Harrys R S/2 Conversion Build
Discussion in 'Airheads' started by black knight, Nov 1, 2020.
  1. dondesmo
    dondesmo Senior Squid
    Apr 29, 2011
    414
    Fed Way PNW
    I admire your design and fabrication skills. Well done.
    black knight likes this.
  2. black knight
    black knight Long timer Supporter
    Dec 2, 2009
    1,028
    E1880239-4785-4424-B08A-827497E5B2D2_1_105_c.jpeg Modifying the frame Gas Tank Mount to give room to do work, maintenance , repairs, starter removal, engine install. Belmetric sell Hex & Round long coupler Nuts. a 40mm cut down to 35/36 should fit snugly , get welded in place after the 2 holes are drilled. The bracket you just cut off will be reused and 2 more m6 holes drilled. this bracket then its bent about 5/8" - - - 3/4" down from the top, as the whole bracket then gets a slight tabs bent to fit right back over top of the now 2 ears w/ the welded coupler. This is your new shortened gas tank mount, Completely removable for ease, ALL the while still used as a support bracket.
    more pics later, i'm waiting for my hex m6x40 coupler nut to arrive, then gets welded in situ.
    Done the Easy Way.
    06F5EC84-899F-497B-948A-FCCC8B510E7D_1_201_a.jpeg 05B14C2F-9A25-45A6-B77F-E13AE9917994_1_105_c.jpeg 13E351E2-66A7-4ACC-A547-CEE8F0120402.jpeg C7FF63A2-9820-48AE-BA25-80F5E8FD85D2.jpeg F80AC310-CA63-4A6D-B4E5-E2F68D06DB0B.jpeg
    5CB9E34A-A24A-4590-914B-0CD034E80A6F_1_105_c.jpeg 6B19709F-A6A0-49E8-A75B-1CC6B8957D68_1_105_c.jpeg 7FC04BE1-7B5E-48CF-BF13-38222430A075_1_105_c.jpeg 7FEB52D0-8EE2-4F42-A01A-E6E44A5BA3CA_1_105_c.jpeg 015FD78B-A788-4545-94FC-E6845B56AE44_1_105_c.jpeg 68B75946-A6A6-4467-8F78-9F69896A988C_1_105_c.jpeg D4094840-B6F9-452B-BEC7-26FEF1A6AF19.jpeg E5E6D9FC-4B4A-4F2E-A335-590B9D8C11F8_1_105_c.jpeg
    Done the Easy Way.
  3. black knight
    Dec 2, 2009
    1,028
    ADDING more anchor points to my 1967 R80SS/2C frame. These will most likely be anchors for the Craven Racks I have yet to fabricate. I have designed them on paper.
    The BiG issue I have w/ /2 frames is points of anchor . So I have this novel idea that I'm using Round & some Hex Metric Coupler Nuts. Belmetric sells what I'm using. They come in different lengths & ..... IF
    I need ones longer, I weld 2 together. Some 16 Plus should get the job done.
    Will purists /2 owners like what I'm doing....
    0BAED357-E3EB-4A1D-9BCE-61035BE74966_1_105_c.jpeg 1BB33EEF-EA04-4287-91B8-183E1C1374DA_1_105_c.jpeg 7CA2ABFB-DF7F-43B7-BD69-2A2F24EFC6D7_1_105_c.jpeg 8B2FDE3C-F2D8-4B78-B257-AA2C24E5809C_1_105_c.jpeg 9D5041A6-AD2D-4A29-8791-615EB2D61CAA_1_105_c.jpeg
    33D69488-295F-47D6-814E-CD6B9B558B12_1_105_c.jpeg 66E29182-4A50-483F-A95C-18FB709525EB_1_105_c.jpeg 75AF55C2-08A8-4AEF-A607-B50D5279AEEB_1_105_c.jpeg 930D8480-AE13-407C-8CDC-8FADB414D49E_1_105_c.jpeg
    63930BEC-A4F4-42B2-A971-DB0A271E1773_1_105_c.jpeg 97146C22-F202-465A-9B6A-DA965011E214_1_105_c.jpeg 438846C2-549A-400C-B431-26CE4AD907E1_1_105_c.jpeg 991933CF-C1EC-4FC2-BF22-FB32A4224981_1_105_c.jpeg A02C1461-A992-4C9A-A0D9-8FDFE3621722_1_105_c.jpeg A036A123-8F34-468F-87A8-18E79D0F7865_1_105_c.jpeg
    B8DBD4C0-A1BC-4F0F-9DB8-0EF520FB225F_1_105_c.jpeg coupler nut.jpeg DAE3C354-20F6-447D-B022-05B2C69E4E96_1_105_c.jpeg F03ACD03-9E0C-4569-8E88-F26FDE8F8E6B_1_105_c.jpeg
    Pezz_gs and nmalozzi like this.
