Harrys R S/2 Conversion Build
Discussion in 'Airheads' started by black knight, Nov 1, 2020.
  1. black knight
    black knight Long timer Supporter
    Dec 2, 2009
    1,028
    thumb_IMG_8030_1024.jpg thumb_IMG_8029_1024.jpg thumb_IMG_8028_1024.jpg thumb_IMG_8027_1024.jpg ~
    Taking Great Note, From Ados 's sweet /2's , yep on 3 that I've seen from him, I took to heart having a lockable Aux. Tool Box as a good thing. Showing his 2/3. ados vergison
    So I looked on fleesebay and finally found what I hoped would be a good acceptable candidate . It came w/o a lock and those are easy to find. - - - - Be sure that the lock is a ' DUST PROOF ' type . Add graphite to the cylinder for ease of operation. It was still many hours yesterday to adjust the cam lock bar so that it fit snugly. No bolt -on easy task, lots of fabrication -+- materials & shop time ~ ~ ~ ~ ~ ~ ~ ~ > Make Extra Keys !
    Some were $200- 400.oo range for original to specific bikes. Well that won't do @ all. I didn't pay near that for mine. I'm going to weld holes, attach anchor plates, seal it and when close to paint, seam seal the interior and body putty the exterior for looks & fabricate a back bracket. . . . . . . .
    Then paint & Pin stripe it at the correct time, long after I've handled it over & over.
    So here is the preliminary work and basic fitting. Since I don't have my Frame ... [ it's @ a shop getting checked over for trueness ]. ... I'll have to wait until it and the hybrid swing arm is back & fitted, before this work can complete.
    Yes, some may notice that the lock is down, it fits the frame better this way. Mostly found on Brit bikes, these aux. boxes are handy & useful. Depending on the aux. tool box you find , like Ados' the lock is up. There are ways to make sure all tools won't just dump to the ground when opened. It will be held to the frame by 3 round coupler nuts, which will be frame drilled / inserted/ welded in situ to the right side LooP . I have plans to add almost 16-20 coupler nuts for all that I will attach to this R50SS~80/2C machine . - - - see yellow tape on frame.
    tool box :2  .jpg thumb_IMG_6950_1024.jpg thumb_IMG_6951_1024.jpg thumb_IMG_6952_1024.jpg thumb_IMG_6953_1024.jpg thumb_IMG_8022_1024.jpg thumb_IMG_8023_1024.jpg thumb_IMG_8024_1024.jpg thumb_IMG_8025_1024.jpg thumb_IMG_8026_1024.jpg
  2. black knight
    Dec 2, 2009
    1,028
  3. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,338
    Fort Collins, CO
    If you are going to use the stock handlebar clamps, I wouldn't put the cross bar on. Mind you, the cross bar does give a good place to mount things.
    18415 likes this.
  4. black knight
    Dec 2, 2009
    1,028
    thumb_IMG_5084_1024.jpg thumb_IMG_5281_1024.jpg thumb_IMG_5282_1024.jpg thumb_IMG_5283_1024 2.jpg
    does this answer your statement . this is 1 / 10 special top plates made some 12-15yrs ago. this is the last uno. I have also made my own top plate cap screws.
    Pokie likes this.
  5. black knight
    Dec 2, 2009
    1,028
    16 11 4 080 165
    Gas Tank Tool Box Threaded Lock – SCREW
    $10.52…
    16 11 4 080 172
    SQUARE Lock Thumb - WRENCH
    $14.08
    Tool box key
    square  toolbox key  1  .jpg square  toolbox lock  1 .jpg thumb_IMG_6972_1024.jpg thumb_IMG_6975_1024.jpg
  6. black knight
    Dec 2, 2009
    1,028
    NOW ! ! ! ! ! !
    That My R50SS Frame is back home from the frame doktor & the Earles fork, getting a straightening check up, I am so ready to get started on her.
    I have this idea in the back of my mind ever since I started this build that the frame is Soft thin metal. She Sure IS ! ! !
    drilling a hole to ap a thread leaves one to wonder ~ This just AIN'T going to hold work shit 3months 3 yrs, 30 years from now. SO !! ! ! ! My ideas was using Coupler nuts. Belmetric makes the round type which is perfect .
