1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
GS Wheels Love Zip Ties
Discussion in 'GS Boxers' started by Pruhusky, Nov 7, 2015.
  1. Pruhusky
    Pruhusky Adventurer
    Sep 30, 2011
    70
    GS 1.jpg GS 2.jpg GS 3.jpg GS 4.jpg GS 5.jpg I saw this on the web and had to try it. Works like a charm. Only tool I used was a pair of pliers to crank on the zip ties. Took the opportunity to install one of those nicely machined right angle valve stems that JVB mentioned. Nice.
  2. bracky72
    bracky72 Long timer
    Feb 22, 2011
    1,069
    Charles Town, West Virginia
  3. GAjetmech
    GAjetmech Been here awhile
    Jan 8, 2010
    263
    North Georgia
    Good to hear about this technique working well. Thanks for posting.
  4. motomandan
    motomandan Been here awhile
    Nov 26, 2010
    576
    Mechanicsville MD
  5. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    2,024
    Southwest Washington
  6. lewisjr1
    lewisjr1 Long timer
    Sep 26, 2008
    6,811
    DC metro
    I'm definitely going to try this zip-tie method for my next tire change. This thread is at least the second or third time a member has successfully used the technique on a GS.
    As for breaking the tires' bead, when at home at least, I just ride through my yard after deflating the tires. Call me lazy, but that works for me.
    smithly, CJ3Flyer, pancho and 2 others like this.
  7. 1aretea
    1aretea Been here awhile
    Aug 7, 2009
    126
    Stacey's Mom's house
    I've been doing this for a while. Saw it on You Tube. Some times you can reuse the zip ties.
  8. gofast1320
    gofast1320 Been here awhile
    Apr 22, 2010
    844
    Middle Tennessee
    where do you get those valve stems?
    #8
  9. YesRush
    YesRush Long timer
    Aug 17, 2014
    4,350
    Va
    Wunderlich brand at your BMW dealer or online ordering or fleabay.But then we'd need the correct size of hole.Any one know?
    #9
  10. filterwrench
    filterwrench Been here awhile
    Apr 26, 2013
    949
    Langley BC CANADA
    Zip Ties work great......[​IMG][/IMG] [​IMG] my new bead breaker.....
    #10
  11. cds247
    cds247 Long timer
    Sep 17, 2008
    1,698
    Vermont
    Just measured it at 11.45mm diameter on my 2009 gs spoked rims.
    #11
  12. motomandan
    Nov 26, 2010
    576
    Mechanicsville MD
    #12
  13. Tubulchain
    Tubulchain ODAAT Supporter
    Oct 10, 2009
    289
    Rhode Island
    Makes me think that we ought to call one of the cable television channels and see if we could make show devoted to what you can do with zip ties! Just think, we could prolly get 24 shows on it AT LEAST. :D Oh heck yeah bud.
    #13
  14. YesRush
    YesRush Long timer
    Aug 17, 2014
    4,350
    Va
  15. Scottgsa
    Scottgsa Adventurer
    Oct 26, 2015
    11
    Behind the pine curtain, east Tx
    Have the location in Alaska with a 300lb teen mom that's also a midget and its a sure bet!
    #15
  16. Gruesome
    Gruesome Alter Heizer
    Apr 28, 2007
    1,607
    Chicago
    Just in case someone is using the search feature and stumbles across this thread: I tried both removing a Tourance (original ) 150/70 R17 from a BMW R1150GS tubeless spoked rim, and putting a new Tourance Next on, and in both cases the zip ties got more in the way than they helped.
    Yes, I have seen the online videos where the tire just slips over the rim after the zip ties are on: nothing even remotely like this does happen for this particular tire+wheel combination.
    #16
  17. BillGsa
    BillGsa Been here awhile
    Sep 2, 2014
    785
    Eastern Panhandle, WV
    Did you heat the tire's 1st, makes a big difference.
    A couple hours on black top in the sun works or stack them up & put a drop light inside with aluminum foil over the top.
    Worked for me with TKC70'S on my 15 GSA.
    #17
  18. Gruesome
    Apr 28, 2007
    1,607
    Chicago
    Yep, temperature was up in the 80s, and the tire in full sunshine before and during the work. Mounting was actually not so difficult once I resorted to using levers (i used wrenches; ordered motionpro bead breaker bars & tire irons now), but I had to remove 2/3 of the zip ties.
    #18
  19. filterwrench
    Apr 26, 2013
    949
    Langley BC CANADA
    Figured the zipties would not work on all tires and rims,but they sure work well on the new GS and since I replaced my vise as a bead breaker with the Bead Buster changing tires is a breeze.
    #19
    picard likes this.
  20. BillGsa
    Sep 2, 2014
    785
    I picked up a used set of TKC80's with 600 miles on them, seems like a good time to try them so I removed my TKC70's with 1,600 miles & put them in stock.
    I mounted the 80's with zip ties & it was so easy I would have been embarrassed if someone was watching.
    What pressure are you guys running in the 80's?
    #20
