[Guide] How To Service or Change Rollers (sliders) (X-Max 300)
Discussion in 'Battle Scooters' started by Blue&Yellow, Jul 12, 2018.
  1. Blue&Yellow
    Blue&Yellow but orange inside...
    Jan 31, 2010
    1,131
    Planet X
    Hi guys,
    I recently wanted to change to a pair of Dr Pulley rollers (sliders) on my X-Max 300, the amount of information out there on how to do this was fairly scarce so I thought I'd make a short guide while it's still fresh in my head. Maybe it will help someone. This is for the X-MAX 300 but there will obviously be similarities between a lot of scooters.
    The X-Max 300 uses six 23x18 17g rollers. The engine delivers max torque at 5750 rpm and max hp at 7250 rpm. So for max performance you want to get as close as possible to 7250 rpm during acceleration, if max performance is your goal that is. My goal was different however, I was more than happy with the original acceleration of the X-Max 300 and instead I wanted to bring the rpm down while cruising at around 60mph from around 5800 rpm to something a bit closer to 5000 rpm.
    To do this I replaced the original 17g rollers with 23g Dr Pulley sliders. This is not what Dr Pulley recommends but it was what I wanted. The engine is now much more relaxed while cruising and while in town the rpm rarely goes above 6000rpm even with full throttle. This means I'm now happy to give it more throttle more of the time, similar to short shifting.
    The driving experience is now closer to the X-Max 400 engine characteristic, it feels more like a 400-500 cc scooter now than a 300 cc scooter actually. The engine is more relaxed, but still fast. Maybe I lost 1 second or so in 0-60 time but personally I don't care, this suite my driving style better. So on with the guide then.
    Step1: Tools needed: Pulley holding tool ($12 on ebay, had to be modified slightly to open wider but otherwise good), medium size screwdriver, 8mm socket, 10mm socket, 17mm socket, 1/2 socket wrench, socket wrench extension. Recommended: 1/2 Breaker bar, small rope, towel. (An alternative to the breaker bar might be an impact wrench and then you might not need the pulley holding tool, unsure)
    Step2: Remove upper air filter cover for access (lots of screws and two bolts) (three of the lower screws are a PITA but you'll get them eventually).
    Step3: Remove lower cover for access and secure airbox with rope to get it out of the way
    Step4: Remove transmission ventilation duct for access
    Step5: Remove transmission cover (loosen all bolts and tap gently around the cover, then wiggle it straight out)
    Step6: Prepare to remove the primary sheave bolt like so. This will be a tight sucker and breaker bar is recommended. Remember to push down with your left palm on the 90 degree bend and pull up with your right hand on the handle. You want a rotating torque on the sheave bolt and little to no force up or down. (Alternatively you can use an impact wrench if you have one)
    Step7: Remove the primary sheave bolt
    Step8: Remove the primary sheave and then pinch and fold away the belt like so.
    Step9: Remove the variator unit by pinching it and pulling it out
    Step10: Take note of the orientation, it might not matter but just in case.
    Step11: Open and carefully clean all surfaces then replace rollers / sliders.
    Step12: Correct slider orientation for Dr Pulley.
    Step13: Put the cover back and then while pinching and holding the variator unit together put it back in the scooter. IMPORTANT!! Hold the unit together to prevent the sliders from falling into a strange position while putting it back. Avoid getting any kind of grease on the sheave surfaces.
    Step14: Put the belt back. I recommend putting something between the belt and the primary axle, like so. It will make it easier to get the primary sheave on.
    Step15: Put the primary sheave back on (it will only go in one way I believe) and prepare to tighten everything up again, this might be the one part of the job which requires some "feeling". According to post below the shop manual recommends 85 ft lb (115 Nm), so this is one nut you want really tight. 100-130Nm is not an uncommon recommendation for wheel nuts so that can serve as a some guide. If you don't have a torque wrench I recommend that you took note of how tight the nut was when you loosened it. I tightened the nut as hard as I could make it with my "small" socket wrench below and then a little bit more with the breaker bar. I would also recommend that you tighten the nut a little, the rotate the entire assembly a couple of turns to make the belt move out of the way and then tighten it some more. If you're nervous about this part a basic torque wrench is about $20 on ebay. (As an alternative you should be able to use an impact wrench here if you have one)
    Step 16: Everything back together, check that all looks ok, rotate it around a couple of times, no parts forgotten inside, no grease on sheave or belt etc.
    Step17: Put everything back together in the reverse order. Take note of the ABS sensor wire and also final transmission air hose, as below.
    Hope you enjoyed my little guide, personally I was very happy with the result of this modification for my driving style and my X-MAX 300 now has a more "grown up" and relaxed character, but still fast. If you want max performance probably go with 15-16g sliders, but it will be "buzzy" when touring. If you want relaxed go with 22-24g sliders. If you want somewhere in between... well you get the idea :)
  2. Tromper
    Tromper Sagaciously Annoying Supporter
    Sep 26, 2009
    1,918
    Land O Drizzle
    Nicely done. From your ability to go lighter I assume Planet X is pretty flat.
