Gravel Cornering....How do you do it?
Discussion in 'New Zealand' started by Night Falcon, Aug 29, 2018.
  1. clintnz
    clintnz Trans-Global Chook Chaser
    May 17, 2004
    5,141
    Rotoiti, North Is, New Zealand
    :evil ...and an MX track & an enduro loop? :wink:
    They're hauling the neighbour's logs out through the old metal pit at present but by summer we'd be good to go.
    Cheers
    Clint
    #81
    NZnic, Box'a'bits and Night Falcon like this.
  2. slowbike smallpenis
    slowbike smallpenis Tester of Tooheys Old
    Mar 9, 2003
    23,328
    Shoalhaven above Tasmania and West of New Zealand
    Gravel sucks, especially New Zealand gravel grrrrrrrrrrrr
    #82
  3. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    4,701
    Wellington, New Zealand
    So does Aussie Bulldust ;)
    #83
    Night Falcon likes this.
  4. xrjuice
    xrjuice n00b
    May 13, 2013
    9
    Upper Hood
    if youre in the southern wairarapa then parera rd is a great place to practice, smooth even surface, nice uniform gravel, not too big or small, lomg sweeping corners with plenty of visibility. just keep the drifting to a minimum so as not to upset the locals.
    #84
  5. Phreaky Phil
    Phreaky Phil Long timer
    Mar 18, 2006
    2,989
    NEW ZEALAND
    Sounds interesting. Have to put some thought into this. There's probably a lot of slow speed bike handling skills that we could play with that translate through to higher speed cornering etc.
    #85
  6. oldbeer
    oldbeer Grandadventurer
    Jan 25, 2017
    1,702
    Tamaki Makarau, Aotearoa
    Well here's a thought. If enough of us decided to chip in we could probably hire Mr Birch or his gravel-cornering equivalent and set up a training day in the middle of the North Island somewhere. We can write the brief so we get what we want out of it.
    I would definitely be a starter for something like that.
    #86
  7. oldbeer
    Jan 25, 2017
    1,702
    #87
  8. innathyzit
    innathyzit AKA Woodman
    Dec 30, 2008
    2,709
    Nelson NZ
    Or just point your bike at something that you think is impossible to ride and see what happens. Learning will happen.
    #88
  9. Micawberism
    Micawberism Been here awhile
    Apr 13, 2008
    460
    Land of the Hardcore
    B.L.A.T then braaaapppppppp
    #89
  10. Whale Rider
    Whale Rider Been here awhile
    May 16, 2010
    716
    DownUnderNZ
    Don't underestimate Phreaky Phils credentials on this subject
    WR
    #90
    NZnic likes this.
  11. Whale Rider
    May 16, 2010
    716
    DownUnderNZ
    And has that always worked for you Colin :jack:rofl:imaposer
    I wish it was that easy.
    WR
    #91
    Micawberism likes this.
  12. Phreaky Phil
    Mar 18, 2006
    2,989
    NEW ZEALAND
    thanks Gerard :-)
    I was thinking it would be great if we could get someone who really knows what they're doing.
    I wonder what Birchys hourly rate is. ?
    On the Naki ride our TEC was a past NZ#1 trials champ. Skills are the same even if the bike was an extra 150kg.
    Never been to a Birch'y training day. Not sure if he carries a pillion at any stage or if there's a pillion brave enough.
    Maybe put Dawn on the back of his KTM so he can try carrying a pillion !!!! :hmmmmm :fpalm
    #92
  13. Adrian V
    Adrian V Long timer
    Jul 15, 2008
    1,927
    Albany Western Australia
    Great thread :clap. I believe, as some have observed, that confidence plays a great part here; bottle out halfway through a corner and throttle off and the bike will run wide...… Happened to me the other week, (actually it happens regularly :D), I came around a dirt/gravel corner I thought I knew, to be confronted with a huge wet clayey patch (water had been over the road). I tried to scrub off some speed but only succeeded in starting to run wide.
