Guzzi Nuovo Falcone
Discussion in 'Old's Cool' started by leafman60, Dec 18, 2012.
  1. banquo
    banquo Newbie
    May 11, 2014
    569
    Macbeth Country, Scotland
    Better have a look at mine then, although it's been in there for ages... Much smaller diameter than yours though
  2. Contractor
    Contractor Been here awhile
    Jan 13, 2015
    118
    Thanks Kater,
    My friction plates are all ~2.65mm and have been assembled in a different sequence in the past as witness marks from the inner most friction plate are also on one in the middle of the pack, hence my wondering about wear . All the Friction plates are double sided.
    Yes lots of pitting/grooving of the centre hub (#2 is pronounced) from the steel discs, also different older wear marks indicating use of a thinner first friction disc (single sided?)
    I'm not having slipping problems but trying to assess the extent of wear while it is apart.
    I have a new roller bearing and inner race on order locally (not the outer race though) and Torrington thrust bearing as well. the brass/bronze thrst plate behind the hub is in excellent condition .
    I going to try to measure the spring lengths under load to see if there is any variation
    A new teflon cable was fitted less than 1000km back.
    Is there a specific way to setup the clutch pull rod adjustment? I assume just minimum clearance on the actuating arms.
    Keeping busy
  3. Skogs04
    Skogs04 Adventurer
    Oct 26, 2019
    94
    Berlin, Germany
    Out for a short ride with a couple of friends yesterday. Near the city there were tons of bikes out, but the further out we went, the less traffic there was. This is a small ferry crossing the Havel River in Ketzin, west of Berlin. We had the thing to ourselves and really enjoyed the clear cool weather and the glorious light.
  4. leafman60
    leafman60 Long timer
    Aug 14, 2005
    3,976
    This question from Pete the Diesel--
    New
    HELP!!!!!
    I have been trying to split the crankcases on my Nuovo Falcone 1972. Crank gears/clutch/flywheel/kick start/final drive gears all off and undone every fixing bolt including the one behind the oil pump. I have a good gap on the top of about 4mm and the gap tapers to about 1mm at the bottom of the engine. Try as I have for some hours, it won't separate. Any suggestions please?
    Pete the Diesel, Today at 9:16 AM Report
  5. leafman60
    Aug 14, 2005
    3,976
    That's a nice picture. I like those clouds!
    *** edit *** ...and the bikes
    ***edit 2*** ... especially that Nuovo Falcone
  6. Kater
    Kater shock-proofed shorttimer
    Jan 2, 2015
    731
    Traunviertel Austria
    Hello Pete,
    A pic will say more than Words and it would be easier to help.
    Kater
  7. MathMatt
    MathMatt n00b
    May 4, 2020
    2
    Italy
    Hello boys,
    I don't know if this is the right place to ask question, otherwise, I'm sorry for the mistake..
    I'm restoring a Nuovo Civile, White and Red from '72, and I'm in trouble with the flywheel-crank bearings I think.
    By pure chance I pulled the flywheel when I was cleaning the crankcase, so I discovered a substantial end play, in other words I can move the flywheel and the crank inside and outside the crankcase for 0.5-0.6mm [0.020-0.024"] (measured with a caliber from the edge of the flywheel), it has only axial play, I can't move the flywheel left-right or up-down.
    I searched for related topics everywhere but I had found nothing about exact tollerances.
    So the question.. Anyone know if that is the normal Falcone crank play or do I have to change the bearings?
  8. Pete the Diesel
    Pete the Diesel English old fart
    Dec 24, 2006
    16
    UK
  9. Pete the Diesel
    Dec 24, 2006
    16
    UK
  10. Kater
    Jan 2, 2015
    731
    Hi Pete,
    I think the same, the steel bushes are rusted. In this case I cut M8 thread trough 4 holes of the case and with the help of 8 M8 screws I can easily separate the two parts without any damage of it......
    Kater
  11. Pete the Diesel
    Dec 24, 2006
    16
    UK
    Ahh, that sounds like a very elegant solution! A couple of questions please Kater:
    1/ Which holes do you suggest, the long or short ones, I guess short ones?
    2/ Did you tap right through (not just in one case side) then block one side with a screw and jack from the other side?
    I will apply plenty of heat at the same time to help it move.
    Great post, thanks
    Pete
  12. Kater
    Jan 2, 2015
    731
    I searched and have found two old pics you can see the procedure. You can see the rust too.
    I cut the threads trough, screw one bolt just to the middle and with the help of the other one I separate the case. Be carefully with only little turns and avoid to twist the case. I think you should close the gap first and start with the screws where the case did not open...
    Good luck
    Kater
    65C3E446-D1BC-4912-98BE-6331BB17C4CC.jpeg F04111D3-9A62-4D85-A9F9-E91BD14C1F0A.jpeg
  13. Pete the Diesel
    Dec 24, 2006
    16
    UK
    Perfect Kater, That makes complete sense. Agreed to close back up, to make a level jacking relationship. And so we begin, as soon as I can get a long 4.7 drill, Then thread, bolts, heat, prayers, and finally (we trust) a beer for celebration!!!
    Your guidance very much appreciated.
    Pete
  14. Kater
    Jan 2, 2015
    731
    Pete,
    I did not drill the holes bigger as it is almost perfect for a M8 thread witch needs a 6,8 mm hole and cuted the thread directly several times without any problems.....
    Pete the Diesel likes this.
  15. Skogs04
    Skogs04 Adventurer
    Oct 26, 2019
    94
    Berlin, Germany
    Hey Vusette, can you please tell me what kind of relay you used in your headlight (to reduce the current flowing to the switch)? Do you have a number? I need to take care of this problem!
  16. Kater
    Jan 2, 2015
    731
  17. Mike Goldthorpe
    Mike Goldthorpe Been here awhile
    Nov 8, 2009
    205
    Auckland, NZ
  18. leafman60
    Aug 14, 2005
    3,976
    Wow, $40 for a relay.
    I use the standard Bosch type relay or variant thereof similar to what Herr Kater is showing.
    I will add that I have determined from past experience that a quality relay is best. Some of the very cheap units I've used failed in a short time.
  19. Skogs04
    Skogs04 Adventurer
    Oct 26, 2019
    94
    Berlin, Germany
    Many thanks for your help! I think I'll go with Kater's suggestion, although I'm sure the matchbox is a fine unit.
  20. Skogs04
    Skogs04 Adventurer
    Oct 26, 2019
    94
    Berlin, Germany
    Here's another question: I want to order a new switch for the lights/dimmer and horn, as mine is toast, and I'm coming up with two different part numbers (12746001 for the Militaire, and 10746050 for the Civile). All I find on the internet is the one for the Militaire, but is there really a difference? Perhaps the distance between the two screws to fasten the switch to the handlebar?