    Buy the quantity an size needed
    b4 welding a blind hole - - - - - vs. a drill thru frame. you'll need to close off the end that's inside the frame. you DON'T want any water going inside the frame. I use a BB or a steel ball bearing that gets based to the end.
    Buy a precise # drill undersized and - Drill a hole. Clean the area that gets drilled. Remove the zinc plating off the coupler nut. Drill . . . . . . . . Hand [ rat tail ] file or ream it so that the inserted coupler nut is a tight fit. add a drop of weld then braze the rest. Clean the threads so they are clean.
    Now you have a point of attachment you never had before. In some cases , I'll only drill thru one side of the frame.
    In other cases , I'll drill thru the frame and have 2 points of attachment.
    I have planned 17-22 coupler nuts for my build.
    sizes 4mm , 5mm , 6mm , 8mm
    6 = fairing .
    3 = aux tool box .
    2 - 4 = Craven Luggage .
    4 = aux electrical offset panel .
    1 = ground .
    2 = seat shock base .
    2 = handle bars .
    Once the frame is blasted then painted or powder coated you really won't see these things at all.
    As for the fairing where the whole ideas came to be was ' HOW do I attach the fairing to the frame with OUT those ugly U brackets and vinyl tape bull shit.
    will the purists like me, I DGAS - I DGAF
    A2F25A66-99CE-4D33-82CF-1843DE22A81E_1_105_c.jpeg EE4080FA-F70B-40F6-BC1C-724D313F504B_1_105_c.jpeg E8F5A89A-BAD0-496D-8EFA-B349A846B54E_1_105_c.jpeg E0664C44-A5D0-425D-A9AE-C8BBBF60DC78_1_105_c.jpeg C4B5FB1A-F6E7-4654-848B-D2B986CDCE10_1_105_c.jpeg 11800271-3ED9-44B1-902C-013E568636B7_1_105_c.jpeg 0535067C-B094-4F83-AA9A-DD8443236446_1_105_c.jpeg 3000246C-F4CC-4BA6-9BA3-BEAAB859C5D9_1_105_c.jpeg 3960ABB9-FBA4-49F5-BB0E-AC1DA3662648_1_105_c.jpeg CB663ED4-9F6D-4FD4-B25D-EB435AF51C55_1_105_c.jpeg 2B6B66CA-2128-44B8-9221-18AB2B0548A9_1_105_c.jpeg 03C84059-C117-4106-BAB0-708DA9974A1F_1_105_c.jpeg 4EDEBF76-DEA6-449B-ADDF-164137935DE7_1_105_c.jpeg 6EDD1B48-F77C-413B-80CF-DE96BCB7A568_1_105_c.jpeg 7A54A127-1E53-4506-9CD6-75E16195C378_1_105_c.jpeg 8DCCF3C8-C050-4642-AB59-7BEEAA47E007_1_105_c.jpeg 8F1946FB-6E7B-466D-9F77-16225072822F_1_105_c.jpeg 09F85D76-3809-4111-97D2-7C0D802D4E9B_1_105_c.jpeg 18E840D8-02E2-4DEE-998A-CDFA67EF18D8_1_105_c.jpeg 200BD5FF-22B6-4D79-B566-394391016C59_1_105_c.jpeg 248CF13E-16A8-4914-8555-8508E2376785_1_105_c.jpeg
    I'm just gettin started .......... more later
  7. black knight
    Dec 2, 2009
    1,028
    Now moving along . . . . . . .
    the new Dual - 11.8" HD Rotors already mounted to the wheel ... waiting for a 'mock-up to apply to and with NissiN / Honda 2 pot calipers and my spare /6 19" wheel .
    I usually ' Pattern Make ' all brackets so this is another example of mark MK #, 5, 7 or 8
    3/16" strap - this is specifically made long so as to get welded past the AXLE piece not just the swing arm - arm.
    I sure don't want any failures there.
