GPX FSE 450R
Discussion in 'Thumpers' started by MBRIDER, Dec 21, 2017.
  1. MBRIDER
    MBRIDER Been here awhile
    Nov 22, 2017
    127
    Utah
    Alright, here it is. Our brand new GPX FSE 450R thread! A bit of info has been posted on this soon to be bike in the Pitster Pro LXR 250f thread, but excitement is getting more intense for it, and I figured it deserved it's very own place to be discussed. Let the games begin!
    malignity and Navin like this.
  2. justinope
    justinope Long timer
    Oct 28, 2013
    1,873
    Lynchburg, VA
    Lots of great info out there, but the biggest question I have is price. Everything seems great, ~255lbs dry, 450cc, 6 speed, etc. Also is it a wide ratio gearbox? is it the same EFI system as the lxr 250f? all questions I have
    also may want to put a general synopsis of rumored specs / pics in the the first post to inform people who haven't been following the 250f thread btw :thumbup
    MBRIDER likes this.
  3. Bhart89
    Bhart89 Long timer Supporter
    Nov 12, 2013
    1,422
    Indianapolis, IN
    Biggest question from me is what will the MSO say (platable?).
    MBRIDER and Ogre_fl like this.
  4. MBRIDER
    Nov 22, 2017
    127
    Utah
    Yeah, I thought about listing pictures and specs in that first post too, but I kind of decided I didn't want the very first pictures to be of the pre-production speculation model, so that new comers just glancing at it would think that is the bike. I figured we would get a conversation going before pictures started showing up (which is exactly what we are doing now). That's also why I mentioned the LXR 250f thread. Because if they are really interested, they can get their first good impression there where there is a lot more info explaining the difference between the speculation photos, and what production GPX's will be like. Just my opinion though.
    Dirtleg and Navin like this.
  5. drdfblackm
    drdfblackm VeeFeer Supporter
    Sep 2, 2006
    1,267
    Safe haven from Zombies aka Flagstaff AZ
    Hopefully the EFI is better than the Asiawing LX450E....apparently the EFI is completely unusable.
  6. Bhart89
    Nov 12, 2013
    1,422
    Indianapolis, IN
    Can you share any specs like weight, HP, Torque, Seat height, etc.?
    Oh yeah, price too. :photog
  7. haulintx
    haulintx Adventurer
    Dec 10, 2014
    48
    I'm interested, depending on price and the EFI.
  8. drdfblackm
    Sep 2, 2006
    1,267
    If I'm a betting man I would say very similar to this....
    2017 LX450E
    ENGINE
    Engine Type 449cc liquid-cooled single-cylinder four stroke
    Max Power 43 hp
    Compression Ratio 11:1
    Fuel Supply Delphi® Fuel Injection
    Ignition Electric and Kick
    DRIVE TRAIN
    Transmission 5-speed
    Final Drive #520 Chain DID® ; 13/48T
    CHASSIS / SUSPENSION / BRAKES
    Frame Aluminium alloy
    Speedometer KOSO® digital
    Triple Clamp CNC machined and anodized
    Air Filter Twin Air®
    Front Suspension Fastace® 48mm inverted progressive fork
    Rear Suspension Fastace® single shock with airbag
    Front and Rear Brake Kailing® Off-Road brake system , Single 270mm disc
    Front and Rear Wheel 1.6-21 / 2.15-18,CNC hub with NSK® bearing , 7075 alloy rim , stainless steel spokes
    Front and Rear Tire CST® C7202 80/100-21' | CST C7203 110/100-18'
    DIMENSIONS
    Wheelbase 1500mm
    Seat Height 960mm
    Ground Clearance 310mm
    Fuel Capacity 8L
    Gross Weight 120kgs
    OTHERS
    Available Colors White
    Tail light R-Tech® Tail light ( Made in Italy )
    Optional Genuine Parts
    WP® 4CS 48mm front suspension ( Made in Austria )
    NISSIN® front and rear brake ( Made in Japan )
    #8
    Bhart89 likes this.
