Grounding cable routing
Discussion in 'Airheads' started by Bwatts259, Oct 9, 2021.
  1. Bwatts259
    Bwatts259 Adventurer
    Jul 27, 2021
    14
    Rapid City
    I am going to install a smaller battery to replace the brick sitting behind my airbox. I was wondering of anyone knows of another grounding point or method other than down by the speedo cable, see picture.
  2. raywilson
    raywilson Been here awhile
    Jul 31, 2011
    613
    Portland, Or
    Why? My speedo bolt has the case threads stripped out. So i moved it over to the allen head bolt next to it. Got a steel spacer about .5" long and a longer bolt from the local hardware and bolted to the trans case. 9" #6 ground strap.
    Thanks Plaka!
    mslim and Jim K in PA like this.
  3. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,173
    I mount to a transmission cover screw. I used an aluminum chainwheel spacer (bicycle shop) and a slightly longer bolt. Went on the cover screw just above the current location. This puts the mounting point just a bit under the edge of the battery box but I always disconnect at the battery with a one tool copper lug.
  4. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,747
    Pocono Mountains, PA
    As above - I got all fancy and got an M6 stud and a serrated flange nut to bolt the cable to the case.
  5. Chad M
    Chad M 14880
    Jan 11, 2006
    1,688
    N49
    I use an M6 coupling nut. First I cinch down the cover with the nut and washer as per usual, then I use another short M6 bolt to fix the cable to the coupling nut.
  6. BoxerD
    BoxerD Just old :(
    Nov 14, 2013
    94
    South Central PA
    I fasten mine to the rear right side coil bolt across from the main chassis ground
  7. Bwatts259
    Jul 27, 2021
    14
    Rapid City
    Awesome, thanks everyone for the responses