  4. Chad M
    Chad M 14880
    Jan 11, 2006
    1,688
    N49
    I doubt the purists will care, you're not following any trends so it remains quite interesting.
    Will you weld on a cover plate to hide that inserted nut? I think it would really finish off that bracket nicely.
  5. black knight
    Dec 2, 2009
    1,028
    absolutely
  6. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,338
    Fort Collins, CO
    Looks pretty useful to me! Some of the after market accessories used round clamps to go around the shock towers.
  7. black knight
    Dec 2, 2009
    1,028
  8. black knight
    Dec 2, 2009
    1,028
    Gas Tank Frame Tab Modification .
    Moderator
    · 1psg6omod ·
    This is what I did to get more working space for installing / removing an engine, periodic maintenance work for starter motors, and because I will have to fabricate a bracket for the E. Hoske RS~2 gas tank, I made this MOD.
    Some have simply cut and welded their gas tank frame bracket back on, just 3/4" or so shorter. I decided that having it removable was my option. More work, . . . . yes. Better options and outcome for me ..... yes.
    1B380C75-4398-4FA3-A0E7-C4EFA1FB9E63_1_105_c.jpeg 1D57F65F-3C5A-4401-B5A9-3DA84DEAFABF_1_105_c.jpeg 5A7A37EE-39B4-4B2D-AB4C-74A54E078EFC_1_105_c.jpeg
    05B14C2F-9A25-45A6-B77F-E13AE9917994_1_105_c.jpeg 5CB9E34A-A24A-4590-914B-0CD034E80A6F_1_105_c.jpeg
    6B19709F-A6A0-49E8-A75B-1CC6B8957D68_1_105_c.jpeg 06F5EC84-899F-497B-948A-FCCC8B510E7D_1_201_a.jpeg 7FC04BE1-7B5E-48CF-BF13-38222430A075_1_105_c.jpeg 8C7B12F6-E6BC-45AF-8B35-79C9EF88D6F2_1_105_c.jpeg 8CF33F8D-020C-4BFD-AC1C-483DF807A687_1_105_c.jpeg
    13E351E2-66A7-4ACC-A547-CEE8F0120402.jpeg 015FD78B-A788-4545-94FC-E6845B56AE44_1_105_c.jpeg 20DFBE84-3726-4F92-AECE-C84826959133_1_105_c.jpeg
    24D6C45C-B28A-4DB4-942B-EBD631AD22AB_1_105_c.jpeg 46A43FAD-E96D-48E6-87A6-E390D245BD1E_1_105_c.jpeg 50BA96B2-8D09-460D-B4B2-2287691EF0BD_1_105_c.jpeg 52AC5684-7546-4AD5-96A4-E89747CEFDCE_1_105_c.jpeg 68B75946-A6A6-4467-8F78-9F69896A988C_1_105_c.jpeg
    562EA0CC-B17A-42BE-829D-D016AB7362AB.jpeg 824BC437-3209-4F2F-89B9-B9B37394B705_1_105_c.jpeg 8570FB83-A485-4139-8509-50973CD77BAC_1_105_c.jpeg 38229F11-6E26-4D67-A6D7-09368155A2E5_1_105_c.jpeg
    The tank is fixed @ the front m8 bolt, the rear support is Not going anywhere, No side to side. No front to back. The 2 tabs have a welded-in m6x37mm hex coupler nut, I may even safety wire those 2 m6's , cause I like SW. The newly cut & shortened piece has an m8 nut welded to it. The future under tank support bolts will have a dense rubber strap to cushion tank. ALL bolts will be 242 Loctited.
    It Ain't going nowhere ...
    0554809B-DA2F-4F3B-8BA0-E0AB634E1E21_1_105_c.jpeg 8110453D-8186-45E9-857F-0C2EEA12D8A7_1_105_c.jpeg
  9. black knight
    Dec 2, 2009
    1,028
    I'm amazed that previous owners have never corrected the rear fender 'flip-up' left strut. It was almost a 1/4" longer. Lop-sided - gap - ugly mess
    SO
    measure, inspect, use a pipe tubing cutter, mark it, grind, sand, make an inner tube, marker, grind more, sand , fit, marker again, sand, fit, weld. File, Sand & Polish.
