Hawkeyes west 2017
Discussion in 'Americas' started by engineman, Dec 6, 2016.
  1. RoundOz
    RoundOz Plenty of seasoning
    Jun 10, 2009
    2,433
    West Nebraska
    You guys are welcome to use the facilities, so to speak, but it would make for a long oil ride. It doesn't need to be all on interstate though. I took a route along Hwy 26 to (eventually) Laramie on my way to Steamboat for the rally and also on my way to Montrose for a meeting. Now we are talking a long-arsed day then tho...
  2. vipers
    vipers Been here awhile
    Sep 15, 2014
    278
    central iowa
    If you and Doug want another rider to tag along this wknd lmk, I'll spin on down and join you.
    I got my bike back from Doug last sat. The new chain and sprockets solved my chatter. I let it go waaayyyyy too long. My cs bolt was damaged and sheared off when they removed the front sprocket. Glen had a blast getting that sorted I bet. Also got my dual usb installed.
  3. engineman
    engineman Long timer Supporter
    Sep 26, 2012
    1,089
    Eastern Iowa
    I've got a 2 place bike trailer. No way to get 3 on it though. My sheep trailer would easily haul 3 bikes but would be a bit much for Orange's jeep to tow
    Sent from my XT1650 using Tapatalk
  4. engineman
    Sep 26, 2012
    1,089
    Eastern Iowa
    Correct. Drive on Saturday, meet in Gypsum Saturday night or early Sunday morning and ride from there
  5. engineman
    Sep 26, 2012
    1,089
    Eastern Iowa
    Got the Rade tank installed on the 690, got the skid plate installed and got the tune put in it for the new air setup.
    @vipers , what's the fuel range on your 500? Will need to make sure we know where we have to get fuel
  6. Orangecicle
    Orangecicle On a "Quest" Supporter
    Apr 24, 2007
    5,520
    West Des Moines, IA
    I'll have the Supertanker, so all he needs is a bottle. :D
  7. engineman
    Sep 26, 2012
    1,089
    Eastern Iowa
    Case in point- I just ordered a Rekluse for the 690, should get here just in time
  8. RoundOz
    Jun 10, 2009
    2,433
    West Nebraska
    Make that two supertankers, though I plan on going half full when it won't cause range problems, just to try to avoid blowing an O-ring on the fall recovery equipment (aka gut busting). The tricky thing is I just turned off my O2 sensors..,no telling what my max range is now.
  9. Orangecicle
    Apr 24, 2007
    5,520
    West Des Moines, IA
    I deleted my O2 sensor some time ago with TuneECU, and then I removed the unit in the exhaust and plugged the hole. I think it removes one more variable from the bike, but I didn't notice any issues at high altitude.
    The 690 has a switch under the seat that normally controls throttle response only. I've converted mine to control fuel mix only. The last time I was in Colorado, I had to switch over to my "lean" setting to make the bike run perfectly, but that was the only change. It probably would have been fine at the richer setting, but I was getting comments that I was smelling like the Exxon Valdez, so I made the change.
  10. vipers
    Sep 15, 2014
    278
    central iowa
    In Iowa I get around 45mpg mixed driving so about 100miles tops. In Iowa with my 15' 690 I got 45-55mpg and in Colorado I got 60-70. Hopefully I get real good mpg with 500 in colorado. Any others have that experience in Colorado or at high elevation?
  11. vipers
    Sep 15, 2014
    278
    central iowa
    I plan on taking extra fuel also. Not sure how much yet
  12. Orangecicle
    Apr 24, 2007
    5,520
    West Des Moines, IA
    I've never looked at mpg in Colorado. You lose quite a bit of power because of the altitude, and if an injected bike is working properly, it will significantly trim the fuel to match the lack of air. I would guess that any fuel savings I could have seen were matched with increased use of the right wrist.
  13. engineman
    Sep 26, 2012
    1,089
    Eastern Iowa
  14. RoundOz
    Jun 10, 2009
    2,433
    West Nebraska
    Yes. And I have a spare if someone needs it.
  15. vipers
    Sep 15, 2014
    278
    central iowa
    I lost mucho power at the highest altitudes but gained a shatload of mpgs which I was ok with.
  16. RoundOz
    Jun 10, 2009
    2,433
    West Nebraska
    So the cabin at Ouray is 3 nights, checking in on 30th, out on 2nd?
  17. vipers
    Sep 15, 2014
    278
    central iowa
    I'm going to be staying in ouray 1 or 2 nights i believe so I'll look into the lodging asap. Gona kinda wing some stuff :)
    Did you do the "evo1" (I think it's called this) remap engineman? I Did that with the evo1 lid and wings. Awesome midrange! Had the same results with the 500 remap, very noticeable power inscrease and better overall fueling.
  18. Orangecicle
    Apr 24, 2007
    5,520
    West Des Moines, IA
    Yeah, I carry one.
  19. Orangecicle
    Apr 24, 2007
    5,520
    West Des Moines, IA
    @engineman no luck on my end finding parking in/around Gypsum so far. The place I checked out will only allow RV parking. As always, we could park the trailer in Golden behind my step-mom's place and then ride out. I'm also checking with various self-storage places in and around Gypsum. I'll let you know what turns up.
    What is the plan leaving? We could do the same as we did last time if you like. That seemed to work OK.
    @vipers, my weekend got screwed up. The wife unit reminded me that we have Mellencamp tickets Saturday night, and we have to drop the kid off at Simpson College on Sunday. I'm only going to be available some time after 3pm on Sunday, so pretty limited.
  20. engineman
    Sep 26, 2012
    1,089
    Eastern Iowa
    This should work for parking. It's the secure lot at a towing company.
    Probably do the same thing for the trip. I'll leave here around 5, get to your place around 7, put my trailer on your jeep and head west.
