Guglatech Filtration System install on 1090R
Discussion in 'Hard. Core. (1090/1190/1290)' started by ladyknieval, Mar 11, 2018.
  1. guglemonster
    guglemonster Crivens!!! Supporter
    Aug 28, 2007
    1,805
    Italy
    Mate
    zip is PA 6.6, totally inert to petrol, we use the same kind of zip to secure the fuel pump clips since always !!!!
    ScooterNoMore likes this.
  2. jonz
    jonz Miles are my mantra Supporter
    Aug 16, 2004
    5,533
    CA dez (it's a dry heat)/West Yellowstone,MT
    PA 6.6?? What is that? I'd like to source my own as it wouldn't really be cost effective to ship a single zip tie.
  3. sizzlingbadger
    sizzlingbadger Been here awhile
    Jan 28, 2013
    490
    New Zealand
    Most Zip Ties are Nylon, which is highly resistant to the effects of petrol.
  4. Newbusa
    Newbusa Long timer
    Aug 21, 2006
    1,422
    Qualicum Beach
    I've used a zip tie around my fuel pump as well,but was concerned about the effects of gas on it so stuck one in a jar of gas, a year later it still looks the same.:-)
    ScooterNoMore and guglemonster like this.
  5. guglemonster
    Aug 28, 2007
    1,805
    Italy
    hi, do you still have the big one we sent along with the filter?
    PA is Polyamid, commercial brand name is Nylon, but if you go to a shop you should see on the etiquette PA or polyamid, as for the lenght, our is close to 530mm, @Green Boy was using a 450mm, I recommend the 7,5 mm wide one, more robust and adequate for the application ;)
    cheers
    ScooterNoMore and jonz like this.
  6. guglemonster
    Aug 28, 2007
    1,805
    Italy
    the white capsule and base pump is made of Nylon too, I believe PA 6.0, without fiberglas charge in the matrix, ;)
    cheers
  7. jonz
    Aug 16, 2004
    5,533
    I live half the year in Montana and half the year in California. Montana does not have the PITA vapor recovery nozzles that California requires. I'm moving back to California in the next few days and had resigned myself to removing the gas tank filter because that in combination with the California nozzles made fueling up just too difficult. I look forward to trying the zip tie fix.
  8. sizzlingbadger
    Jan 28, 2013
    490
    New Zealand
    My kit arrived yesterday, install has gone fine so far. I installed the in-line filter as shown in the photo below, didn't require any extra hose, just cut the OEM hose and fitted the filter.
  9. guglemonster
    Aug 28, 2007
    1,805
    Italy
    very well done, I would have put some rubber or a cut off inner tube to separate the filter from the chassis
    we send the hose to allow people to keep the system as original as possible, plus you may wish in the future to install the much bigger one on the frame :)
    I think always in advance !!! :)
    cheers
  10. sizzlingbadger
    Jan 28, 2013
    490
    New Zealand
    I taped the frame before putting the tank back on. Some advice if anyone is going to do it this way - cut the tube about a half inch closer to the engine than I did in the pic above, my quick-connector to the fuel tank is a little harder to reach now due to the pipe being slightly shorter.
    Either that or use the tube supplied in the kit to replace it :1drink
    guglemonster and KTM 1190advR like this.
  11. guglemonster
    Aug 28, 2007
    1,805
    Italy
    ahahah :) well said
    my two cents, leave the original pipe intact, and use a portion of the provided hose to connect the filter to the airbox :) like this any kind of operation will have the proper lenght of hose from both size, allowing you also a way easier "space" to eventually change the in-line filter :)
    ps
    I had a filter change finally !!!!
    85.000 km on a 990 KTM, mounted in 2012, neck prefiltering and big in-line BOSCH straight connectors unit..... unfortunately it was done out of boredom...... not out of necessity... filter was fully functional and not clogged at all..... sorry guys, I do not have statistics to tell when to change the external fuel unit.....
    you must keep riding and than report to me I suspect......
    :D:D:D:D:D:D:D:D:D
    cheers
    Jaimoto likes this.
  12. rubber_band
    rubber_band Been here awhile
    Feb 27, 2011
    163
    Portland, Oregon
    Just want to throw out some props to @guglemonster for great service & product.
    I contacted him, outside of the site, through the email address on his website about my neck filter falling into the tank, with a pic.
    A quick response asking for the order number & address. I replied and a new filter showed up on my doorstep a few days later, no hassle or cost to me, what so ever.
    When I fished the filter out of the tank to snap a pic, it had small amount of contaminants visible in both corners. My bike has only been fueled up from commercial pumps in Oregon, Washington, BC and Victoria Island while the filter was installed.
  13. ScooterNoMore
    ScooterNoMore Been here awhile
    Nov 29, 2012
    837
    Calgary, AB CANADA
    I’ve had the same great service. Top man!
  14. sizzlingbadger
    Jan 28, 2013
    490
    New Zealand
    I had to remove the neck filter, I couldn't get the pump to fill the tank fast enough, it was taking many minutes to fill, despite having a cable tie in there to help open it up.
  15. ScooterNoMore
    Nov 29, 2012
    837
    Calgary, AB CANADA
    Ahhh, too bad. I have to go a bit slower but not much. If I can angle the nozzle towards either back corner (ie the 4 o’clock or 8 o’clock) position I usually can giver full blast.
    guglemonster and Whiteyez like this.
  16. guglemonster
    Aug 28, 2007
    1,805
    Italy
    Hi, did you position it like @Green Boy suggested? we had many positive feedbacks after the mod, also from other much more difficult bike such as the AT1000 CRF, sorry to hear that though
    cheers
  17. guglemonster
    Aug 28, 2007
    1,805
    Italy
    thank you guys
    my pleasure and duty ;)
    I am deeply sorry about this production lot, happy we fixed it for good ;)
    cheers
  18. MN rider
    MN rider Adventurer
    Mar 1, 2018
    89
    MN
    I have a question, over time will the aquastop neck filler deterorate as it's rubbing on the inside of the tank it's whole service life?
    guglemonster likes this.
  19. guglemonster
    Aug 28, 2007
    1,805
    Italy
    @MN rider
    this is not the proper place :) they will bann me one day !!!!
    please, use the vendor post to ask, or a PM or an email :)
    pst, as for not, the smooth surface of plastic tanks never gave any problems, we are using a special protective mesh for metal ones though :)
    cheers
  20. miken0vf
    miken0vf Been here awhile
    Apr 17, 2018
    330
    Broomfield, CO
    Yep, also went beemerboneyard, got 90 degree fitting to get a straighter run to external filter.