    4D6DDAEB-08CE-44DB-A58A-F8E4868041BE_1_105_c.jpeg 4B1E03B3-644B-41DB-8924-AC66FFE7F3C3_1_105_c.jpeg 1F917223-A4C9-4C18-AD94-5003380223BC_1_105_c.jpeg 2E1E37B4-5540-404A-B3E7-73E210855873_1_105_c.jpeg 437CBC66-2674-47F6-B026-6CBE4B8E43F4_1_105_c.jpeg 735A896E-F6BA-43E4-90D4-8636D916CD05_1_105_c.jpeg 049186EA-F594-48A1-A7F0-B31501959ADD_1_105_c.jpeg 57252A2E-F646-4F57-A8B7-42107D0595C4_1_105_c.jpeg B583DC8B-0102-4BA9-BCBF-9A1B66C5E476_1_105_c.jpeg D3914DCA-2B4A-401D-8954-0738117E4F99_1_105_c.jpeg E8A9B7F3-F2C6-46B8-8022-9016FD17AE57_1_105_c.jpeg E42CC96D-F6BA-4486-82D6-F5D75EA18EF6_1_105_c.jpeg EBDEC4B5-3FE5-4228-84C9-AE809D00D0DC_1_105_c.jpeg F937D7DC-82CB-4CC2-AA17-A82352189B08_1_105_c.jpeg FAD41D7C-8010-4E5D-A8B0-4B2D64AF827F_1_105_c.jpeg
  8. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    It's your bike, to do as you please. DGAFF for those that disagree!
  9. Arktasian
    Arktasian Feelin the BMEP
    May 23, 2014
    2,278
    BC
    That cat seems to be going over your numbers, not sure it agrees with the changes.
    black knight likes this.
  10. black knight
    Dec 2, 2009
    1,028
    0A4D8D69-F809-47ED-AF65-D7C7BCCC97FE_1_105_c.jpeg 0D491B0A-E2DA-433B-A1B1-7F3C9C5DBEC7_1_105_c.jpeg 1D9C1411-2E52-4A14-9AAA-7422E2F5A9B6_1_105_c.jpeg 1DED1B2B-9394-4135-BB7E-264D20082525_1_105_c.jpeg 03DB2D6A-E3BC-4F05-8778-AFBFF36ED2BE_1_105_c.jpeg 06DD80CB-D839-49AD-937B-3F43A6C5FEE2_1_105_c.jpeg 7A3CD5BA-48D1-447C-9AD8-90661260C58D_1_105_c.jpeg 8A697F6E-E545-4A98-A993-D160E223EB99_1_105_c.jpeg 9BF8A78D-8A38-4C96-9F08-A4465B6FEB36_1_105_c.jpeg 29D852B4-4866-411C-92DC-980861FE888D_1_105_c.jpeg 76C34D57-4E1B-4F25-8B6F-8A1758022186_1_105_c.jpeg 78BE399F-2148-493F-8B62-C912D7E87EA9_1_105_c.jpeg 83D0B654-520F-423B-AB67-F5E9428A0564_1_105_c.jpeg 311DCA33-773C-4BFA-9539-D58C20BE0FEA_1_105_c.jpeg 984E8287-EBBE-4139-9DF5-FE171D531C86_1_105_c.jpeg BBAC789B-41B8-4093-86E1-65F283DC2FC2_1_105_c.jpeg CDC99C4F-7C69-4E90-A8FE-B1D6DBE6FF3B_1_105_c.jpeg CDD01B70-26A3-4A15-84A1-8BA600AB3C43_1_105_c.jpeg F3C68575-11CE-4099-AFA6-CD54E7114AD7_1_105_c.jpeg
    :ksteve:p3rry:jump
    It is ABSOLUTELY ESSENTIAL That the bracket extends forward and gets WELDED to the front axle Earles fitting so there are no Earles Fork Weld Failures
    :clap:clap:drif
    Almost read to get the axle spacers made and turn down the axle as needed . make 4 more round spacers to weld to the 2 brackets to space the caliper correctly & squarely centered .