  9. MBRIDER
    Nov 22, 2017
    127
    Utah
    So I know the similarities to the Asia Wing bike will be non-existent. Keep in mind, that at this point, this is speculation, with some hard info from GPX to back it up. This bike will be based on the same chassis that KEWS uses, which is basically a clone of the 2017 & up Husqvarna TE & FE line. It will be made out of high quality chromo steel. It should be compatible with most aftermarket parts that fit the Husky. (Tanks, plastics, etc.) The suspension components themselves will be similar to the existing LXR we have now, but with higher end alloy pieces like the rear linkage. The engine is not at all the same piece as the Asia Wing model. Although similar in rated HP, the GPX engine will be manufactured by Zongshen. Zongshen is the same manufacturer of the LXR 250f we have now. It will be built with very long service intervals and high life expectancies. The 250f version has proven very durable and reliable, so the 450 should be the same. The fuel injection is unknown at this point, but I highly dought it will be Delphi based. I would expect it to run as good or better than the Kayo EFI we have now on the LXR250f. The quality and fit and finish on this bike is said to be every bit as good, maybe even better than the current 2018 model Huskys and KTMs. I have included some pictures and specs of how I think this bike will be equipped. Expect unique colors for plastics and graphics. Also, it is confirmed this bike will come equipped with a head light and tail light. It will also have a number plate included for those not wanting to run the lights.
    #9
    flagg, OUTERLIMITS and Bhart89 like this.
  10. justinope
    Oct 28, 2013
    1,873
    Lynchburg, VA
    I think the lxr 250f is delphi based right? or at least it says on the pitster site
    #10
  11. MBRIDER
    Nov 22, 2017
    127
    Utah
    It does say Delphi on the website, but the website is incorrect. The website has been found to have quite a few discrepancies. The EFI system on the LXR 250f is manufactured in house by Kayo.
    #11
  12. drdfblackm
    Sep 2, 2006
    1,267
    My point was the specs will be similar. Understanding though it will certainly not be the.
    100% the same.
    Sent from my Pixel 2 using Tapatalk
    #12
  13. MBRIDER
    Nov 22, 2017
    127
    Utah
    Yeah, I understand what you meant. I guess you could say they're similar, but really the only thing similar is the HP rating. Otherwise, they are about as similar as a Honda CRF450x and a Husky FE450. Both 450's, but very very different bikes all together.
    #13
  14. drdfblackm
    Sep 2, 2006
    1,267
    Bhart89 asked "Can you share any specs like weight, HP, Torque, Seat height, etc.?"
    I'm fairly certain my response was accurate in comparison to the GPX FSE 450f.
    So is the word that this won't be over here until the fall still??
    #14
    Bhart89 likes this.
  15. MBRIDER
    Nov 22, 2017
    127
    Utah
    Last word I got, is hopefully in the spring of 2018. April or May'ish.
    #15
    drdfblackm likes this.
  16. drdfblackm
    Sep 2, 2006
    1,267
    Oooooooooooo.......very excited about that!!!!!!
    #16
    MBRIDER likes this.
  17. MBRIDER
    Nov 22, 2017
    127
    Utah
    Me too brotha!!
    #17
  18. Chadzu
    Chadzu Lost In Space
    Nov 7, 2017
    922
    Utah
    No, its not the Delphi system. Its marked Rojo and is specific to the Kayo non EPA bike. 35mm TB, I think I read the Delphi in 34mm TB.
    The PP website has as much missinformation as fact at the moment.
    #18
    MBRIDER likes this.
  19. Chadzu
    Nov 7, 2017
    922
    Utah
    One thing of note is how different the 2t frame is from the 4t. It seems like they are dedicatied to making really good bikes.
    #19
    MBRIDER likes this.
  20. OUTERLIMITS
    OUTERLIMITS Been here awhile
    Jul 30, 2006
    285
    San Diego, CA
    I got the feeling going forward that the LXR, FSE250, TSE250 frames were going to be the same. Just assumed the 450 would be as well, but maybe that's not the case?
    #20
    MBRIDER likes this.
