GS 911 Question
Discussion in 'GS Boxers' started by enrich, Jan 18, 2020.
  1. enrich
    enrich Been here awhile Supporter
    Jul 7, 2018
    113
    Keswick, VA
    2017 GS; new GS 911 w/ the oblong OBD connector
    What's the process for "calibrating" the transmission? Manuals and FAQs not clear on this. I was able to calibrate my fuel mixture, which did seem to make a difference in how the bike ran. Anxious to see what- if anything- the transmission calibration might do.
  2. Mark Hooton
    Mark Hooton Been here awhile
    Sep 7, 2011
    148
    The guys at Hex offer fantastic support - just a suggestion but if you mail them they normally are very helpful (or they are with me).
    enrich likes this.
  3. enrich
    Jul 7, 2018
    113
    Keswick, VA
    Hexcode's been very helpful in getting me up and running with the device. I'm actually looking to hear from someone who has done this on their bike.
  4. Mark Hooton
    Sep 7, 2011
    148
    Ah ok, I understand. How did the fuel calibration go? Never done it with mine......
  5. andynj
    andynj Been here awhile
    Jul 9, 2013
    464
    To calibrate the quickshift you need to be able to run through the gears, I've done it on the center stand others have done it on the road.
  6. enrich
    Jul 7, 2018
    113
    Keswick, VA
    Thanks Andy!
  7. enrich
    Jul 7, 2018
    113
    Keswick, VA
    Fuel calibration was easy. Select the function then follow the instructions. From memory, all you needed to do was run the motor at idle until the fan kicked in, shut everything down and on restart whatever changes were made are applied.
    Bike was running fine before I did this, and after it just seemed to have a smoother idle and felt smoother when applying power. Could all be in my head and wishful thinking though after spending $400 on it. Bit like getting a shave and a good haircut- you were fine when you went in, but feel just that much better afterwards :)...
    Massabusa likes this.
  8. enrich
    Jul 7, 2018
    113
    Keswick, VA
    Found an answer for the transmission question here. Only question is can it be done on the center stand or must it be done on the road?
    https://advrider.com/f/threads/gs-9...on-euro4-wethead-boxer.1340091/#post-37430619
    #8
  9. Mark Hooton
    Sep 7, 2011
    148
    Thank you
    #9
  10. Masterblaster
    Masterblaster Long timer
    Dec 18, 2010
    1,216
    Conroe Texas
    Youtube has some good vids
    #10
  11. Back2Dirt
    Back2Dirt Adventurer
    Jul 7, 2016
    65
    NE Ohio
    https://www.amazon.com/ScanTool-OBDLink-Bluetooth-Professional-Diagnostics/dp/B00H9S71LW
    If this post belongs somewhere else, please advise. I saw this obd diagnostic tool advertised as ‘works with bmw late model bikes’. I’m a gs-911 owner, and am sure that tool does more than an obd scanner. But I also wondered how much more, in the context of roadside diagnostics and cost/valve.
    Anyone have insight into the existence of obd ports on the newer gs bikes, and the usefulness of obd scanners?
    (I saw JVB on this thread and just KNEW he’d have a thought or three!)
    Thanks all.
    #11
  12. Josephvman
    Josephvman I'm the Decider Supporter
    Nov 27, 2002
    4,208
    Houston, TX
    is there an issue with your transmission that you’re trying to fix by calibrating it?
    #12
  13. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    7,102
    Zer0-Zer0-Zer0-Zer0
    It was old post and looks like more about calibrating SAP rather than transmission...
    #13
  14. enrich
    Jul 7, 2018
    113
    Keswick, VA
    No issue. Was running through all of the available options on the GS 911 and figured I'd do it for the sake of doing it. Heard that it may help SA work a bit smoother, but I don't regularly use SA.
    Ended up doing it on the center stand and running though the gears. Simple to do, but no noticeable change.
    #14