  3. Alexander B
    Alexander B Long timer
    Apr 24, 2013
    1,356
    Sweden
    Great tutorial! Very well done!
    Sidenote:
    I did however notice that it seems you from Planet X (like many Americans) have not grasped how metric fasteners are measured. The bolt you encountered was hardly an M17, but probably an M10, with the 17mm head?
    The key to all metric fastener notation is the THREAD, not the size of the required tool!
    An M10 bolt has a thread diameter of approx 10 mm. For a regular hex bolt, the tool grip is normally 17 or occasionally 16mm.
    (A bolt that fits a 10mm spanner is an M6, by the way.)
    It is extremely simple, and gets very intuitive to people with engineering training. The relevant measure is the thread, as that is the "load bearing" part. Otherwise, an "M10" would have different thread and core diameter, depending on if it had hex head, Allen key head, E fitting, Torx grip etc......
  4. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    Flat enough! But don't get me wrong, it revs out fine but it's just a little bit lazier getting there. Rather than riding the peak hp I'm mostly riding the peak torque now, which is my preference. There would be no problem pointing this thing up a mountain, maybe a little bit less responsive out of the hairpins but you'd get to the top nonetheless.
    Thanks! Aware of that, it's just a bit easier to say you use a 17 socket on the 17 bolt... not correct perhaps but it makes the tutorial a bit easier to follow. Edit: I changed the text a little. Hopefully better. If someone finds out the exact required Nm from the service manual at some point it would probably be good.
    Alexander B likes this.
  5. Strayarider
    Strayarider Been here awhile
    Apr 15, 2018
    103
    Xxx
    Thank you, thank you, thank you.
    This is without question the best and most thorough slider/roller upgrade post i've ever read. And you know what really impressed me? You even took the time to note the stock part specifications. Most people miss that and skip to what they installed. It really completes the picture.
    Love your work mate.
    :beer:thumb
  6. Strayarider
    Apr 15, 2018
    103
    Xxx
    PS... I totally concur with your logic in going for lower revs and more relaxed ride. I have mentally stored this post for future experiment as it suits my riding and my part of the world very well too.
  7. aguim
    aguim Long timer
    Dec 27, 2007
    1,045
    Northern Quebec
    That clutch setup is near identical to my Forza's , same M10 Drive pulley center bolt (17mm head), recommended torque 81 N-m (60 ft-lbf).
    I don't use any special tool, just a small 1/2"- drive electric impact gun, aligning punching
    marks traced BEFORE loosening that bolt . Here's my complete clutch tool kit (torque wrench,
    pulley holder are left looking nice, in the t-box) : 20180713_135505.jpg
    PS: I use a little wedged 1/4" wood piece as a Driven pulley separator when re-
    installing the belt. Big Driven clutch-nut socket is 1 5/8"/41mm.
    Alexander B and Blue&Yellow like this.
  8. aguim
    aguim Long timer
    Dec 27, 2007
    1,045
    Northern Quebec
    Yamaha and Honda share a lot of R&D these days, some say (but they won't tell).
    The more I look at those CVTs, the more I'm convinced they're built in the same shed.
    Same with the engines, FI setups, brakes, etc. We're buying plastics, friends.
    #8
  9. Bealo
    Bealo Adventurer
    Jul 10, 2018
    35
    Pattaya, Thailand
    Great Tutorial and Photos.
    Love your hands on approach, unfortunately i haven't got the knowhow but i've upgraded my clutch etc with a company here in Thailand called Techpulley. They asked me what was more important to my riding. Pickup, mid range or topend. I told them 1st pickup, 2nd midrange, 3rd topend.
    They recommended the following
    Clutch
    Torque spring
    Dr Pulley rollers
    Variator
    14t final gear
    Performance has been greatly improved and i can still hit 150kph (90+mph) which is more than enough and i really impressed with overtaking punch at most speeds. 32748722_954597318052573_8378436319147196416_n.jpg 32857187_953350928177212_2746930116083843072_n.jpg
    #9
    The Virginian, kpinvt and Blue&Yellow like this.
  10. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    @Bealo
    Wow that's a lot of parts/mods :D
    It looks like they also went for a mix of 15 and 16g weights? So 15.5g on average? They really must have tested this stuff if they can tell the difference between 15g and 16g and decided to go with 15.5g!
    #10
  11. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    Just a small update, I went to 20g dr pulley sliders in my x-max 300. 23g sliders was perfect for touring but a little bit too boring around town in the long run. I think my personal sweet spot is probably 20-21g dr pulley sliders. Good for touring and snappy enough around town.
    #11
    Salth2ofish and kpinvt like this.
  12. Glen e
    Glen e Been here awhile Supporter
    Aug 31, 2018
    715
    Fort lauderdale, fl
    #12
    minimac and Blue&Yellow like this.
  13. Alzero
    Alzero Been here awhile
    Jan 13, 2019
    237
    Onboard
    Are you sure your basic premise is correct? Wouldn’t you want to be at maximum torque for best acceleration and not max HP?
