Guglatech Revolutionary Ultra 4 Air Filters for motorcycles
Discussion in 'Vendors' started by guglemonster, Jan 28, 2018.
  1. Themastermike
    Themastermike Think you caught me in a coma Supporter
    Jan 20, 2011
    3,209
    So Ill
    Filter is installed, still putting the bike back together. Will finish up tonight.
    Filter slid right in and looks good.
    As far as hard testing..............there will be none. This is my over the road (some being gravel) machine. It will not see torturous conditions.
    Thanks for the quick ship on the filter.
    #41
    guglemonster likes this.
  2. guglemonster
    guglemonster Crivens!!! Supporter
    Aug 28, 2007
    1,710
    Italy
    werlll my friend, for some of us hard means cracking skulls for other, such as "meself", putting plenty of miles and enjoying every inches of the road :)
    keep me posted :)
    it's been a pleasure being able to put a smile under those handlebar mustaches haahaaha (cit Fabio Grandoni)
    :D:D:D:D:D:D:D
    #42
  3. guglemonster
    Aug 28, 2007
    1,710
    Italy
    #43
  4. guglemonster
    Aug 28, 2007
    1,710
    Italy
    and we're back............... but not only !!!!!!!!!!!
    https://blog.guglatech.it/en/articl...ter-the-first-wet-dry-air-filter-in-the-world
    we finished the hardest testing of our media
    let me present to you the real potential of our ULTRA4 Rally Raid
    THE FIRST AIR FILTER IN THE WORLD WET&DRY
    the special media design, allows a fantastic filtration efficiency DRY, but with a few drops of oil for "old" tech cotton filters transforms it in the most impenetrable barrier also for sand and fine dust
    this is the first Air Filter in the world that will adapt to any condition and adventure
    a few drops of oil
    the usual HARDEST FIELD TEST IN THE WORLD IN OUR HAVOC MACHINE
    and the rear of the filter to show how amazingly good it worked
    you can just see how little oil was used, but not a single particle of dirt or dust !!!!!!!!!!!
    cleaning? also WET? few drops or home grease remover, NO ALCOHOL, and back on the bike even if still humid,
    it ain't a miracle, it's WAY BETTER
    It's GUGLATECH TECHNOLOGY !!!!!!!!!!!!!!!
    #44
    eddyturn, ScooterNoMore and Bike Guy like this.
  5. MAXVERT
    MAXVERT O.G. on da O.C.
    Jan 19, 2004
    2,502
    Baja Arizona
    O.K. your products look amazing now where do I go to buy the whole suite of your products for my "18 KTM 1290 ?
    Max
    #45
  6. guglemonster
    Aug 28, 2007
    1,710
    Italy
    #46
    NextAdventre and ScooterNoMore like this.
  7. guglemonster
    Aug 28, 2007
    1,710
    Italy
    now, directly from a 10 days FULL SAND MODE trip of one of our customers
    dune crossing, column riding, full power, never stopping for any kind of servicing, NO INTAKE FILTERS OF ANY KINDS
    still thinking what AIR FILTER you SHOULD BE ALREADY MOUNTING ON YOUR BIKE??
    REALLY??
    cheers
    #47
  8. ScooterNoMore
    ScooterNoMore Been here awhile
    Nov 29, 2012
    730
    Calgary, AB CANADA
    #48
  9. guglemonster
    Aug 28, 2007
    1,710
    Italy
    #49
  10. Hammy713
    Hammy713 Adventurer
    Apr 26, 2013
    67
    Pacific Northwest, USA
    I have a foam air filter on my 2017 KTM 1290 Super Adventure R... I hate the mess, and they are hard to get clean and oiled proper or at least I have always seemed to have an issue with it. If I put the stock KTM air box back on, what type of grease are you guys using to seal the lip of the air box. I assume that is where the leaking is coming from on these boxes, correct?
    I would like to go this route of the Ultra 4 air filter.
    #50
    Yellow Pelican and guglemonster like this.
  11. guglemonster
    Aug 28, 2007
    1,710
    Italy
    from our experience and also hard lab testing the after 2015 airbox is airtight in all conditions, with the RATS (havot machine) we tested DRY and WET WITHOUT grease to check the perfect dimensioning of the filter.
    however, for fine sand application we recommend a lite "finger" greasing with simple lithium or silicone greas, if you look at the pictures, it was used both below the lid and around the frame, mostly the weak point is the bottom part, where the wedges are trying to twist the fram of the filter, UNI has a much harder and flat frame, easier to twist tha our triangular soft fhaped one.
    as for the oil, we have tested some brands, we have almost reached the final verdict, as for now, any good brand cotton or foam filter will do the trick :)
    do not use solvent, just use a nice home grease remover, no alcohol, here in Italy Chanteclair is very famouse and it's really amazing :)
    for dry use, only water will suffice :) always contrary to the air flow :)
    thank you
    cheers
    #51
  12. ScooterNoMore
    Nov 29, 2012
    730
    Calgary, AB CANADA
    I’d agree with the air tightness of the newer air box. Just opened my 2018 box after 5000km of mixed on and off-road, nothing on the intake side of the filter!!
    #52
  13. Hammy713
    Hammy713 Adventurer
    Apr 26, 2013
    67
    Cool, thanks.
    #53
  14. TheBritAbroad
    TheBritAbroad Just ride.
    May 11, 2016
    957
    Portugal / London.
    First I have seen of these new filters. Just ordered one for my 1290. Thanks for finally making them @guglemonster.
    #54
  15. guglemonster
    Aug 28, 2007
    1,710
    Italy
    while you're at it, get a fuel filte too !@!!! your KTM really needs it :)
    thank you
    cheers
    #55
  16. TheBritAbroad
    May 11, 2016
    957
    Portugal / London.
    :D No I’m alright with the normal fuel filter. So far anyway! (50;000 Kms, Europe only).
    #56
  17. guglemonster
    Aug 28, 2007
    1,710
    Italy
    #57
    ScooterNoMore and TheBritAbroad like this.
  18. TheBritAbroad
    May 11, 2016
    957
    Portugal / London.
    :hmmmmmOk. Seems like having a look at them might be a good plan.
    #58
  19. guglemonster
    Aug 28, 2007
    1,710
    Italy
    #59
    ScooterNoMore likes this.
  20. ScooterNoMore
    Nov 29, 2012
    730
    Calgary, AB CANADA
    #60
