Guzzi Nuovo Falcone
Discussion in 'Old's Cool' started by leafman60, Dec 18, 2012.
  1. leafman60
    leafman60 Long timer
    Aug 14, 2005
    3,422
  2. Redsingle
    Redsingle Been here awhile
    Jun 29, 2014
    118
    @ Leafman : Lately I've been pretty busy working on my blown Moto Guzzi 4 cilinder. Re your question about the oil seal conversion kits I produced and sold : there are pics in post nr. 1967.
    Redsingle
    leafman60 likes this.
  3. leafman60
    Aug 14, 2005
    3,422
    Thanks, good buddy.
  4. leafman60
    Aug 14, 2005
    3,422
  5. 9triton
    9triton Adventurer
    Apr 24, 2017
    54
    Melbourne, Australia
    ok thanks leafman and redsingle -
  6. Contractor
    Contractor Adventurer
    Jan 13, 2015
    97
    9triton the seal is a 14-24-7 viton seal as the viton is better at the higher temps. The 24 mm outer dimension is used with the bush removed from the crankcase cover and a retainer plate over the end of the seal/bush recess. I screwed this down using 3 fine countersink head unf screws as i couldn't find metric. (Redsingle used 3 mm metric if I remember correctly) These are set in the material around the perimeter of the old bush.
    As usual I didn't take a photo, but i might have a retainer that didnt fit quite right to show. It is important to make sure there is plenty of clearance between the retainer/screws and the nut on the crankshaft.
    It would be more elegant to fit a seeger ring or similar internal circlip, but it is machining I cant do in my w/shop.
    I cleaned up the 'quill' on the end of the crank as best I could and set the seal and retainer and put it all together and it will hold enough pressure not to trip a 10 psi/.8 bar oil switch light for about 10-12 seconds after turning off the engine.
    give me a ring if u want 043934485two
  7. Redsingle
    Jun 29, 2014
    118
    Yes, I use 3 mm countersink screws ( drillsize 2,4 mm) in my kits. No need to wory about clearance between screws and crankshaft nut : I measured 3-4 mm clearance in 2 cases.
    Redsingle
  8. 9triton
    9triton Adventurer
    Apr 24, 2017
    54
    contractor thanks - hopefully I can get busy over Christmas break
  9. leafman60
    Aug 14, 2005
    3,422
    Wait a minute, Red. 4 cylinder????? Guzzi??? I don't remember that one. Can you post some details?
  10. Redsingle
    Jun 29, 2014
    118
    This might give you some idea.
    Redsingle
  11. Redsingle
    Jun 29, 2014
    118
    This one is a couple of weeks later; I'm making progress, though not perfect yet.
    Redsingle
  12. leafman60
    Aug 14, 2005
    3,422
    Wow
    That sounds interesting. Are each pair of cylinders firing together?? Sounds sort of like that.
  13. Redsingle
    Jun 29, 2014
    118
    Engine is made of 2 V35 blocks, with an Eaton M45 blower. The 2 blocks are on 360 *. Pressurised carb is a SU HIF 4.
    Redsingle
  14. leafman60
    Aug 14, 2005
    3,422
    amazing
  15. huub
    huub Been here awhile
    May 11, 2012
    430
    slightly off topic, for german speakers,
    my le mans 2 is featured in the latest oldtimer praxis mag.
    weird to see your own bike on the front page of a magazine.....[​IMG]
    Redsingle likes this.
  16. leafman60
    Aug 14, 2005
    3,422
    Awesome, Hubert. We have a celebrity in our midst.
  17. leafman60
    Aug 14, 2005
    3,422
    Hey, I have a non-NF question based on a discussion with another friend.
    Do any of you know of a 4-cylinder two-stroke motorcycle that was ever put into production?
    My friend was under the impression that he has seen them but I think he is recalling the big 3-cylinder two-strokes from the Japanese.
    Maybe there was a race bike like that but I cannot recall a 4 cylinder 2-stroke.
  18. huub
    May 11, 2012
    430
    over here the yamaha rd500 and the suzuki rg500 spring to mind,
    not sure you ever got those....
  19. leafman60
    Aug 14, 2005
    3,422
    Yes, that was a V-4 I believe. Never imported into US.
    He was talking about a straight transverse 4 cylinder.
  20. Contractor
    Jan 13, 2015
    97
    TZ 700/750, perhaps you remember Kenny Roberts flat tracker and its subsequent banning by the cry baby H-D supported authorities.
    "I don't get paid enough to ride that"
