H4 LED by Evitek F2 has achived the same focus as H4 halogen bulb - new 2018
Discussion in 'Vendors' started by spiderman302, Mar 6, 2018.
  1. spiderman302
    spiderman302 Recalculating
    Nov 29, 2010
    391
    Ventura County
    This is exactly my experience. Riding with brighter, properly adjusted, LED low beam headlights, I see better and I am less affected by any "bad" oncoming glare.
    Fortunately, the reflectors in my bikes work extremely well with the F2, M2, E1 and other newer LEDs, It is good to know that there are other options for those who have bad headlight reflectors...
  2. appliance57
    appliance57 Long timer
    Dec 11, 2014
    2,603
    Boston
    Tolerable is also different from "so bad your going to die unless you're lucky".
    ChopperCharles likes this.
  3. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    4,624
    Durham, NC
    FYI not all of the lights of this style are good. Here is one I just picked up. The high beam is decent but the low isn’t great.
    Though it looks good on the gravel, it’s significantly dimmer than the Sunpie.
    BCBBC724-2B8C-4AE2-A621-14831293B9F8.jpeg 618FFD77-4C83-4C4C-A193-9D13BB3B1F4D.jpeg
    Charles.
  4. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    31,399
    The Berkeley of Arkansas
    which one is that Copper Charles?
  5. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    That’s the Denali knockoff for the SCR950. Some unknown brand I bought off of Ali express for $80. It’s about the same as the stock bulb. High beam is better than stock but low beam is similar to stock with an e1 bulb. Maybe slightly better. I prefer the sunpie, which has an excellent low beam and just-okay high beam.
    From the front it looks like the sunpie, but the projector lenses obviously aren’t as good, because the beam cutoff is not straight. That said, this cutoff does give more light to the sides of the road at night.
    From the back, this has a specially cast heat sink with bosses for attaching the bracket that fits it inside the stock SCR950 headlight bucket. Which is a carbon copy of the Denali bracket and hardware, unfortunately.
    I was looking for something that would fit and be affordable ($400+ for a headlight pains my inner KLR-ness). It’s passable but not as good as the sunpie, much less the actual Denali bulb.
    I might futz with separating a sunpie and swapping the heat sink - maybe even combining the best of the projector lenses as well. But... it’s also adequate. The stock housing even with the e1 bulb was just below adequate. This is just at adequate.
    Charles.
  6. Gruesome
    Gruesome Alter Heizer
    Apr 28, 2007
    1,501
    Chicago
    I installed the cheaper version of the Hikari H1 ($37 for a pair https://www.amazon.com/gp/product/B07PZC16SF) on my R1150GS. Both high beam and low beam fit, using replacement rubber caps/grommets (https://www.amazon.com/gp/product/B076Q9D52Z).
    Alignment of the low beam looks perfect (see picture below).
    https://advrider.com/f/attachments/img_20190825_001235-jpg.1855493/
    The high beam seems to fill in nicely right in the center above the low beam cut off line (see 3rd & 4th pic, with the bike slightly leaning to the right).
    Low beam:
    https://advrider.com/f/attachments/img_20190825_000947-jpg.1855494/
    Low&high beam:
    https://advrider.com/f/attachments/img_20190825_000954-jpg.1855496/
    The cheaper Hikari has smaller fans than the more expensive one. I was able to leave the original rear covers with wiring in place and stored them under the low beam and next to the high beam. The bulbs do not scrape the lamp holder cutout when inserting, like the Advmonster H1 R3 did.
    Edit: earlier the pics worked, now they don't...adding them one by one.
    My LED strips have turned brittle, and one of them cracked and died. I replaced both of them.
    Adding pics: Hitting 'options...' first does indeed seem to make it work in one step; thanks, Charles!
    Why this is now necessary is of course another question...
  7. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    Sharp low beam cutoff of Hikari H1 on R1150GS.
  8. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    2nd pic, low beam, bike slightly tilted:
  9. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    3rd pic, high beam on:
    Is there a new limit of one pic per post?
  10. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    Why can't one add pics to an existing post directly? A few years ago this was working. IMG_20190825_103618.jpg
  11. 250senuf
    250senuf Long timer
    Feb 17, 2008
    3,660
    Nelson area, Kootenai, BC, Canada
    "A few years ago ..." is an eternity in computerdom
  12. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    And? We should expect things to get worse and stop working, or what are you trying to say?
