GPX TSE250R 2T Enduro
Discussion in 'Thumpers' started by Navin, Dec 3, 2017.
  1. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    Another trail day, Keihin carb is back in, AER forks up front, Michelin fr/rr are new. 12/53 gearing gives me a nicer front end pop for wheelies, logs and pivot turns. Second pulls from near dead stopped too, the 53 will probably stay.
    nycmx, Dirtleg and Fallacy like this.
  2. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    Decided to experiment on clutch pull lever ratios.
    The TSE250R clutch pull is incredibly light and the levers are great for smaller hands. The light pull comes at a cost though, lever travel. This is great for less experienced riders. It makes the friction zone of the clutch lever very wide and easy to manipulate.
    I decided to reduce the lever arm length in the engine case to get a full clutch release further from the bars.
    Excuse the hack job but it works! I will be modding another stock arm by simply relocating the cable attachment. The measurements are from center of the rivit for the cable clip to the center of the clutch lever shaft.
    By reducing the length of the lever, the action is much shorter but on the other side of the equation, the effort goes up. As it sits with the shortest lever length, it’s just a hair harder pull than a 2018 SXF350 and is fully disengaged by about half the distance of stock at the hand lever.
    More testing next week.
  3. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    36,261
    Pittsburgh PA
    You could probably make an arm with multiple holes to adjust clutch feel.
  4. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    The stocker may just lend itself to that with a few holes drilled and a nut n bolt. See how the cable angle looks as
    I go a bit deeper on this one.
    andrewgore and Yinzer Moto like this.
  5. andrewgore
    andrewgore Gôremā
    May 5, 2008
    19,928
    brrrrrrlington
    I put mine on the charger today. Exciting I know.
  6. Bultaco206
    Bultaco206 Back-to-back motos suck Supporter
    Feb 11, 2007
    53,640
    Mineral Point, WI
    Bitingdog, Fallacy, Dirtleg and 2 others like this.
  7. andrewgore
    andrewgore Gôremā
    May 5, 2008
    19,928
    brrrrrrlington
    Poor things been basically sitting since June. :fpalm
    I better order another plug. It's not firing up as quick as before. Might be the less than fresh gas. :lol3
    Fallacy, Dirtleg, Yinzer Moto and 2 others like this.
  8. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    Off angle root just under the sand got me today. Rear went off line badly. Front brake locked in the dry sand and I was about to drive between two trees. Not at the new angle I was traveling at! Lol
    Face has been worse, I picked the bark from my mouth and cheeks, left hand swelling but not busted. TSE left flag guard mount broke. Everything else survived, clutch perch rotated on the bars.
    Speaking of clutch, I reset the actuator to it original shape. That experiment was worth trying but it wasn’t great, might try it again eventually or convert to a hydro set up.
    Loop two might just happen as my fingers still seem to be working!
    4D9E3347-D453-4863-8A6B-CF07C6469C41.jpeg 43428533-C0BC-48D4-89EE-5A1E17F2FA15.jpeg
    Fallacy, Bitingdog, Dirtleg and 3 others like this.
  9. Yinzer Moto
    Jun 13, 2008
    36,261
    Pittsburgh PA
    If you had TI motor mounts, that bike would have handled 10x better and you wood have threaded the needle between the trees.
  10. Bultaco206
    Feb 11, 2007
    53,640
    Mineral Point, WI
    :imaposer
    Fallacy, Bitingdog, pro5mark and 3 others like this.
  11. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    I will let Gary know he needs to mill a few batches up! The Chinesium steel moutour brackets were just dandy until that one spot. :rofl
    Final parts damage, one hand guard mount, one radiator louver torn from the frame. Thankfully everything behind those parts is intact! They did their jobs, no complaints here. Advil popping time, things are starting to hurt that didn’t hurt before.... :lol3
    Fallacy, Bitingdog, Dirtleg and 2 others like this.
  12. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    You won’t be laughing when those guys start swapping a sweet steel frame on those Ellie’s!
    Fallacy, Bitingdog, Grreatdog and 3 others like this.
  13. Bultaco206
    Feb 11, 2007
    53,640
    Mineral Point, WI
    :fpalm
  14. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    Can’t seem to sell her so gotta ride her!
    First test true for me riding the newest GPX OC 48mm forks. These really only have light DS and street use on them. Let’s see how they flow.
    Dirtleg, Fallacy and Bitingdog like this.
  15. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    I can’t speak for these new forks in rocks but here in Florida they are great. They stay up in the stroke and resistbottoming so well. They seem plusher midstroke than at the fist portion and let me really push hard. Super happy with them. I didn’t expect performance as good as the Fast Aces but these are excellent for me.
    Dirtleg, Fallacy, nycmx and 1 other person like this.
  16. Siafu
    Siafu Adventurer
    Oct 12, 2019
    20
    Buffalo
    Just took delivery of a brand new 2019 3 days ago. Even with my awareness of the wonky gas cap issue it just sort of came apart on day one and I didn't even ham-fist it. I also am curious as to when the blinker/horn kits are going to be stateside. I am already registered and insured in NYS but can't venture out on the roads because my dealer won't inspect it without the necessary parts in place. I bought this bike to eliminate the need to transport a trail bike to the trail on the back of my truck.
    I also have a question about the 2-stroke oil.Can I use Motul 800 2T in the oil reservoir or does it have to be an "injector oil"? I have a half a case of it and I wondered if it would be ok to use it up in this bike.
    So far I am very impressed with the machine. I hope it rides and handles as good as it looks. Build quality seems very high. I sold 2 older bikes that were becoming mechanical headaches and used the money from them to buy this. I look forward to learning more about the bike on this board and posting my experiences. It's good to be aboard. IMG_20191010_140219740.jpg
  17. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    15,287
    Vancouver B.C. rainforest
    1.) If you want a blinker and horn etc (aka a dualsport kit) just order the Tusk kit from RMATV. Since you don't need a headlight, the kit is cheap. @Navin can tell you the type of brake switches that you need (I think it's the Nissin style but not positive) for your brake lights. I've been using this kit for 4 years, and it's fine.
    Quit waiting, start riding:-)
    2.) Motul 800 2T will be fine. Wal-Mart Super Tech is fine too.
    Congratulations on your beautiful new bike!
    Dirtleg likes this.
  18. bark sampler
    bark sampler Been here awhile
    Mar 30, 2008
    256
    Middle of Michigan
    @Siafu, @Bitingdog
    I don’t have a TSE, but I do have some oil injection bikes and have used Motul 800t extensively in my mix bikes. I can not recommend it for oil injection. It is a higher viscosity and one of the more difficult oils to get fully mixed and suspended into gas. It works awesome at keeping the power valves clean, but I would suspect problems with it running through an injection system.
    Not trying to make this an oil thread, but injection oils are a little different. It sounds like the TSE is robust and happy with anything, but I’d make sure it was formulated for injection.
  19. Navin
    Navin Long timer
    Sep 22, 2009
    28,246
    Front brake switch, 2015 KTM EXC500 common part.
    Rear brake banjo switch, Nissin thread compatible. M10X 1.25 thread brake banjo switch.
    Glenn247, Bitingdog and Dirtleg like this.
  20. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,346
    Saranac,MI
    Would you recommend mixing with Wallyworld oil to dilute the viscosity? Would be nice to use it up I imagine.
