for my eyes to try and focus on..trax will show a colored track or line that you follow and if you deviate from the line, you can see it and make attempts to get back on the line.
    Yes, I prefer tracks! I never had any use for routes, but many will give a good argument for routes and they probably do have their place, but I am not interested in routes..it all comes down to your preferences..hopfully someone else will get in here and tell you why routes are better than tracks..good luck
  4. Countdown
    Countdown Long timer
    Oct 20, 2003
    6,933
    Carson City/Ridgecrest
    What Lewall said but the preference is determined by if you are planning trip off highway on small jeep roads & trails or mostly highway and graded county roads.
    One BIG problem with routes is getting the 60 to route the same path as you saw on your PC and then god forbid you make a wrong turn and the 60 Auto-reroutes you another way.
    For Dual Sport Events, promoters only give out Tracks, never Routes.
    If you go to GPSXchange.com there are thousands of Tracks but almost no Routes.
  5. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    3,769
    Walnut Crick, Cal.
    :y0!
    I'll give it a shot as well.
    A route is designed to get you from point A to point B, with the whole objective to simply arrive at B. It provides turn by turn directions ("left turn in 500 feet") and when you miss a turn or go off the route the gps will then recalculate the route and provide new instructions again designed to get you to point B from your new location.
    A track is designed to give you a "breadcrumb trail" to follow, with the objective to stay on-track. There are no directions provided and you follow you own course plotted on the gps, attempting to stay aligned with the on-screen track.
    Most of the time when I'm riding it's the journey I'm after, not so much the destination, so I prefer to use tracks.
    Hope that helps!
    It's a little oversimplified, but that should get you started. And you can always convert a track to a route if you change your mind. Sometimes it's easier to create a route in BaseCamp and then use that as a guide when creating a track if there are a maze of trails and roads to choose from when navigating your path.
  6. TRZ Charlie
    TRZ Charlie That's MR. Asshole
    Nov 13, 2008
    20,651
    Tucson, Arizona
    Hardworkingdog,
    Excellent analogy. Well done.
  7. HardWorkingDog
    Aug 20, 2009
    3,769
    Walnut Crick, Cal.
    Thanks! Even a dog has his day, I guess :D .
  8. Master
    Master Been here awhile
    Apr 4, 2010
    340
    Belgium
    I always use both at the same time. When using routes, the gpsmap tends to recalculate and you end up with a different route than the one you wanted to ride. The route provides you with turn-by-turn directions and estimations of time and distance, while the track makes sure you don't stray away from the route you planned to ride (when in doubt: follow the track, the gps recalculates the route and usually your route is back on track :norton).
    Also, a route is easier to make on the computer, because you just have to click on a few points and the computer does the rest for you. I always make routes on the computer and after that convert them to tracks with a few mouseclicks, using a little piece of software called wingdb3. I just load up both route and track on my unit et voila, good to go.
    #8
  9. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,735
    MN and NM
    I am new to this page but have been using Garmin GPS's for a long time. I am seeing lots of stuff I don't recognize.
    What is this BaseCamp? I looked on the Garmin page and it looks kind of nice. I always use Mapsource. Is BaseCamp meant to be a replacement?
    BTW. I navigate using tracks. But I also create routes on my computer because it is a lot easier to do "what if" tests using routes - mainly to see how long a leg is and how far it is to gas. Once I have finalized a route I hand draw the track and/or splice together pieces of my and other peoples tracks.
    I also take the time to create manual waypoints once the the route is set. I just like seeing them on the screen. I number them from 1-50 to make sure I don't exceed the 50 limit for a lot of units for follow-the-road routing.
    Also I plan rides for large groups and distribute the navigation data. Some of the guys just prefer routes even though I tell them that they are not always going to work due to routing differences and the fact that I often include roads that are not in City Nav.
    #9
  10. Klay
    Klay dreaming adventurer Supporter
    Nov 19, 2005
    120,084
    right here on my thermarest
    BaseCamp is for Apple operating systems, I believe.
    #10
  11. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,885
    Nelson area, Kootenai, BC, Canada
    Also comes in PC flavour.
