GS-911 questions?
Discussion in 'GS Boxers' started by PineyMountainRacing, Jun 9, 2019.
  1. BMWBOB51
    BMWBOB51 Going slower, but bench race faster :)
    Sep 25, 2014
    674
    I just buy a cheap used DELL I7, 8 mb, upgrade to Win 10 and swap out HDD to SSD. In it for $200 and gets the job done.
    #21
    ultane likes this.
  2. CrustyAPO
    CrustyAPO Long timer Super Supporter
    May 7, 2008
    2,563
    New York state (unfortunately)
    I second the SSD. I have a Win10 laptop, maxxed out the RAM, and put a SSD in, now it takes 27 seconds from pressing the power button to being ready to go. Way faster than it came from the factory. Plus I wiped out all that Dell "malware" and it runs way better.
    #22
  3. PineyMountainRacing
    PineyMountainRacing Oops....
    Jul 2, 2008
    4,839
    Sarasota, FL / Sylva, NC
    OK, I think I’ve figured it out, thank you all very much :lol3 I connected the 911 to the OBD2 port, ran the usb cable to my 12 yo Dell notebook running XP (can’t believe the battery is any good, it’s been in a closet for the last 10).
    1. you do not need Internet to use the GS-911. I was able to access the entire menu, run my ABS pump and bleed the ABS pump without being on the WWW. I will say that the menus are more “detailed” than when on an iPhone. You get all of your bike’s specific build sheet, showing all options, even my luggage that was added to the bike at the time of sale.
    2. when you start to use the 911 for anything other than reading faults, observing real time data or accessing ECU info, it asks if you want to register that VIN. That’s why mine wasn’t showing my VIN, all I had done was read / clear fault codes.
    what I did find was a couple lines referencing service intervals. I’ve never seen a service reminder on my ‘17 with 17,000 miles. Next service date Jan 1, 2009? What’s really weird is after you clear faults, those 2 lines disappear. As soon as you run another autoscan, they return. I’ll keep an eye on those numbers and see if they change in the future.
    Cheers :beer
    #23
  4. JimVonBaden
    Feb 11, 2005
    83,679
    Alexandria, VA
    That 2009 service date is why you never get a service reminder. Mine is set for the same date.
    #24
  5. PineyMountainRacing
    Jul 2, 2008
    4,839
    is there any significance to that date?
    #25
  6. JimVonBaden
    Feb 11, 2005
    83,679
    Alexandria, VA
    Not that I am aware of, just a default I suspect.
    #26
    PineyMountainRacing likes this.
  7. alijanah
    alijanah Adventurer
    Feb 22, 2012
    28
    Brunei Darussalam
    Can the GS-911 update the TFT firmware ?
    #27
  8. Ken Oath
    Ken Oath Adventurer
    May 13, 2018
    70
    Perth, Australia
    ISTA+ for BN2020 or E-Sys.
    #28
  9. AussieRider123
    AussieRider123 Adventurer
    Oct 21, 2017
    59
    Sydney
    GS911 doesn't allow updating of any software version of any modules of any bikes.
    ISTA+ or e-sys is required as Ken wrote.
    #29
  10. Tor
    Tor Imported Norwegian
    Nov 27, 2005
    2,310
    South Carolina
    I use my iPhone's hotspot to connect. That way I get full functionality even on the road (when I have phone service) To get this set up, you use the WIFI utility to connect to your iPhones hotspot. Take a note of the IP address the iPhone is giving the GS911 (you will see it in your WIFI setup app).
    While you have the GS911 hooked up to your bike, open Safari on your iPhone, type in the IP address in the website address field, and will connect to the GS911 with full service functionality.
    #30
    ultane and LAFS like this.
