1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
GS-911 for 2004 BMW R1150GSA
Discussion in 'GS Boxers' started by blues_bleu, Mar 22, 2020.
  1. blues_bleu
    blues_bleu Been here awhile
    Apr 12, 2004
    269
    Singapore
    Hi, can anyone advice if I should get an GS-911. What I wanna do is mainly bleeding the abs. As there is not much fault I can reset! Also there is no service reminder. Which model of the GS-911 should I get. I might need to use it while on the road if there any problem. I also OK came across motoscan / duonix
    Anyone has any review or recommendedj which is better to use when on the road touring ?
  2. Zoef zoef
    Zoef zoef Long timer
    Apr 19, 2009
    1,214
    Finnøy Island, near Stavanger, Norway
    You do not need the GS-911 to bleed the brakes on that bike. It doesn`t even have a function to do bleeding on your bike.
    NoiZboy and SmittyBlackstone like this.
  3. blues_bleu
    Apr 12, 2004
    269
    Singapore
    So that mean I do t have to get the GS-911? So how do I bleed the abs?
  4. jclark83
    jclark83 Been here awhile Supporter
    Mar 23, 2005
    614
    Kentucky
    pops and bar-low like this.
  5. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    7,267
    Sunshine Coast B.C.
    It sure does!!
    It has many diagnostic functions for the servo ABS!
    There is a bleed test for both F&R, sensor drift test, full troubleshooting for fault codes, and more
    Without it I could not diagnose/fix many issues.:deal
    Suggest you visit Hexcode.za
    Callisto224 likes this.
  6. blues_bleu
    Apr 12, 2004
    269
    Singapore
    Hi, I have visit the hex site, but not too sure if I understand it correctly. That’s why I m asking here.
    Now the popular version is the wifi version, I can connect using my iOS to clear or read the fault code?
    But just to confirm that my model works as I have not seen it in the list. Mine is a 2004 r1150gsa.
    Can the GS-911 read the tps, also what kinda fault are we looking at the my old cow?
  7. GS Addict
    Sep 24, 2006
    7,267
    Sunshine Coast B.C.
    Yes, you can set the TPS and monitor many engine functions as well as plotting the O2 sensor.
    You can read/reset the ABS codes
    Visit the site, they have a very good explanation on what it will do for the MA 2.4 Motronic and the Servo ABS
    Click your model
    https://www.hexcode.co.za/products/gs-911/function-chart
    If you want to talk to Ted Porters Beemer Shop, Ted is the NA guru.
    https://www.beemershop.com/category...r-bmw-motorcycles-ted-porters-beemershop.html
    A very knowledgeable approachable man.
  8. JimVonBaden
    Feb 11, 2005
    90,046
    Alexandria, VA
    You do not "need" the GS911 to bleed the brakes, but as @GS Addict says, it is a good tool. Find a used yellow one here in the flea market. You should be able to pick it up for under $150.
    #8
  9. Zoef zoef
    Apr 19, 2009
    1,214
    I`m familiar with what the GS-911 can do, have one myself. OP`s question was about the bleeding process. For the bleeding itself you do not need it. Indeed, it is handy for fault clearing, checking sensors, etc.
    #9
    Mayfallover likes this.
  10. GS Addict
    Sep 24, 2006
    7,267
    Sunshine Coast B.C.
    To confirm you have bled it correctly you can confirm with the GS-911 bleed test.
    You would be surprised what you find with it thinking it is properly bled.
    ESPECIALLY if one has just upgraded the brake lines to SS Teflon. It takes a lot of bleeding in the control circuits to get every last bit of air out.
    The 911 test allows you to do that.
    #10
  11. blues_bleu
    Apr 12, 2004
    269
    Singapore
    Hi All ,
    Thanks for the input, so now I understand,
    Will the GS-911 be able to check on the tps? Coz sometime ago, I put a cover for the sensor, and it seem like the throttle is not balance. What other fault can we clear for the r1150gsa?
    #11
  12. GS Addict
    Sep 24, 2006
    7,267
    Sunshine Coast B.C.
    Yes, TPS calibration is easily done.
    All other logged faults can be cleared (provided that the are remedied)
    #12
  13. Daboo
    Daboo Been here awhile
    Jun 6, 2011
    676
    Seattle
    Try looking into the Motoscan app. It'll do all that the GS-911 does for less cost.
    Chris
    #13
  14. JimVonBaden
    Feb 11, 2005
    90,046
    Alexandria, VA
    Does it work on an 1150?
    #14
  15. Daboo
    Jun 6, 2011
    676
    Seattle
    What kind of connector do you have for the GS-911? I believe if a GS-911 will work, the Motoscan app with the scanner off of Amazon will work just fine.
    Chris
    #15
  16. blues_bleu
    Apr 12, 2004
    269
    Singapore
    Hi, where to get the motoscan app? Does it come with the scanner or I can just download off the App Store?
    #16
  17. Daboo
    Jun 6, 2011
    676
    Seattle
    You'll need to do a search on that term for more info. I only know that if I didn't already have a GS-911, that would be the direction I'd go.
    There's lots of info on this forum and others on what to get and what it'll do.
    #17
  18. GS Addict
    Sep 24, 2006
    7,267
    Sunshine Coast B.C.
    Google is your friend.
    #18