    #13
  14. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    Very. The purpose of the engine is to produce work (measured in energy per time unit, such as Joule/second or more commonly known as Watt). The purpose of the transmission is then to translate that work to a torque at the wheel (Nm or ft-lb), that torque vector then gets translated into a forward force vector which accelerates the mass of the vehicle down the road.
    Just think of F1 cars, they use high revs because they want to produce maximum HP. All motorsport cars try their best to ride the HP peak and not the torque peak, which is why they have such fancy gearboxes with close ratios tailored for specific tracks etc. A fun side note is also that CVT was banned in F1 cars because it was deemed too good at the time (and maybe because it lacked the motorsport drama of gear changes too).
    #14
  15. Alzero
    Jan 13, 2019
    237
    Onboard
    Sure, OK. May I point out that your scooter is not an F1 car?
    #15
  16. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    @Alzero I'm not sure if that's a serious rebuttal or if you're jesting.
    If it's a serious rebuttal well, it doesn't matter. All fossil fueled, and electric, engines are governed by the same principles regarding work, torque and rpm. Those three have a strict relationship based in math and physics. We can use F1 cars or lawn mowers as examples, it doesn't matter.
    If you're jesting well.. my scooter can identity as anything it damn well pleases as long as I get to ride it.
    #16
  17. Alzero
    Jan 13, 2019
    237
    Onboard
    If you feel that your scooters engine is similar to that of an F1 car, has similar performance requirements and is operated in a similar manner with similar expectations, then there is not much more to discuss.
    However, as far as I can see a single cylinder low compression air cooled carbureted engine has next to nothing in common with a high compression multi cylinder pneumatic valved fuel injected forced induction race motor beyond the use of gasoline as fuel. And I doubt very much if that fuel is even remotely similar, or do you think that F1 cars run on the same “gasoline” as found at the local gas station? I guess the air is still the same, so there is that.....
    But if you want your scooter to be more like an F1 car and if you think that is possible, then have at it and keep us all informed of your progress along the way. Good luck.
    #17
  18. The Virginian
    The Virginian YouTube n00b Supporter
    Apr 30, 2008
    4,438
    Spotsylvania, VA
    A really well written and documented "how to" tutorial. Outstanding!
    Eric
    #18
    Blue&Yellow likes this.
  19. Blue&Yellow
    Jan 31, 2010
    1,131
    Planet X
    All of that is a straw man argument. Your original question was this:
    Since then I've patiently been trying to explain to you that yes, we do indeed want to be at the hp peak for maximum acceleration. I'm all about education and learning. But you don't seem to want to get it.
    So here's the lay-down. You don't understand how an engine work and the relationship between hp, torque and revs. You may think that you do, but you don't.
    Watch this video: https://www.youtube.com/results?search_query=engineering+explained+horsepower+vs+torque
    Everything he says is 100% correct and it's a very good video. If you don't understand it then watch it again, and again. Then come back tomorrow and read my posts again and you will see that I've tried my best to explain all this to you. Maybe someday you can return the favor to someone else.
    #19
    Gbmike1x and MrVvrroomm like this.
  20. Moat
    Moat Been here awhile
    Dec 3, 2005
    451
    Mid-mitten
    It's pretty simple, really;
    Acceleration requires power (horsepower) - a measurement of work actually being done. I.e. - moving a weight (T = torque) over a distance (revolution, expressed as radians) in a certain amount of time (a minute, in the case of RPM's with engines);
    (RPM * T) / 5252=HP
    Where RPM is the engine speed, T is the torque, and 5,252 is radians per second.
    Torque is just a part of that equation; a measure of force being applied to something (pounds-feet, or how many pounds of force applied to a lever so many feet long). But all of the torque (force) in the world will get zero work done (no work = no power, no acceleration), if nothing (a weight) gets moved (a distance) in a certain amount of time (a minute, as in RPM's).
    Picture trying to move a huge boulder with a chunk of pipe as a lever... try as you might - pushing and pushing with all of your might (torque) - yet you can't budge it a single inch. You've applied all kinds of torque, but without moving the boulder, have accomplished no work - zero - and thus produced no power. Hence, no acceleration - no intended movement.
    (Horse)Power requires movement over time (Revolutions Per Minute, respectively) - NOT torque, alone. And the more often that movement happens per minute (higher RPM's), the more work (acceleration) is accomplished. The further the boulder gets moved.
    Double the times per minute (RPM's) that the boulder gets moved "X" distance, and you've doubled your (horse)power - and doubled the acceleration.
    As an example, an engine producing 10% less torque, but at 15% higher RPM, will produce 3.5% more horsepower (.9 x 1.15 = 1.035) - and thus more work gets done, equaling better acceleration. It may be pushing "smaller rocks" (lower torque), but it's doing it faster enough (higher RPM) to more than make up for it - i.e.; overall, more total weight of rocks gets moved in a given time (or the same weight gets moved in less time... which is the same as greater acceleration).
    Horsepower is nothing without torque, but both are nothing without speed (rate, or RPM).
    Bob
    #20
