Header heat shield wrap - Don't do it
Discussion in 'Dakar champion (950/990)' started by mgorman, May 24, 2010.
  1. mgorman
    mgorman Crashing since 1964
    Oct 25, 2006
    6,230
    NEO
    When I bought my 950A the previous owner had wrapped the front header from the guard forward. I was worried it would rust underneath and for some reason figured it was bad news so when a spare cam up on here for sale, I bought it but didn't get around to putting it on.
    I was out riding Sunday and on a downhill I whacked the right tank guard on the 950 pretty hard. Enough parts moved that it cracked the header. I couldn't feel or see the leak, but I could hear it.
    When I got home I pulled the right tank off to inspect the header. It didn't feel right and when I pulled the heat wrapping off I found a lot of rotten metal and it basically fell apart on the floor. The wrap had held it together for about 2 hours.
    The hole had been on the bottom where I couldn't feel and like a plasma cutter, torched a hole in the plastic side of the skid plate and melted the top cover of the relay switch for the starter to the starter fuse. When I pulled the cover, the fuse came with it. As you can see, things got tight and toasty down there.
    I am lucky though, could have been the gas tank I am lucky also in the fact I was worried about what was under the heat wrap so I bought the used header (here) for $35 about 1 month ago. KTM price $243.00 Thank God I am a hoarder!!!
    I Couldn't find any thick heat foil for the tank so I ordered some from the local KTM shop.
    Unless you live where it never rains, don't use heat wrap.
  2. sonoran
    sonoran a treat especial Supporter
    Sep 28, 2009
    57,228
    33°05'38.7"N 111°40'57.2"W
    Yikes. I thought the header pipe was stainless steel.
    Glad your bike didn't burn up.
  3. rider914
    rider914 Agnostic Adventurer Supporter
    Feb 28, 2005
    3,935
    Alta Loma, CA
    Nope, just nickel plated steel.
    Had mine ceramic coated by YoungGun
    Holding up very well.
    -M
  4. Pete640
    Pete640 Long timer
    Nov 23, 2008
    2,127
    Earth
    Thanks for the heads up - suppose it makes sence tho.
    That ceramic coating sure is purdee tho - I likee a lot. Let us know how it goes wear wise.:wink:
    Pete:1drink
  5. Shuffler
    Shuffler Hommes Grande
    Apr 20, 2004
    1,763
    CFalls MT
  6. Terlingua
    Terlingua Terlingua
    Oct 1, 2005
    271
    Port lavaca Texas
    My dumb ass did the same thing. Cost me a big ride to Mexico. :cry I found it just before I was to head down there. Then had to what a 4 are 5 weeks for the pipe.
  7. Bronco3738
    Bronco3738 Mike
    Jun 19, 2009
    505
    Just South of Phoenix, Arizona
    I was just looking at header wraps online trying to keep the heat out of the engine. Wont be doing that now!
  8. Joe
    Joe Debaser
    Nov 6, 2007
    1,999
    Ontario, Canada
    #8
  9. rider914
    Feb 28, 2005
    3,935
    Alta Loma, CA
    Holding up VERY well.
    Baked on mud does not stick like stock. Washes off pretty easy.
    Can't really tell if it has any effect on fuel tank temps. Can't hurt tho.
    -M
    #9
  10. mgorman
    Oct 25, 2006
    6,230
    NEO
    I sent KTM950.info a note.
    #10
  11. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    Thanks for the heads up. A link to this thread has been added in the Wisdom of the Forum page on KTM950.info.
    #11
  12. mgorman
    Oct 25, 2006
    6,230
    NEO
    The pictures are on a temp folder, let me know if I should have them moved to someplace else.
    #12
