1. eNewsletter Sign Up
H4 LED by Evitek F2 has achived the same focus as H4 halogen bulb - new 2018
Discussion in 'Vendors' started by spiderman302, Mar 6, 2018.
  1. spiderman302
    spiderman302 Recalculating
    Nov 29, 2010
    391
    Ventura County
    It is the same bulb base that is used in the ST1300 (PX43t), we just cut off the bottom two tabs off the H4 and drop it in, works just fine.
    as long as the back of the bulb gets some air it will be fine, if it is sealed in a bucket then I can not say, there are others here who have been trying it in sealed buckets and we will have to see how it works out over time. my F2's have about 30k miles on them so far....
  2. spiderman302
    Nov 29, 2010
    391
    Ventura County
    Those of you who are upgrading to leds and have older bikes or vehicles should look carefully at your head light lens. shine a flashlight across the surface of the lens. if it is plastic and cloudy or pitted. Try using a plastic polish or headlight restore kit. It will take a lot of rubbing but you could clean it up. If it does not clean up then consider getting a replacement headlight assembly. The cloudy lens will create extra glare. I replaced the headlight assembly's on my suburban and I was able to clean up my wife's vans headlights using polish. I use the polish once a month on my bikes windshield...
  3. jackbyo
    jackbyo @sunnysideup_mc
    Mar 6, 2015
    405
    Sydney
    Thanks spiderman
    Looking at these 3 pictures, do you think it will be ok? I can't see how I will get any air on the back of the bulb with that housing. Note, there is no bulb in there currently, and a small hole at the top left of the reflector housing
  4. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    4,843
    Durham, NC
    You’ll have to trim that black rubber part so that the heat sink and fan can stick out into the air. Then it’ll be fine.
    Charles.
  5. bpt
    bpt Adventurer
    Nov 29, 2015
    29
    texas
    For those in the US who've ordered directly through Evitek, how long did it take to receive them?
    Cindy originally told me about 10 days and I thought that was probably a bit on the positive side. But now it's been about a month and nothing has changed on the tracking info since "prepared for shipment" and "in transit".
    Cindy says sometimes things are slower just after the holidays (Chinese New Year).
    What's the usual transit time for the US based folks here?
  6. ChopperCharles
    Jun 7, 2006
    4,843
    Durham, NC
    Stuff I ordered from GearBest and alibaba often takes as long as 6-8 weeks to arrive. And then sometimes it takes 10 days. It’s a crapshoot with customs holding up packages on both sides, long delays before items are picked up, etc.
    Charles.
  7. bpt
    bpt Adventurer
    Nov 29, 2015
    29
    texas
    Ok, thanks ChopperCharles. Like I said, I thought 10 days seemed too quick but she offered that info without me even asking.
    I figured more along the lines of 4 weeks or so, but just began wondering if there might be a problem since she told me that and also since there's been no update with the tracking.
    I'll continue to wait patiently..........
  8. jackbyo
    Mar 6, 2015
    405
    Sydney
    My F2 bulbs arrived within 10 days buying direct from Cindy
    Unfortunately I don't see how they'll work with the dirt bike headlight setup. The black housing from my previous post is required to lock the bulb in place, but with the heatsink and fan, there isn't any space to make it work... At least not without major modifications
    In this next photo, you can see the stock H1 bulb which sits directly inside the black housing, before being twisted into place
    I'm going to use these bulbs on my 4wd. Will report back
  9. ChopperCharles
    Jun 7, 2006
    4,843
    Durham, NC
    You'd have to dremel the back open. That's a strange setup, I've never seen anything like that before. Looks like the only bulb that would work for you in that housing is the ADVMonster Native bulb. I actually have a spare, PM me if you're interested.
    Charles.
  10. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    891
    Sydney Australia
    Hi @jackbyo,
    Does the fan unit unscrew from the bulb front section?
    I've seen that on some other LED models which then might allow fitting by drilling a smaller hole in the back of your black bulb holder thing. Then reassembling the two halves of the globe. Just a thought.
    I'm interested to try these down the track So I'm hoping they work out for you.
  11. jackbyo
    Mar 6, 2015
    405
    Sydney
    Thanks Charles. I'll have a think about the dremel option... Would also require cutting the connector wires and resoldering etc, and then would leave the headlight able to receive water ingress. Too hard basket I think! Will PM you about that ADVMonster bulb...
    Good thought, but just checked and unfortunately it doesn't separate. The front bulb part actually spins around freely from the fan, with little ball bearing style detents to lock in position. Allows it to be set in any orientation regardless of the housing orientation... Very clever actually
    Perhaps it could be separated by unscrewing the tiny screws holding the fan housing on, taking off the fan, finding more screws etc... But I'm not willing to try! Unfortunately appears it's just too bulky for a tight little dirt bike application like mine
  12. 16VGTIDave
    16VGTIDave Reaver made me do it...
    Nov 4, 2012
    1,399
    Drumbo, Ontario, Canada
    The LED heat sink/fan/emitter assembly can easily be separated from the mounting plate. A slight twist to get the ball bearing out of the detent and then pull the fan and mounting plate in opposite directions.
    This may allow you to modify the stock mounting cap (what engi-nerd thought this was a good solution???) to fit the LED. Assembly would entail installing the bulb mounting plate in the headlight, then the modified mounting cap, and finally inserting the LED assembly through the cap and into the mounting plate. Connect wiring and have bright light.
    Of course, you’d have to measure every which way, look at it sideways, and ponder your options while consuming an adult beverage before proceeding...
    jackbyo likes this.
  13. spiderman302
    Nov 29, 2010
    391
    Ventura County
    In your first photo the wire is coming off the top which means the bulb is upside down. Rotate the heatsink so the wire is on the bottom and the shield is under the leds. Does the plug unsnap off the back of the holder? It looks like it might be two pieces since there is a edge/slot by your thumb and finger tips.....
    oh and looking at a previous photo it looks like you can take the holder apart.
    The back of my leds (fans) are fully exposed and gets wet without any issues...
    The fan is electronically controlled so there are no brushes to go bad.....
  14. bpt
    bpt Adventurer
    Nov 29, 2015
    29
    texas
    Delivery Update: Nearly 8 weeks later my bulbs have finally arrived. I guess they were literally on the slow boat from China. That would explain the lack of tracking info, if they've been on a ship most of the time. And they first hit the US in Houston; I wonder if some arrive on the west coast and that's how others are getting them much more quickly?
    I was a little concerned that they were just loosely wrapped in the shipping box (instead of a box inside that box) since one end of the box was slightly crushed, but they appear to have survived the journey intact.
    Thanks to those who replied and FYI to anybody ordering directly.
  15. spiderman302
    Nov 29, 2010
    391
    Ventura County
  16. ChopperCharles
    Jun 7, 2006
    4,843
    Durham, NC
    What about the E1? Any deals from US sellers? I could use a couple more...
    Charles.
  17. ERD
    ERD Custom Rider
    May 8, 2012
    616
    Dallas, Texas, USA
    I have a single E1/H4 available in a couple of weeks.
  18. spiderman302
    Nov 29, 2010
    391
    Ventura County
  19. ChopperCharles
    Jun 7, 2006
    4,843
    Durham, NC
    is there a link to order them directly from China? Through GearBest or something?
    charles.
  20. spiderman302
    Nov 29, 2010
    391
    Ventura County