  11. black knight
    Dec 2, 2009
    1,028
    FF372449-BF09-45E4-84DD-194FE0D344CD_1_105_c.jpeg 53768416-4405-4065-B984-60FF98FA9B76_1_105_c.jpeg :ksteve:p3rry:jump
    :ksteve:p3rry:jump
    05B22381-2976-4236-B0F4-EDE7C8753515_1_105_c.jpeg 6B305477-E2A6-47DD-AD05-BEA4B2136A87_1_105_c.jpeg 53768416-4405-4065-B984-60FF98FA9B76_1_105_c.jpeg A87AFB6A-4C49-4DE4-B710-93BF3E4E5699_1_105_c.jpeg
    rat tail file a GROOVE into the bracket to fit the Earles weld
  12. black knight
    Dec 2, 2009
    1,028
    00C40549-7533-41BB-BC07-93189FBF196B_1_105_c.jpeg HYBRID Swing Arm Welding & Drive shaft
    2C5EC686-ECF2-4C1B-80C1-E799B0719F74_1_105_c.jpeg 2FCEC623-C9C2-4BAA-B993-13A673D88656_1_105_c.jpeg 3A4B51C8-0037-49A1-BE25-088C09E879E2_1_105_c.jpeg 3C60D536-3BE3-43F5-91F2-A9194709E527_1_105_c.jpeg 5FB6C2CF-4B08-44F5-815A-2EB5E11DD290_1_105_c.jpeg 06E9C880-B2BA-427D-8C1C-38AA2FA29A0B_1_105_c.jpeg
    8D144E09-5B24-4102-A785-CF586DCEC072_1_105_c.jpeg 8F206AA5-57A3-43AA-BB38-197923ED08E0_1_105_c.jpeg 9B91D88D-5A2F-4EAC-9E04-338C77202FBF_1_105_c.jpeg 9BFE47CB-2734-4847-BACE-EE3D50FA1BB2_1_105_c.jpeg
  13. black knight
    Dec 2, 2009
    1,028
    All welded on a super Jig ....
    77F1EB5A-59D3-4FDC-BC7D-332629CFC1BC_1_105_c.jpeg 343BDECD-FECE-4E45-B193-AB6C0A8EEB6A_1_105_c.jpeg 359A7EA4-5D2D-4031-842D-19927736F6DA_1_105_c.jpeg 437D626C-71F2-4CA3-B3C6-E3E848FDA7AB_1_105_c.jpeg 619B19A1-E703-44B0-824F-3011EFC2E22D_1_105_c.jpeg 674C6CB1-0D33-48A0-BBC4-81701554B064_1_105_c.jpeg 815F92EB-CEBC-4D97-84A7-F69ECC70A1FC_1_105_c.jpeg
    A Jig was used to align the old style swing arm to the grafted later style FD piece. making sure all was aligned perfectly and has the correct length. welders know that there is movement during welding in the heated area vs. that which hasn't been heated. Since this takes multiple passes from different angles and the jig needs re-positioning our the welding, cooling start in.
    because it's held in the JIG the tendency for change is minimized greatly.
    930DD82D-052C-4D42-940E-CBAE2F4E4ED7_1_105_c.jpeg 5130E938-7C61-4697-B024-70CFECB3F0EC_1_105_c.jpeg 9311A832-6DB2-433C-BD90-F165BAEE7A22_1_105_c.jpeg 34192E68-D72A-484C-A6B3-8656D240DC96_1_105_c.jpeg 856146B6-A5C8-4224-B5F0-043B18C2C209_1_105_c.jpeg 935335AC-8722-4A69-BC43-6ED0A239CBF5_1_105_c.jpeg 7363709B-A014-41B2-B380-7D09D0B3A5F4_1_105_c.jpeg A3ED086A-788B-40E2-9C04-A0A835354485_1_105_c.jpeg AD36D3E9-1558-4531-BD5D-930EAB3FBDAA_1_105_c.jpeg B3BFF91E-35B5-4CB4-8379-702477067BAC_1_105_c.jpeg BAD41050-8C21-4374-B3E6-61515DE4DDC0_1_105_c.jpeg D38BF391-0CBC-4BE1-A93A-254FBE2FAFDD_1_105_c.jpeg D207F1B6-32F9-4AE2-9545-346438CEC9D4_1_105_c.jpeg
  14. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Looks good! Keeping the rear axle and rear drive in the right place and square is the biggest problem.