    27CA323C-8A41-4264-A0F9-91C3B43858C2_1_105_c.jpeg B031E441-EA54-4F15-847F-90C3C5F25FCE_1_105_c.jpeg 5C38EF0E-8B5A-4604-9900-C759E0A2CF7E_1_105_c.jpeg 6A1EF1E0-051E-4266-86BE-F546356A663B_1_105_c.jpeg 09EBF1C6-392B-4885-9CF0-BBAA90F9C7FD_1_105_c.jpeg 10C56FA3-110F-4133-980F-ED3DC7A313A7_1_105_c.jpeg 47B5FC0F-E8D9-4422-9315-5C4CC595F142_1_105_c.jpeg 234E9BA5-7DFD-4A35-8495-0B2038199625_1_105_c.jpeg 234E9BA5-7DFD-4A35-8495-0B2038199625_1_201_a.jpeg 653B6EC0-C0A9-44FF-862B-53F33EE654E4_1_105_c.jpeg C906D6DC-59F0-4CD1-BA6B-08D80C12ED77_1_105_c.jpeg E1D3FBF5-BC20-48C3-9439-F91805113E89_1_105_c.jpeg E454FA4B-3B5D-48E2-8DD3-35D936E997F5_1_105_c.jpeg
    F5E1CA83-DBA2-445A-B70E-DE9293F63D07_1_105_c.jpeg 6A1EF1E0-051E-4266-86BE-F546356A663B_1_105_c.jpeg
  10. black knight
    Dec 2, 2009
    1,028
    clearance issue
    3D77A1D9-9A9C-4077-8979-676C9A167F79_1_105_c.jpeg 5A5198AD-BE8F-4E57-B49E-50A85BC054DE_1_105_c.jpeg 6DCC8874-FFAD-4732-9D93-3AF03E54B037_1_105_c.jpeg 7D48CA06-5F48-48E3-A093-A4FF6DF654EE_1_105_c.jpeg 8A696FF9-2249-4C67-9D90-853ADD138976_1_105_c.jpeg 59BA8CBD-1BE8-4B73-889E-62F96588406E_1_105_c.jpeg 86E4B94C-A84B-443B-B948-7FF36BE3B28C_1_105_c.jpeg 219F6540-448C-4D8A-A05D-649CE9C06537_1_105_c.jpeg 229A312B-B68B-4317-BC53-819E386F3FBE_1_105_c.jpeg 255C6CA2-6E27-4F7B-90E7-FE30480634B8_1_105_c.jpeg 310AF3D9-A3A4-4C51-89E4-DD0CD9ACE0CB_1_105_c.jpeg 352AE7A5-BFD5-4045-9133-01F23359B813_1_105_c.jpeg 61979597-9F14-4E3C-A2E7-D662E06F1BB1_1_105_c.jpeg BD31AA65-CA02-45B0-ADBB-4DACB0843C85_1_105_c.jpeg CADBCED9-BD0E-4180-A276-94FCF24A6CE7_1_105_c.jpeg thumb_IMG_6532_1024.jpg 2ACBE7B9-3A4F-4228-9E65-BA7DA2CE6B3E_1_105_c.jpeg 3A0DCEBB-6C3D-49F1-BC8C-0774DF4137D4_1_105_c.jpeg 3ADFD862-8162-4700-ACB5-1CF79812E73D_1_105_c.jpeg 8FABEB40-2E85-4505-AB70-62A4B6161C77_1_105_c.jpeg 09AF5777-93B8-4BD8-92CD-A55762F6AD6D_1_105_c.jpeg 064EE142-6D90-4657-B82B-E62E29B0C78B_1_105_c.jpeg 6859D382-BE24-46C8-9376-2A82E334EAA4_1_105_c.jpeg A47D2E81-5FE7-4342-A679-4FBF8287FE84_1_105_c.jpeg
    Pezz_gs likes this.
  11. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    The correct flip up nut has a shoulder on it that locks the arm in place.
  12. black knight
    Dec 2, 2009
    1,028
    correct ~ is a relative word here .. . . . ... . ... . . .
    a 'shouldered' nut is called a Flange Nut. I am so far away from being correct on my conversion, not caring but building my ride as needed. You'll see a LOT of different things done on this bike that you've not seen before, @ least I haven't. It's a fun build so far and after the engine arrives from a build, faster progress moves forward. Stay tuned ...
