    Dismiss Notice
Handle bar riser / brake line interference
Discussion in 'Japanese polycylindered adventure bikes' started by DandyDoug, Jul 1, 2020.
  1. DandyDoug
    DandyDoug Long timer Supporter
    Nov 30, 2007
    1,810
    Lewisville, Nc.
    2020 CB500X my bar risers came today, I can get enough slack on the clutch side, but there is a clamp on the front brake line that I can't get loose ??
    Any help ??
    Thanks, Doug.
    I managed to get the metal bracket that mounts to the bottom of the top of the forks off , but I'm stumped on the clamp itself that is attached to the metal bracket.
    Have not encountered a clamp like this before ??
    Any help here ??
    Got the risers mounted , the brake line length looks ok , but I'm keeping an eye on it to see if it starts to chafe . If it does I'll replace it with a longer braided steel one.
    Salth2ofish likes this.
  2. Salth2ofish
    Salth2ofish Long timer
    Nov 28, 2019
    1,216
    NC
    Hope you get that clutch line/bracket figured out.
  3. Salth2ofish
    Nov 28, 2019
    1,216
    NC
    Will be sending you a pm
  4. DandyDoug
    Nov 30, 2007
    1,810
    Lewisville, Nc.
    Man that thing was a bugger to get off, finally got it clear .
    Still dealing with a big rubber part that goes around the brake line . I can see where it has a split in it that I think I may be able to remove with a flat blade screw driver , it's not really in the way of anything. I'm just a bit fussy when it comes to cables and brake lines being free of any potential snag points.
  5. Salth2ofish
    Nov 28, 2019
    1,216
    NC
    You able to find any YouTube videos about that? Those are popular bikes. I’m gonna go look just to see your bike and what you’re dealing with.
  6. DandyDoug
    Nov 30, 2007
    1,810
    Lewisville, Nc.
    I looked around , but my computer skills are not real good and my frustration level is especially high at the moment. I think it has a lot to do with all this being quarantined stuff just wearing at me.
  7. Salth2ofish
    Nov 28, 2019
    1,216
    NC
    No your skills are fine. I found a vid of 15mm risers and one of 25 mm risers neither showed anything about cables.
    DandyDoug likes this.
  8. Cal
    Cal Long timer
    Mar 11, 2008
    3,904
    Calgary
    I just left that rubber part on the hose as it was doing no harm. It looks to me to be bonded to the hose.
    #8
    DandyDoug and Salth2ofish like this.
  9. DandyDoug
    Nov 30, 2007
    1,810
    Lewisville, Nc.
    Thank's as long as it doesn't cause any harm or get jammed up I'll just let it go.
    #9
