H4 LED by Evitek F2 has achived the same focus as H4 halogen bulb - new 2018
Discussion in 'Vendors' started by spiderman302, Mar 6, 2018.
  1. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    5,338
    Durham, NC
    Had to be something off with that particular bulb. Took apart the other one just to check, and the solder pads appear fresh and shiny and new with no damage. So it wasn’t overheating in the housing, the damage was caused by something else.
    Charles.
  2. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,412
    日本
    Just go with Morimoto Elite HID sold by The Retrofit Source. Takes more effort to install but once done you're set for years. The focus and brightness is much better than LED (which I tried in both my bikes using quality brands).
  3. 16VGTIDave
    16VGTIDave Reaver made me do it...
    Nov 4, 2012
    1,418
    Drumbo, Ontario, Canada
    @ChopperCharles That black dust you found is caused by vibration wearing aluminum away. You have a vibration problem. I’d suspect that the bulb retaining clip wasn’t holding the bulb securely enough.
    Another possibility is that you are encountering a sympathetic harmonic. That can be tougher to determine and resolve. Rubber washers, bushings, etc to isolate parts. Adding weights to change frequencies (like bar end weights do). Changing length of mounting brackets...
    Good luck!
  4. ChopperCharles
    Jun 7, 2006
    5,338
    Durham, NC
    The spring to hold the bulb in is pretty tight. I did vibrate and break the chinesium metal brackets where they were cold-bent to attach to the buckets. Welded them up and didn’t have problems after that. These were mounted to my crash bars... and the stock headlight is attached with copious amounts of rubber, come to think of it. So yeah, probably vibration killed it.
    I’ll probably use the good bulb in a different motorcycle and go with solid state LED driving lights instead. The housings I was using weren’t that great anyways.
    Charles.
    16VGTIDave likes this.
  5. BPop
    BPop Architect
    Sep 26, 2007
    93
    North of Seattle
  6. Mr_Jones
    Mr_Jones n00b
    Mar 12, 2019
    5
    Spain
    Bad news... not anymore... Cindy answered me saying that they don't produce it anymore... :(
  7. Steph82
    Steph82 Adventurer
    Feb 26, 2020
    11
    USA
    Why not? Did she specify?
  8. Mr_Jones
    Mr_Jones n00b
    Mar 12, 2019
    5
    Spain
    No, she didn't. She only said that they don't produce the B6 anymore.
    She offered me to test the F2 or the NB35
  9. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    32,207
    The Berkeley of Arkansas
    One of the original "Katana" branded LED units I ordered from Amazon failed recently in my sons truck.
  10. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,290
    Upper Midwest, US
    Did there used to be different pictures on that link that that showed projection against a wall or why do you say hemispheres?
    The picture I am seeing there now shows a road scene where the Cyclops low beam is lighting up a reflector at driver eye level in the oncoming lane and the halogen is not, so I'd call it a fail...