    ' This Conversion, has no rules ... ... ... except my rules '
  13. Pokie
    Apr 4, 2013
    8,338
    Fort Collins, CO
    I hear you, my builds usually are from whatever I have either on hand, have been given or what I make. I wasn't trying to make a rule for you, I was just stating that those "flange" nuts are good at holding the flap in place.
  14. black knight
    Dec 2, 2009
    1,028
    thx Pokie,
    appreciate the thought,,,,,, :getiton:getiton
  15. black knight
    Dec 2, 2009
    1,028
    fixed @ Vern's shop.
    3DFAEBC4-7BF3-4EA4-A964-E032F83AE83C.jpeg 7B2EB26F-6E97-4821-8A44-5A7AC16FEEA9.jpeg 7BCE9699-09DA-46C1-BF98-F1F7E37E3A98_1_105_c.jpeg 7C9BD2E1-4F65-4FEB-8B74-B13B69CF8346.jpeg 7D48CA06-5F48-48E3-A093-A4FF6DF654EE.jpeg 027D6DB5-10D8-498D-A9D9-F3D5A0FAC911_1_105_c.jpeg 31D06E00-AB27-4674-8BF3-1FB19381F22D_1_105_c.jpeg 45B6FC01-1707-444E-899A-532424405A8A.jpeg 87FCD8E1-C084-4D8F-8BFC-A2BA53BB1C48.jpeg 219F6540-448C-4D8A-A05D-649CE9C06537.jpeg 470C4A31-0762-40D4-AFE9-79F13AF1D3A5_1_105_c.jpeg 6455359A-0F43-4F0D-8E39-3170737BD25C.jpeg A2EF7ADF-8952-4D07-8EFF-FA84D1D09CB9_1_105_c.jpeg
  16. black knight
    Dec 2, 2009
    1,028
  17. black knight
    Dec 2, 2009
    1,028
    stiffer 'stringer' on the Earles swing arm. 3/16" x 3/8"
    1D90AA79-9FE5-484E-B5B4-AA6DC4FE112D_1_105_c.jpeg 3CF24DC8-FBCE-4FF5-95E5-7B71DD00BAD6_1_105_c.jpeg 6B5A4141-09BF-4D49-8024-A1E8B5AF93D2_1_105_c.jpeg 6D78AE82-E117-45AB-817B-F25D3863CFCD_1_105_c.jpeg 29C565D6-A3E4-4251-A021-A5990A00C5DE_1_105_c.jpeg 30B2A69E-8A1F-4380-9D12-8A43B0ED7890_1_105_c.jpeg 99E60ECC-5721-4334-9F3E-2CF542626871_1_105_c.jpeg 695F043E-D7C4-4620-8012-4ABF2098224F_1_105_c.jpeg 776D9256-252D-44B0-BB13-DF0095A29505_1_105_c.jpeg 92722CAC-D75A-4F13-97DC-45060B9EAA30_1_105_c.jpeg 96649FA1-1FBA-4BB6-8330-70ECEACEA9F0_1_105_c.jpeg 180292D4-69B1-414A-AD2F-F2B40F3659B5_1_105_c.jpeg 841287CC-C33D-4F22-9150-B9D776199E72_1_105_c.jpeg 40936742-4094-4A77-B6E3-5C115360CDB8_1_105_c.jpeg B11A55E0-0A73-4FDF-9473-442793D4885F_1_105_c.jpeg C1CD892F-6839-47DD-A9DB-AFF4058BC5A6_1_105_c.jpeg D3D14DF5-5886-4284-83B8-7990A6AE39F0_1_105_c.jpeg D62B3314-1CA8-49E8-8B9A-25B0B015EFAE_1_105_c.jpeg EC49EA90-06B5-4E36-9F00-5E40B5BEA275_1_105_c.jpeg
  18. black knight
    Dec 2, 2009
    1,028
  19. black knight
    Dec 2, 2009
    1,028
  20. black knight
    Dec 2, 2009
    1,028
    4DECF306-D6B2-4948-9561-65EC553C94A4.jpeg 6F3441A7-DF2F-4482-A606-7E6493855FA6.jpeg 49AE7B57-68E5-4529-82ED-4A164A388B90.jpeg 4695C0C9-A422-407C-BBE4-1E7D95EB1DEA.jpeg C3DB8A30-910F-4A83-8BB8-12B49CB0D097.jpeg F6F12281-F571-4524-BDD2-CE0924782F3A.jpeg F9C9FA5E-1E3E-4BDF-95A3-ADC6A48D915F.jpeg
    Solo Lobo likes this.