  15. black knight
    Dec 2, 2009
    1,028
    3F743CD2-7BEA-4FE4-B572-B7A1941D5DA8_1_105_c.jpeg 4C2B80D7-730B-4258-BCAB-01CFB03C112A.jpeg 4E57A4A2-E4E9-4E06-B357-191E1641DEB5.jpeg 5B1496E4-F317-4396-A670-ED2BB88CB1FA.jpeg 06BC5844-8CE6-4A84-9A29-D5D12D21FF07_1_105_c.jpeg 9E3075D6-BEFD-473E-9F12-59A2F542E2A2.jpeg
    020E26CC-F04C-4E5D-877E-A930E7F45B6D_1_105_c.jpeg 60C029A5-5805-47B3-8CB3-0470C234C5D9_1_105_c.jpeg 725E3E3C-A2DD-405D-B39E-742E0A6EF004.jpeg 444066EF-1D08-4DBA-B725-25E0F93ADF51_1_105_c.jpeg 1333887F-C051-4164-ADBA-07239F583CD5.jpeg AABF60C3-0E32-4314-877C-D66FD8924E08_1_105_c.jpeg DEA6C484-996C-4AFF-ABBD-3EF9DFBAB7D8_1_105_c.jpeg
  16. Arktasian
    May 23, 2014
    2,278
    BC
    “Super Jig” - are you referring to the swing arm fabricating, or positioning of the U Joint caps for spot welding?
  17. black knight
    Dec 2, 2009
    1,028
    read above .....
    1F06EA4A-FC7A-4B96-86AB-AF6EE153DE5D_1_105_c.jpeg 2A7B472B-809E-4D96-88BC-2A17C983F608_1_105_c.jpeg 2B1B6B9E-AA1B-4268-9B1C-1F9122F3A67C_1_105_c.jpeg 2E1E918A-ECFB-43BF-9789-5E217F22BEC1_1_105_c.jpeg 3D075DC5-776B-4660-BEA2-DF3A4583B7B5_1_105_c.jpeg 8C7E65CD-45C2-42E7-B415-0CCF63638B53_1_105_c.jpeg 14D32D21-E2FD-4144-A251-2FF9B56383E9_1_105_c.jpeg 20B5BEE2-CE45-43B1-B72C-3CAF2C74F0D2_1_105_c.jpeg
    24DF7C21-6300-418D-A206-63964FD2FD93_1_105_c.jpeg 41EDA879-DC66-48AB-A87A-19481B696812_1_105_c.jpeg 46CAC37F-ACA9-48C3-8661-7F8DD66A99A6_1_105_c.jpeg 57F5DBCA-A8FA-4FBA-891D-961B21B86470_1_105_c.jpeg
    069D54E5-9CC6-4B6E-A085-163E271FA881_1_105_c.jpeg 219BAC28-19BC-4309-8029-51A08C8B9971_1_105_c.jpeg 625CEFCC-0FDC-423C-89CE-D65247683A25_1_105_c.jpeg 0748D0AB-C209-4D9B-8F45-6D680A5C206E_1_105_c.jpeg
    8338E301-7375-4ED0-9FF6-AA002794735C_1_105_c.jpeg B128F802-4824-4097-8395-12CB5B7D6591_1_105_c.jpeg
    E09CB508-9A3E-4DF0-8319-5692E4448C3D_1_105_c.jpeg EB5D9B98-4E86-4AAB-977B-AEB055168F86_1_105_c.jpeg
  18. black knight
    Dec 2, 2009
    1,028
    sometimes it just takes a revision. so back to my design drafting board in the shop. I went thru 15 versions of what ,ay be best for my needs.
    this is ................ MK #12 It really is important to have the bracket extend forward to weld to the Earles circle weld front attachment when attaching disc brakes to an old bike. it's added safety .
