Heated gear advice
Discussion in 'Equipment' started by drtumolo, Feb 10, 2019.
  1. drtumolo
    drtumolo n00b
    Aug 25, 2017
    2
    I just received a heated jacket liner from first gear and have a fit question. This is my first piece of heated gear and everything I read states it should fit "snug". My question is how snug? I can wear it with a t-shirt under it but it is tight across the shoulders and there is no way I could wear anything additional under it besides the t-shirt. I am thinking I need to go up one size but looking for advice from someone who has experience with heated gear.
  2. inspmark
    inspmark Adventurer
    Jul 12, 2009
    26
    NW PA
    Mine are sized as my normal size. A T-shirt under it would be good. If your jacket fits correctly, it will hold it close to your body. You can also layer between it and your jacket for insulation.
  3. jdub
    jdub Dawg bytes reel gud Supporter
    Jan 7, 2004
    3,569
    S. Central PA
    The last heated liner (my third) that I bought (this one on-line, and from a different manufacturer) fit like yours, and I exchanged it for the next size larger. While the liner should fit closely, I could see me tearing its seams while picking up the bike in the woods or just by doing basic maintenance like airing the tires, etc. Also, gain just a few pounds and that snug one is now in the too-tight and unusable category.
    The next larger size for me still fit well without being bulky or too big.
    Chaostrophy likes this.
  4. appliance57
    appliance57 Long timer
    Dec 11, 2014
    2,598
    Boston
    You also want as little between you and the liner as possible. So a t_shirt or other base layer is good.
    UncleRandy and Shaolin like this.
  5. oldtouring B
    oldtouring B Been here awhile Supporter
    Oct 9, 2009
    939
    Al Ba Jerky. NM
    If it is tight just standing then imagine what it will be like on the bike! I vote next size up..
    SmittyBlackstone likes this.
  6. (I^2)R/746
    (I^2)R/746 Rider
    Oct 12, 2012
    507
    Santa Cruz Mountains, CA
    ^ +1
  7. Switchglide12
    Switchglide12 Long timer
    Feb 11, 2015
    1,136
    Somewhere in NJ
    I always have base layer and shirt then heated jacket. I normally wear large t-shirt and order Large heated jacket.
  8. davidji
    davidji bike curious
    Mar 16, 2009
    2,508
    california
    one thin layer underneath. You may not want bare arms. Usually I have my arms covered. Not always. If I'm wearing a short sleeved t-shirt, I usually add cycling arm warmers.
    If it's fine with a base layer, the size is probably good. If it's too tight, size up.
    Anything beyond the base layer goes over the heated liner. For me that pretty much only means a wind/rain layer, though I've probably had insulation over it, and would again in cold enough conditions.
    #8
    TrashCan and shrederscott like this.
  9. JR356
    JR356 Long timer
    May 4, 2005
    6,948
    Way out West
    You say it is snug,is that when you are in riding position,or just normally standing?
    As stated above,you do not want it so tight that you risk tearing seams.
    JR356
    #9
  10. bookmd
    bookmd n00b
    Jan 25, 2019
    9
    South Arkansas, USA
    The heated jacket liner is supposed to fit a bit looser, like a jacket liner, lol. The (underlying product) company (warmnsafe) also makes a heat layer shirt that is supposed to be pretty snug for better heat transfer. I have both, and like the shirt better fwiw...
    #10
  11. squish
    squish Out of the office.
    Dec 4, 2003
    8,921
    Where the Ghetto meets the sea.
    I like my electric vest to fit close to my body, not tight but snug enough that i can feel it against my undershirt
    My electric liner fits a little more like a typical liner, and with it I don't wear any insulation between the heated jacket and the outer jacket
    Where with my vest I've worn a non heated liner for insulation.
    The idea is to keep the heat close to your body, and a layer of insulation between you, the source of heat and the outside element.
    #11
  12. drtumolo
    drtumolo n00b
    Aug 25, 2017
    2
    Thanks for the advice. I decided to go up one size on the liner since it was snug just standing with it on.
    #12
    jdub likes this.
  13. lipsee
    lipsee Been here awhile
    Jul 18, 2012
    467
    Lincolnshire
    Hi,, I have the 90watt warmnsafe liner,, I wear a base layer,, then I use an Knox armored vest with breast pad,, then the Warmnsafe liner,,, it works great!! I think the armorded vest is more important to be closer to your body then the ellecy liner and it still keeps me hot... mind you,it being 90watt does help.. Good luck youall just using the heated vests (armless) whats the point in letting your arms get cold,(but each to there own)Now that I am hooked on elecyy gear.The question now is do I try Battery on bike or separate battery...
    #13
