Harley Riders Sign In With Pic
Discussion in 'Road Warriors' started by sfarson, Nov 13, 2004.
  1. Trackjunkie21
    Trackjunkie21 Been here awhile
    Nov 20, 2018
    482
    Staten Island, NY
    34,000 miles
    Shooter1 likes this.
  2. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    17,133
    the hills
    That's about right. I recommend customers take a look at 30K. As well as upgrade to the '07+ tensioners.
    Richy likes this.
  3. trumpet
    trumpet Group W Bench
    Aug 2, 2008
    5,069
    Connecticut
    What are you seeing for '07 and up tensioner longevity?
  4. anotherguy
    Jun 18, 2009
    17,133
    the hills
    Haven't seen any wear out yet. 90K miles is what comes to mind as far as high mileage. Worst I've seen is a couple pop up and lodge crooked w/big lift (.600"+) cams. After seeing that twice I install Zippers upgraded tensioners with hot rods.
    Richy, Shooter1, Kevm and 1 other person like this.
  5. Diogenes415
    Diogenes415 Zoinks
    Mar 16, 2016
    86
    Kentucky for now
    From the last trip I took a few weeks ago through New Mexico on my '98 Sporty. It was also a shakedown of the 6 gal flat side fat bobs I installed... almost 300 mile range before having to stop now. PP_NewMexico.png
    rauchman, alpina, ebbanflood and 10 others like this.
  6. Shooter1
    Shooter1 Long timer
    May 10, 2004
    1,035
    Kansas
    My local dealers lead mechanic said he's see the old style tensioners wear out in 6K miles and last up to 45+K. He said the touring bikes -usually- last longer than the Dyna's as the FXD's are typically ridden harder. I don't know if it's true but I have read some reports that every time you open the throttle very hard, (like in a drag race environment) the chain actually pulses into the tensioners a bit harder accelerating wear.
    When I bought my '00 FXDX back in 2010 I had the dealer install the SE hydraulic cam plate/oil pump as I didn't want to have to open the cam chest up for some time. I should have put a set of cams in at that time but didn't. I may have cams installed over the winter and get a chance to look at the hydraulic tensioners and see how they look with about 30K on them. HP 2021 FXDX 2.jpeg
    rauchman, rs42sport, Scoozi and 7 others like this.
  7. SportsterTom
    SportsterTom Been here awhile
    Apr 13, 2016
    379
    Chicagoland
    Been drag racing the FXDX?.....How'd you do?
  8. ZCarFan2
    ZCarFan2 Been here awhile
    Mar 19, 2014
    924
    NW Georgia
    Got a 2004 Road King Custom project. No pics of my own yet but dealer photo attached.
    The ECM is gone , apparently harvested for parts to get something running. Am I going to have problems popping a used one from ebay in there? Power Commander III still attached.
  9. Richy
    Richy Long timer
    Sep 9, 2005
    3,509
    Deadbury FL
    9D51D2FB-64F1-4EE9-B0B0-F0F6243CA169.jpeg Out doing my civic duty- killing love bugs, when I felt the wallowing, then the vibration.
    It was shady across the street
    I was only 13-14 miles from home, and just happened to have my trailer hooked up, so my wife rescued me. I have AMA towing but knew this would be faster.
    I had a plug kit in my bag, but…
    rauchman, ag_streak, alpina and 4 others like this.
  10. phideaux
    phideaux Long timer Super Supporter
    Feb 4, 2008
    4,213
    NW Georgia
  11. Trackjunkie21
    Nov 20, 2018
    482
    Staten Island, NY
    I'll definitely be upgrading the cam plate come next time I tear a part the chest for a cam install. Being the bike is Magneti Marelli, I didn't want to mess with an expensive tuner. It'll be getting either a CV or a HSR42 when I finally drop some coin on a TwinTec ignition.
  12. Shooter1
    Shooter1 Long timer
    May 10, 2004
    1,035
    Kansas
    I made 10 passes with a best time of a blistering 13.703 at 96.33 mph. :lol3 The bike is basically at a stage 1, stock muffs with the baffle plates knocked out, SE a/c with a K&N filter and re-jetted carb. The bike runs well for what it is. As I've grown older, I've learned it's more fun to ride a slow bike fast, (or as fast as it will go), then it is to ride a fast bike slow. :D (7) GH010064 Heartland Park Topeka 7.2.21 FXDX test 1 - YouTube
    rauchman, Scoozi, ag_streak and 9 others like this.
  13. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    16,998
    Orange County, CA
    mikuni carb conversion?
    Daniii likes this.
  14. SportsterTom
    Apr 13, 2016
    379
    Chicagoland
    Good for You!! The bike did good for stockish. I loved the vid. Did you ever get your Hot Rod FXRS-SP to the track?
  15. Shooter1
    Shooter1 Long timer
    May 10, 2004
    1,035
    Kansas
    I did get the -Sp to the track a couple times back in the early '90's. The best time was 13.19 @ 102.44 mph. That bike had a cam, HS-40, Kerker pipe and an ignition on it and I'm sure could have done better but my reaction times were much slower back then. Even though I'm on a slower bike now, my technique, (what little there is), is a little better thus helping the slower bike out.
    The FXR was at redline in 5th when going thru the lights which is perfect for the 1/4 mile. The big pig DX was at redline in 4th gear meaning it was over-geared for the 1/4 mile. If the gearing was a bit lower and I had an equivalent tune on the DX, I think I could have bested the FXR by a hair. Below is a pic of me representing with the FXR :lol3 with some chopper guy at KCIR back in '93.
    rauchman, DirtyRoadie, alpina and 5 others like this.
  16. CarlWheezer
    CarlWheezer It's a trick...get an axe
    Jan 24, 2008
    400
    Kansas City
    Ah...KCIR. I miss that place. Had some good times there.
  17. Shooter1
    Shooter1 Long timer
    May 10, 2004
    1,035
    Kansas
    Yeah me too. I raced there at the All Harley Drags in '92 and '93 and had a blast. I remember some guy was riding a chopper with a big inch shovel with a stretched and raked frame and would do a wheelie 1/8 mile down the track. I kept waiting for it to break in half when he landed the front end but it never did. He was the hit of the show. (Pic below as example, not the real guy).
    alpina, Philthy64 and LongW like this.
  18. Daniii
    Daniii geezer
    Sep 29, 2005
    41,228
    Plano Tx
    I remember the 1550 CC V-Rod "BadRod" doing an 8.3 at KCIR back in about 2005 or so, no wheelie bar, and then going on a 100 mile ride on that bike with the VRod Forum group. I believe he blew up the motor a few weeks later, though :bluduh
  19. ZCarFan2
    Mar 19, 2014
    924
    NW Georgia
    vs. a $175 computer on ebay? Sounds like more work.
    Kevm likes this.
  20. villageidiot
    Apr 29, 2010
    16,998
    Orange County, CA
    yeah, possibly.
    didn’t realize ECM’s were that inexpensive
