Has anyone installed the Denali split soundbomb horn?
Discussion in 'Parallel World (790/890)' started by Canadian eh, Aug 15, 2021.
  1. Canadian eh
    Canadian eh Adventurer
    Sep 17, 2017
    80
    Lethbridge, Alberta Canada
    I'm curious if anyone has installed the Denali split soundbomb horn on their 790/890 bike?
  2. new2adv
    new2adv Converting gas into wheelies since 1974
    Nov 5, 2018
    1,260
    Great White North
    Installed a set of PIAA horns. There wasn’t enough room behind the radiator so I modified the console supports.
  3. NarOuvCux
    NarOuvCux 790R
    Apr 28, 2020
    15
    Narbonne, France
    Yes the compressor fits in place of the euro5 canister and the trumpets where the normal horn mounts. Been using it for 2 years no probs. Grease all connectors and place relay up high to avoid problems during water crossings.
  4. Canadian eh
    Sep 17, 2017
    80
    Awesome, what is the Euro5 canister? Thank you :)
  5. NarOuvCux
    NarOuvCux 790R
    Apr 28, 2020
    15
    Narbonne, France
    Follow the tank breather pipes and you find a black long box down on the right hand side of the motor. You will need to take the tank off (easy job) and then it will be clear.
  6. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    7,128
    Planet Fucking Earth
  7. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,989
    Star Tannery, VA
    ^this will get you the general idea for sure.
    Though I'd suggest just leaving the OEM solenoid in place rather than messing with buying a dongle. The dongle just replaces the solenoid so the ECU won't complain about it missing, and there isn't enough size difference between them to matter.
  8. Canadian eh
    Sep 17, 2017
    80
    Thanks guys :)
    #8
  9. Starky307
    Starky307 Adventurer
    Jun 18, 2020
    19
    New Zealand
    Did you have any issues with canbus warnings when removing the original horn to feed the relay of the Denali unit or was it a straight fit and seamless integration?
    #9
