Heat troller with neutral lockout
Discussion in 'Dakar champion (950/990)' started by Louge, Mar 27, 2006.
  1. Louge
    Louge silence of the limbs
    Nov 22, 2005
    1,554
    yellow house 25 miles NW of the white house
    I installed a Powerlet and Heat Troller in the left panel. The Heat Troller LED is below the panel surface.
  2. Louge
    Nov 22, 2005
    1,554
    Heat Troller resident in right panel. The relay removes power when the engine is in neutral.
  3. Louge
    Nov 22, 2005
    1,554
    Interconnecting cable.
  4. Louge
    Nov 22, 2005
    1,554
    Power tapped from ACC2. The carb heaters are on this same circuit which probably derates it to 7A when under the heater temp sensor threshold.
  5. Pointman0853
    Pointman0853 Unregistered Gun Owner
    Apr 14, 2005
    1,552
    Douglas County, Nevada
    So, it looks like you went from 16-18ga wire from the Acc2 up to 12-14ga to the heat troller? Mighta' been safer pulling this from the battery direct via a fuse.
    Do you carry a fire extinguisher on your nine-fiddy? It could get :grim.
    Pointman
  6. Louge
    Nov 22, 2005
    1,554
    Why?
  7. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,540
    Central Ohio
    Because the load carrying ability of 12-14 gauge wire exceeds that of the 16-18 gauge. So, you potentially can overload the smaller diameter wire and cause a meltdown, or worse, a fire.
    That supposes that the fuse won't blow first if the load exceeds the circuit's limits. Wouldn't count on it myself.
    If you ran a wire to the battery with the proper fuse in line, you could carry the maximum amperage for the larger diameter wire. You can always use a relay in the circuit to switch things on if you want to use the other circuit for control purposes.
    Dave
  8. Orangetwin411
    Orangetwin411 Katoom Rider
    Jan 27, 2006
    292
    Vernon, NJ
    Nice. clean install Louge :uhhuh
    #8
  9. Pointman0853
    Apr 14, 2005
    1,552
    #9
  10. Foto Veloce
    Foto Veloce The Free Radical
    Jul 29, 2005
    375
    Seattle, WA
    #10
  11. Louge
    Nov 22, 2005
    1,554
    Relax fellas, 18AWG load carrying capacity with any of the common jacket materials is comfortably beyond the circuit's 10A rating. My Gerbing's jacket liner has a 77W draw of which I'm typically using 30-40W or less than 4A via the Heat Troller.
    Hooking the circuit directly to the battery would invariably result in a no-go situation.
    The relay takes my Gerbings jacket liner offline at idle when the bike's charging system is in the most compromised position to support it. My sensitivity to this comes from running an Evoluzione ignition amp on the Mille. At idle it ran a charging deficit.
    After doing load analysis / wiring Iron Butt winners this is small potatoes.
    #11
  12. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,540
    Central Ohio
    Errrr, OK. But, I don't get your point.
    Mine was not to downgrade wire gauge and fuse for the heavier gauge as this could cause serious problems. And if you want to put in some kind of shutoff, you can do that with a relay.
    Dave
    #12