    #11
  12. Emmbeedee
    Emmbeedee Procrastinators
    Mar 19, 2008
    11,450
    Near Ottawa, ON, Canada
    There's a version for both PCs and Macs, though the Mac version is more advanced. Mapsource is obsolete, no longer being developed. BaseCamp has some really interesting features; my favourite is the way it'll display the maps installed on certain models of gps as if the maps were installed on the computer.
    #12
  13. Countdown
    Oct 20, 2003
    6,933
    A bit overstated. Probably most people still use Mapsource and see no need for further development, and no real need to switch to BaseCamp and deal with all their old files. Obviusly new users will probably start with BaseCamp and also be happy.
    I mainly use Mapsource to manage my tracks and I have not found BaseCamp offers anything new or improved.
    #13
  14. Steve W
    Steve W Old Grouch
    Apr 28, 2008
    730
    Rocky Mountains of Alberta
    As do I. BaseCamp (both flavors) is lacking some track tools, especially in the editing department. Enhancements have been requested on the Mac side but the response from the development team has been cool to any more track editing tools. This is one area where the windows version is more advanced.
    #14
  15. Emmbeedee
    Mar 19, 2008
    11,450
    There, I fixed your post for you. No need to thank me. :1drink
    #15
  16. DRTBYK
    DRTBYK All Things GPS Supporter
    Mar 26, 2003
    8,159
    48°58′18.9″N, 89°57′39.1″E
    Can't resist. . .
    I think Jerry and Steve are both correct. If you create Routes, Tracks and Waypoints at the lowest common denominator for compatibility then there is no reason to switch from MapSource to BaseCamp. MapSource does those things just fine - once you learn the Tool methods. No need to Import all of that data from the files you've created over the years. Besides, you'd most likely have to buy a new(er) computer to get the performance needed to run BaseCamp well with the map compressions being used with the newer products.
    On the other hand, if you haven't been using MapSource long, don't have lots of data to Import and want to take advantage of some of the newer features found in newer GPS's then you might consider BaseCamp - even in it's current multiple personalities. I do a fair amount of Track editing and Waypoint updating/creating and haven't found anything I can't do in BaseCamp-Mac. Was there a Tool I was suppose to use that isn't there? Ooops, open ended question! :wink:
    I create Routes only to humor myself and to sometimes make "creating" Tracks easier.
    Change is an interesting phenomena - I like it. :norton
    Later this month I'll have a short article on BaseCamp. :evil
    Cheers,
    #16
  17. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,735
    MN and NM
    Jerry,
    Thanks for the info. I will stick with Mapsource for a while. I was really dreading thinking about having to switch. I don't think your post needed editing. Everybody on PCs that I know still uses Mapsource.
    #17
  18. wbbnm
    wbbnm Long timer
    Dec 18, 2007
    5,735
    MN and NM
    Slightly off subject. Does anyone have a good way of editing tracks,i.e., adding or replacing a small section of a long track.
    I need to do this quite a bit. Now I open the track window to be modified and delete the part I don't want. Then I get out and use Track Draw to create the new section. I open that track window and copy the points. Then I open the original track window and paste the new ones in. It would be nice if I could draw the new points into the middle of an existing track.
    Sometimes I am smart enough to draw the new track section first. Then I only have to open the track window to be modified once.
    BTW I checked around with some of the guys I ride with and, as I thought, all are still using Mapsource.
    #18
  19. HardWorkingDog
    Aug 20, 2009
    3,769
    Walnut Crick, Cal.
    BaseCamp allows one to split one track into two, and join several tracks into one :deal. Never used MapSource so I don't know if that's available there or not.
    They are added end to end (you have control of the order they get added).
    Rather than copying and pasting the points, I split the track in two right at the errant section, drew the correct section, and then joined all three tracks into one. I don't know that it's any faster or not, but it gives you a chance to see all the pieces on the map to make sure you're going to get what you expect before you join them.
    #19
  20. Klay
    Nov 19, 2005
    120,084
    I split tracks regularily in Mapsource...never tried to join two, but I imagine you could.
    I'll have to check out this BaseCamp for windows.
    #20
