GPX TSE250R 2T Enduro
Discussion in 'Thumpers' started by Navin, Dec 3, 2017.
  1. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    38,881
    Annapolis, MD
    Firestone Destination A/T on my truck and 4Runner. Those are good. T
    But you don't want those new Metzelers I tried on the bike. Hell I will lever them off still almost new and ship them to you.
  2. Navin
    Navin Long timer
    Sep 22, 2009
    29,455
    A wise man never accepts another's used rubbers... :muutt
    Bitingdog, Dirtleg, LJC and 1 other person like this.
  3. Grreatdog
    Apr 6, 2007
    38,881
    Annapolis, MD
    Words to live by.
  4. offroadtoys
    offroadtoys Been here awhile Supporter
    Feb 14, 2013
    445
    Oak Harbor, OH
    Came across this the other day. Thought it was interesting because I haven’t heard of anybody tuning the PV before this. Figured I’d drop it here.
  5. offroadtoys
    Feb 14, 2013
    445
    Oak Harbor, OH
    Early on I read a few people experiencing a wonky electronic power valve actuation .
    Bitingdog likes this.
  6. Navin
    Navin Long timer
    Sep 22, 2009
    29,455
    Sharing this nugget just to confirm it, fella on FB was asking... KTM Fr/Rr wheels bolt up to the GPX bikes no problemo. Here is the GPX OEM 17" SM rear on my 18 SXF350. The fronts Ive been swapping forever now.
  7. Glenn247
    Glenn247 Long timer Supporter
    Feb 25, 2014
    2,026
    Lynchburg, VA
    Just wanted to confirm the new crop of 2021.5 TSE bikes have the "upgraded" exhaust, larger tank, kick start, and "street legal" wire harness as stock, correct?
    Tracking the suspension is different and improved...
    Also, are the plastics and seat the same or at least interchangeable with the previous generation, circa 2019?
    Anything else I'm missing in regard to differences between a 2019 and 2021.5 TSE?
  8. Navin
    Navin Long timer
    Sep 22, 2009
    29,455
    Im 99.9% sure the plastics/seat are all new. They might be 2020+ KTM compatible but not with 2019 GPX/Husky unless you change tank, seat, subframe and all that plastic. (Im told the new stuff bolts to the old bikes with a new seat/tank/subframe, etc).
    The perf pipe is on it, I think the same 2019 gen Mikuni carb, not sure about the Race CDI. Big tank too and SZC suspension which is more conventional in assembly.
    No idea on wiring or kicker. Maybe @Pitster can clear that up?
    Bitingdog, Glenn247, Fallacy and 2 others like this.
  9. Bitter
    Bitter Been here awhile
    May 9, 2020
    225
    Right behind you
    • Stage 3 performance exhaust, ripped for added strength
    • Alloy subframe (1.5 lbs lighter)
    • Pre-mix (1 lbs lighter)
    • New body work and air box for better air flow
    • Race Carb and CDI
    • Waffle style air filter
    • 2.5 gallon fuel tank
    • New LED headlight and mounting
    • 250cc two stoke engine w/electric start and kick start
    • Six speed wide ratio transmission
    • CNC triple clamps & footpegs
    • Folding billet clutch & brake levers
    • Trip / Speedometer
    • Light weight central backbone chromo "A" box frame
    • Frame guards & 3m Heavy duty graphics
    • New lightweight aluminum Enduro X Series wheels
    • Rebound, compression adjustment suspension front and rear
    • Head light, turn signals, rear view mirrors(no Horn) and tail/brake light kit & racing number plate included
    bergoff, Bitingdog, Glenn247 and 4 others like this.
  10. Navin
    Navin Long timer
    Sep 22, 2009
    29,455
    Nice!
    Via email also confirmed latest gen KTM body parts fit though they are a different shape. Someone cant post in this thread but they do read it.
  11. Bitter
    May 9, 2020
    225
    Right behind you
    The engine on these bikes is counterbalanced as well. Making it super smooth. Way less vibration than my old 95 KDX.
  12. Bitter
    May 9, 2020
    225
    Right behind you
    Hey Pitster. I changed a few things on the specs list I posted from your website. You may want to change them on the website.
    Bitingdog and Pitster like this.
  13. Glenn247
    Feb 25, 2014
    2,026
    Lynchburg, VA
    Why did you change these?
    The engine isn't exactly 250cc, correct?
  14. Glenn247
    Feb 25, 2014
    2,026
    Lynchburg, VA
    Any possibility GPX will sell an "oil injection kit" to add to the new generation TSE?
    It would be great if GPX offered a few models with oil injection; but an easy-to-install kit would be next best...
  15. Bitter
    May 9, 2020
    225
    Right behind you
    If you go to their website, their spec list answers your question on engine size. I only added "and kick start" to their engine description. Their website description doesn't mention that it has both electric and kick start. Although the spec list does. Actual cc they list is 224. They call it a 250. It's a clone of the DT230. Very few engines are the exact cc's that the model description uses. They also don't mention turn signals, rear view mirrors or functioning brake light on the website description. IMO they need to list those to their website list of features.
    Glenn247 likes this.
  16. gomerkfx700
    gomerkfx700 Been here awhile
    Dec 20, 2012
    124
    Grundy, Va
    Yes that my video. I believe all tse are affected by the powervalve not working as designed by Yamaha but I can't be sure I know the guys in brazil has the own type of fix for it on the mxf250ts I think the box they sell has 10 maps programmed into it I'm not sure though server language barrier
    bergoff and offroadtoys like this.
  17. offroadtoys
    Feb 14, 2013
    445
    Oak Harbor, OH
    Thanks for the vid! I found it interesting and the first of its kind. When looking for zeeltronics tuner it seemed very limited in the US. Do you remember where you got yours from?
  18. gomerkfx700
    Dec 20, 2012
    124
    Grundy, Va
    Ordered it from there website across the pond in the uk I spoke with them via email and ordered took about a month since they seem to be built to order
    Pablogordo and offroadtoys like this.
  19. Damifino
    Damifino Damn if I know Supporter
    Mar 3, 2006
    831
    Maryland
    About how much does the Zeeltronics controller cost? Thanks
  20. gomerkfx700
    Dec 20, 2012
    124
    Grundy, Va
    I believe it was about 225 for the controller and programmer