    Now, my current approach to this has been learnt through trial and error, do I - stand the bike up and brake, nope, the bike will lose traction and I will spear off into the bush, do I - keep scrubbing speed off, nope, I'll keep running wide and end up in the wet ditch), do I - gas it - Yep, just enough to either spin the wheel, with the benefit of me ending up facing in the direction I need to be, or to drive me through the corner better by correcting the understeer. Trouble is it feels so counter intuitive at the time, but it works for me....
    Re drifting around corners, it took me a while, but I now feel relatively comfortable going around a corner with the rear wheel spinning slightly, it feels predictable and I am controlling how the bike is responding, rather than waiting to react to something untoward starting to happen. I learnt by getting the wheel spinning early in the corner, before the apex and using the throttle to help steer the bike the way I need to go. I've found if I get too far forward the bike can break away more quickly (un predictably?), so it's a fine balancing act to find the sweet spot. If it goes pear shaped I stand up and as someone has already said, kiss the outside wing mirror (weight out over the tyres, with a front bias I suppose?) and apply the gas....
    I also think tyres play a great part here. Motoz Adventures break traction too easily for me , I don't think they have enough side grip (and can feel unpredictable), whereas Dunlop D606's work great for me, with a 90/90 x 21 Scorpion Rally on the front.
    I reckon that the bikes we ride are often a lot more capable than we give them credit for and their ultimate cornering limits are probably higher that we are comfortable riding, so we react fearfully and stuff things up....
    Of course, I could be talking crap...…….
    #93
    bart-nz, EVLED, Night Falcon and 2 others like this.
  14. Phreaky Phil
    Mar 18, 2006
    2,989
    NEW ZEALAND
    I've used a couple of those scopion rally fronts but can't buy them here in NZ. Had to get them from your side of the ditch.
    #94
  15. RMOTO
    RMOTO Anticipating summer...
    Mar 7, 2010
    814
    New Zealand
    Chiming in with my two cents… coming into the corner, cut your line and get on the gas sooner than what you think.
    Caution: watch the throttle on the way out of the corner, you may find the front wheel ‘unintentionally’ lifts :augie
    #95
  16. Micawberism
    Apr 13, 2008
    460
    Hasn't always worked for me, nor always for the fella just in front of me. I have however perfected the art of landing on my head :p3rry
    #96
  17. Night Falcon
    Night Falcon Structural Failure
    Dec 25, 2008
    9,530
    New Zealand
    dont want to turn this into another tire thread but.......I didn't like the E07 front on the tiger on the slippery bits at all (refer water table excursion mentioned earlier) I used to run MT21's on the 690 but they had a bad uneven wear habit. Its the frustrating thing with ADV riding - there's always compromise. When I looked at what some others were using (basically road tires) I thought to my self....harden up ya plonker :loco
    #97
  18. Micawberism
    Apr 13, 2008
    460
    All the theory and knowledge in the world is wonderful. However an idiot with knowledge will never beat an idiot with skills and natural abilities.
    I cant play a musical instrument. Some people can. That's life.
    Forget the cock waving contests and ride your own ride, at the speed you feel most comfortable with. Admire those with greater skills than your own and laugh at your own mistakes and with others when they are laughing at theirs.
    Don't take yourself too seriously and have fun seems to work for me.
    Above all remember this simple thing, its only a race if your winning. :clap
    #98
  19. Night Falcon
    Dec 25, 2008
    9,530
    New Zealand
    I couldnt play a musical intrument either......until I bought one, took some lessons to get me started and practiced practiced practiced - I'll never be Eric Clapton but I play a pretty mean "Smoke on the Water"
    #99
    Adrian V and Phreaky Phil like this.
  20. young1
    young1 Long timer
    Jan 29, 2007
    1,433
    Taranaki New Zealand
    Snap!