    When all is buttoned tight I will SS safety wire the 4 bolts to the F~4 brakes @ the tiny hole.
    1CCF8EC3-7E4B-4600-A132-D40C7B6E2C4F_1_105_c.jpeg 3DFD62DB-0DD5-4DB1-B801-0EA6EE618467_1_105_c.jpeg 6D82C5C1-BDBD-46C1-B374-1B6D87F6475B_1_105_c.jpeg 7E9A89FC-8D8E-4F7D-A5B7-D4703E924B04_1_105_c.jpeg 8A0F7BAE-2A22-424B-AA78-CE4A815662A2_1_105_c.jpeg 25F474A5-1678-47D4-AE76-D22A0A0DE82D_1_105_c.jpeg 47BE63C0-DE9D-46BE-BD8C-8CF683E18E52_1_105_c.jpeg 49E3F7AE-3A69-43DF-8D4B-DF62EF920F9C_1_105_c.jpeg 56B43BBF-D511-4881-912E-21E31A0A8CB6_1_105_c.jpeg 083A2DB4-4962-4BD5-9A2B-94C86F0294D6_1_105_c.jpeg 151FF9DB-0775-4904-8C26-6F516C3485AC_1_105_c.jpeg 700E022C-C714-4DEE-BAE3-94D9C0D2282E_1_105_c.jpeg 880A2252-952E-4418-A107-D7B7CAAEC166_1_105_c.jpeg 2048C336-7A36-48F8-9FC6-B57210A0A254_1_105_c.jpeg 4677A5EF-B7AD-4E17-9438-E569992FEE90_1_105_c.jpeg
  19. black knight
    Dec 2, 2009
    1,028
    0EF27DC1-9817-4228-8E1E-256565276B57_1_105_c.jpeg 3BC502E3-034B-4A58-91C5-D0E9A65B95B1_1_105_c.jpeg 11FD3028-3FF4-4413-888D-DC80E85B392C_1_105_c.jpeg
    33E4D316-7294-41BE-BC20-D6479A7ECE79_1_105_c.jpeg 462BA672-B230-4D80-8FDE-AEFAF2D7307B_1_105_c.jpeg 5237C6F0-7FA4-4184-90E1-AA95650E4309_1_105_c.jpeg 8422CE39-F3F7-4193-902F-44BDFEFCBD40_1_105_c.jpeg
    9987281F-9D2B-46A9-98C1-E6EB8108709D_1_105_c.jpeg A4A19E0A-5A27-435C-A1B8-91EC455C50EA_1_105_c.jpeg A64F04A8-30B9-4A10-822E-8CE2DE7262DC_1_105_c.jpeg B325ED11-E340-4711-91A4-64918636F572_1_105_c.jpeg
    EF85295E-C643-4A55-B702-426132F63A9D_1_105_c.jpeg F868114B-FC56-4E3C-8CB5-E0A22D3E9EDB_1_105_c.jpeg
    Scott in Missouri likes this.
  20. black knight
    Dec 2, 2009
    1,028
    Making a perpendicular twisty to a parallel twisty.
    thumb_IMG_8305_1024.jpg thumb_IMG_8306_1024.jpg thumb_IMG_8308_1024.jpg 5D54E914-A8B6-49AD-8972-0492A0FEEB55_1_105_c.jpeg 7DD06451-25FF-44BE-9DBF-07734F558078_1_105_c.jpeg 8D11250E-4CA6-4408-84C3-DADA5DA4CAAB_1_105_c.jpeg 31CC9E0B-F5F6-4B39-9280-5059271AE089_1_105_c.jpeg 43F904E2-2E99-48A5-8728-8968D0BCD1CE_1_105_c.jpeg 55A62AF0-A4CC-4FFD-A1F6-05CFFB1253BB_1_105_c.jpeg A2BDEC0D-4CEC-4A98-866A-D72EFFC14929_1_105_c.jpeg DC1D25F5-A6B7-4AFE-8DBE-971CC60A83CF_1_105_c.jpeg F9FC5D43-514C-45D5-A09D-9EC9E9D72666_1_105_c.jpeg