  13. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    I just edited a post in another thread and was able to add images. You have to click "Options".
    Charles.
  14. spiderman302
    Nov 29, 2010
    391
    Ventura County
    So there is this new blade LED bulb (B6) that is a little different than the others that look like it...
    I had made the suggestion to make the leds longer than the halogen filament.
    This is because the wire filament is 3D and the leds are 2D.
    The filament emits light off the back end which makes it effectively "optically longer".
    by making the leds longer it spreads the light wider, better lighting up the sides of the road.
    This bulb might work in those headlights that have poor patterns with leds and halogen bulbs.
    This configuration creates a very thin ribbon of light on the horizon. This reduces foreground glare and puts the light where it is needed. It makes a very good low beam and an excellent fog beam pattern.
    This bulb has the solution for the dark spot and provides a wider beam pattern.
    notice that there are six leds on each side on the low beam.
    This bulb is only 18 watts (measured) which is half as bright as the F2/M2 bulbs. But is twice as bright as the halogen bulb.
    Because the leds are spread out and being lower power it does not project as far as the F2/M2 bulbs.
    This would be a good "in between" bulb.
    In the H4 version the power is the same for High and Low beams. When you switch to Hi beam, instead of turning off the low beam the power is split between the low and high leds. This makes for a less powerful hi beam, but it does keep the light on the sides of the road. I have been using them on my bike for the last three months.
    https://www.alibaba.com/product-det...ml?spm=a2700.icbuShop.41413.10.444577b7xKlc8x
    not yet on amazon......
    Charles this bulb might work in some of those "bad" light buckets......
  15. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    Hrm interesting. Though why not use high intensity LEDs with a spread out pattern tho?
    Also any chance for an aliexpress link so I can actually order it?
    Charles.
  16. spiderman302
    Nov 29, 2010
    391
    Ventura County
    16VGTIDave likes this.
  17. Gruesome
    Apr 28, 2007
    1,501
    Chicago
    Deviating from the filament geometry that the reflector is designed for seems like a bad idea.
  18. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    Well, I had a bulb failure.
    62C5C9AF-A6BB-4C35-9233-EAF39B8E663E.jpeg 7ACEA2E8-C521-40E2-9373-884D84FB8895.jpeg 431AE73F-2CF8-4A43-B422-2E86F48C8119.jpeg
    I noticed my left bulb flickering off now and again. Pulled it and found this sad state of things. The low beam emitters are both fried and the high beam is on permanently. Even when set to low beam it’s on high. That explains why the left side looked brighter in the reflection from a car, and why the bucket ran hotter.
    The flickering is because apparently there is a short somewhere. If I jiggle the cable it goes off. So somehow the low circuit is shorted to the high. When on high beam jiggling has no effect.
    If you look at the pics, you can see a LOT of wear to the aluminum base. There were metal particles floating around inside the headlight reflector. Aluminum dust, really. Very, very fine black dust. My bike vibrates a lot, but no more than any other v-twin. Less than most, probably.
    So, it either failed because of:
    1. Metal dust shorted the LED contacts
    2. Internal wiring shorted where the cable goes into the unit, causing both low and high beam emitters to be on at the same time, ultimately resulting in the low beam emitter burning
    3. Bulb simply overheated.
    Since I’m running two bulbs in identical housings, and the other one is perfectly fine with no indication of overheating, no discoloration to the plastic around the emitters, I don’t think it’s #3. I think either the metal shavings from vibrating against the mount, or the effed up wiring did the bulb in.
    Charles.
  19. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    Note that the black metal dust was in both housings, and coated both bulbs, as both bulbs had erosion to the aluminum baseplate. The blackness you see isn’t from the magic smoke getting let out, it’s present on the good bulb as well, which was in a separate housing.
    Charles.
  20. ChopperCharles
    Jun 7, 2006
    4,624
    Durham, NC
    Hrm, took off the fan to have a look, and it appears the solder joint overheated.
    Both low beam and ground solder has flowed away from the pad. The low beam wire was just barely connected. Moving it caused it to break free. The low beam solder has flowed onto the high beam pad to make contact. That’s why the high beam was always on.
    Not sure if this is from heat or metal dust or what. But it’s pretty hosed.
    Charles.
