GPS Recommendations / Upgrading from Garmin 395
Discussion in 'GPS 101 - Which GPS For Me' started by welcometoashley, Aug 5, 2019.
  1. welcometoashley
    welcometoashley New Member
    Jul 8, 2009
    48
    Chicago, IL
    Hi all,
    My Garmin 395 is no longer charging in the mount and I've read about problems/issues with the mount and cables charging the device. I've had it for a 3-4 years now and, instead of getting a new cable and troubleshooting, I think I may just upgrade to a new GPS.
    Any recos? The 596 looks nice, but it's kind of expensive - let me know if any owners with the 596 have issues with charging in the motorcycle mount.
  2. BillMoore
    BillMoore Long timer Supporter
    Oct 21, 2011
    1,120
    Snohomish, WA
    I have the Garmin Montana 600T that is now about 5 years old, mounted in their AMPS Rugged Mount, and it has been awesome. It was a bit expensive, but I rely so heavily on this thing for route finding, that it was worth every penny. A little bit of a learning curve on how to use it and also how to use BaseCamp for route planning, but once you figure it all out, it is pretty easy and very convenient. If anything were to happen to mine, I'd be looking at another Montana...
    wbbnm and shrederscott like this.
  3. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,593
    denver
    +1 Montana with powered rugged mount works great on my ktm 350
    Scott
  4. Blissed
    Blissed Been here awhile
    Dec 6, 2014
    348
    PNW
    +1. Original Montana 600, used on a bike (bike mount), in a car (car mount), handheld for hiking, in US and Europe, with City Navigator and various open source and custom maps.
  5. dddd
    dddd Long timer
    Jan 15, 2012
    1,334
    Montreal, Canada
    I would definitely keep it and buy a new mount. It not even 10 years old! Not kidding. It's like 100-130$? Less trouble than a new gps too.
    I suspect the mount problem is your fault. Yes. Sorry. The mount has a chip inside. Whether its pins got shorted, or had water or soap exposure, it is probably electronically damaged, not necessarily a cable problem if they were routed securely. Water damage happened to me. Changed the mount and now I keep the mount cover on all the time and put it in whatever pant I have the moment I put the gps on.
  6. deserteagle56
    deserteagle56 deserteagle56
    Feb 7, 2010
    168
    Central Nevada
    +4 on the Montana. Bought my 600 years ago when they first came out and it hasn't missed a lick since, despite several crashes. Goes with me everywhere. I have RAM balls mounted on all my rigs and the Montana and it's powered mount is moved to whichever rig I'll be using.
  7. beakerflo
    beakerflo n00b
    Jan 6, 2015
    1
    Alkmaar, the Netherlands
    I have had my Garmin 350LM for 7 years now, ridden around 200.000km's with it and I replaced my mount 3 times. Idiotic, but well.... things wear and tear. You can prolong it a bit with cleaning it with vinigar, perhaps there is some chalk on the contacts because of rain or other stuff.
    ohgood likes this.
  8. dddd
    dddd Long timer
    Jan 15, 2012
    1,334
    Montreal, Canada
    Never let any liquid come near the mount's pins array; use the plastic cover.
    It is not waterproof, water would sneak in and corrode stuff, cause shorts and all.
    The most you should ever do is rub a pencil eraser on the contacts of the mount and back of gps.
    #8
  9. Parcero
    Parcero Mundial Supporter
    Aug 7, 2008
    1,552
    Chicago physically, Colombia en mi mente.
    Smartphone with one of the numerous and free GPS apps. I prefer maps.me, and have used it four newly five years in all parts of the world. Flawless navigation, easily import and share routes, way more information available than Garmin. I use it with an old iPhone 7+, that's waterproof enough to use in a handlebar-mounted RAM X-mount without any "waterproof" or Otter-type cases that always seem to limit usability. Never had any issues despite many, many, rides through driving rainstorms.
    #9
