Headlight options DL1000 Sidecar
Discussion in 'Hacks' started by Rockman, Oct 2, 2017.
  1. Rockman
    Rockman Been here awhile
    Jan 26, 2007
    630
    Inverell, NSW Australia
    I took the junk aftermarket headlight of my DL100o sidecar yesterday with the idea of refitting the original setup. What I found is that this isnt possible because the PO has cut the mounting bracket off the frame so I'm now looking for an alternative. The Trail-Tech 8" style appeals to me but they dont have a dipping option so they are no good. Has anybody run across anything similar that dips (LH)?
  2. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,787
    Your imagination.
    Easily converted to a high/low H4 or an LED.
    This is the one I slapped onto the Tangerine Dream (Eric's K100'). The one fitted to the bike has a H4 high/low insert. The one between the outfit is a straight up spot light. The one on the nearside of the chair is a 5 3/4" H4 high/low with its own switch and relay.
    Your imagination is the only limit as to what you can do.
    G'day Gus.
    Bobmws likes this.
  3. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    11,038
    north of seattle
    weld the bracket back on?
    or
    fab up a new bracket?
    The Strom stock headlight assemblies with led bulbs are awesome. I run them this way on my dl1k solo.
