    Dismiss Notice
Heavy Duty Tube vs Mousse vs Tubliss - Best on TECHNICAL stuff?
Discussion in 'Equipment' started by pingvin, Aug 1, 2017.
Which is best?
  1. Heavy Duty Tube
    9 vote(s)
    24.3%
  2. Mousse
    11 vote(s)
    29.7%
  3. Tubliss
    17 vote(s)
    45.9%
  1. pingvin
    pingvin Been here awhile
    Nov 17, 2008
    899
    Kongsberg, Norway
    So not for tarmac or gravel roads but rocky, slippery, steep, tricky conditions.
    Guess poll works best if those voting have tried all alternatives here.
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,348
    Guys who use tubliss swear by it: you can air down to 5psi and yet not to worry about damaging rims.. works like rim lock and saves some weight too. On down side cost and need to be careful mounting/dismounting, co-worker had one destroyed by shop monkey. and where is 17"??
    Hi-De-Ho and pingvin like this.
  3. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,707
    日本
    I used tubliss in my KTM350. Worked well, but you need to change tires by hand after it's installed.
    pingvin likes this.
  4. MX Engineer
    MX Engineer Alta Redshift MXR is the best dirt bike ever!
    Dec 22, 2015
    1,360
    Ann Arbor, MI; Lake Havasu City, AZ
    There is one more option - Tube Saddle. I have it on my electric bicycle to keep the pinch flats off and rims protected. It works beautifully. You just have to check the air pressure a few hour after the installation and after the first ride because the foam gets compressed by the pressurized air.
    A Mousse would be my second choice, if I thought that it would give me the "tire pressure" that I want. The installation requires both strength and skill, but you never have to check or adjust air pressures or worry about flats.
    I tried and didn't like Tubliss because it was always slightly leaking, and I had to check 4 air pressures before I could ride. I used a green goop inside the tire to try to seal the micro leaks, it wasn't helping much, but surely was making tire changes very messy. It also depends on the inner surface quality/smoothness of the tire that you are using. YMMV.
    ozrodder and pingvin like this.
  5. JensEskildsen
    JensEskildsen Long timer
    Mar 24, 2009
    2,302
    Denmark
    I'd go mousse, but with me being cheap, i run heavy duty tubes, and dont air down past 14psi.
    ohgood and pingvin like this.
  6. pingvin
    Nov 17, 2008
    899
    Kongsberg, Norway
    Used both mousse and Heavy Duty and was happy with both, main advantage with mousse IMO is not worrying about puncture. Tempted trying Tubliss though to reduce pressure even more for better traction. And easy carrying seal plugs in case of puncture.
  7. twinrider
    Aug 20, 2002
    17,707
    日本
    Yup, those are the two main pluses of tubeliss. I used to air down to about 7 psi for dirt on my KTM and also have fixed a flat with a sticky string.
    It's a good idea to carry a spare inner tube in your truck in case you puncture it. Never happened to me, but it did to others in my group.
  8. pingvin
    Nov 17, 2008
    899
    Kongsberg, Norway
    Also as opposed to mousse, riding on tarmac is fine with Tubliss. Though mainly do technical riding some tarmac transport is sometimes required.
    #8
  9. Mountainhound
    Mountainhound Long timer
    Sep 25, 2015
    2,141
    New Hampshire
    I must be really slow because I run 6psi in the back and 8 in front with uhd tubes. My not making something has nothing to do with not low enough air. I'll stick with what I know.
    #9
    trc.rhubarb likes this.
  10. pingvin
    Nov 17, 2008
    899
    Kongsberg, Norway
    That's too low, too many sharp rocks around here. A buddy used pressure similar to you but after several punctures (with heavy duty tubes) he realized he had to increase. Most of us run 0.8 bars front and rear (11-12 psi), then you're fairly sure you won't have a puncture.
    On a side note, the Mitas EF-07 rear tyres have incredible grip even in the wet, rubber comes in three compunds, yellow stripe (hardest...but still very soft), green stripe (softer) and 2 green stripes (softest). These are intended for extreme enduro and is almost like cheating. You can twist the knobs 90 degrees with your fingers! Matching front tyre is C-19.
    #10
    twinrider and cyclopathic like this.
  11. Yard Sale
    Yard Sale let's be bad guys
    Jan 17, 2008
    4,649
    Northern Nevada
    I used to run my UHD and trials tire down to 6 psi but I was very careful. Now I've got Tubliss and use it at 5 psi with a Shinko 505. It gets me at least 80% of the trials tire traction in conditions like this.
    Never used a mousse but simulated 13 psi traction isn't like 5 psi traction. I used to ride at 13 psi with tubes.
    I also use Tubliss on my trials bike at 4/6 psi but that's a whole 'nother ballgame.
    #11
    cyclopathic and pingvin like this.
  12. Mountainhound
    Sep 25, 2015
    2,141
    New Hampshire
    No problems yet (course having said that tomorrow I'll probably get flats on both tires) with over 2,000 miles of new England woods. But then like I said I'm probably a hell of a lot slower than I think I am or as fast as any of you are. Running golden tire fatty in front and the 216 rear. I started at 12 and wound up where I am. Most those miles are on my 500 exc only around 300 on my 300xcw.
    #12
    pingvin likes this.
  13. twinrider
    Aug 20, 2002
    17,707
    日本
    Yes, I had no problem even riding highway.
    #13
    pingvin likes this.
  14. twinrider
    Aug 20, 2002
    17,707
    日本
    The main reason I installed tubliss was so I could fix flats with a sticky string.
    #14
    pingvin likes this.
  15. pingvin
    Nov 17, 2008
    899
    Kongsberg, Norway
    Really want Tubliss...but hesitating since realizing more maintenance and more complicated after looking more into it. And got a good deal on Michelin Mousse. Maybe next time...
    Good video:
    #15
  16. twinrider
    Aug 20, 2002
    17,707
    日本
    Nice review but in two years of use I didn't experience any of the issues he reported. I'd check the pressure before a ride and air up after if I was riding back. Otherwise I just checked it the next time. Always had the tire tread wear out before the sidewalls. Never suffered any pinch flats.
    #16
  17. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    804
    Loomis, CA (Sacramento area)
    Good review. I have successfully been using Tubliss front and rear since its inception. Prior to Tubliss I would get periodic pinch flats unless I ran absurd psi levels however with Tubliss I have never had any pinch flats although my wheel rims do occasionally get dinged.
    #17
  18. pingvin
    Nov 17, 2008
    899
    Kongsberg, Norway
    Well...went for mousse for 2 reasons:
    1. Zero risk for puncture, no need to bring any tool/tube/repair kit
    2. No maintenance
    Not that much tarmac, normally max 15min transport, for my 450 anyway. About to buy DS bike, possibly 690, then I'll strongly consider Tubliss and bring plug kit for simple punctures but also tube as back-up if far from civilisation.
    Thansk for your input guys :clap
    #18
  19. MX Engineer
    Dec 22, 2015
    1,360
    I have a cool tech solution to the annoying task of checking 4 tire pressures on a bike equipped with Tubliss. It is TPMS!
    There is a bunch of various systems available, those that screw on top of the valve stems and talk to your cell phone and/or standalone alarm units. Fobo Ultra is one of them. It supports pressures up to 188psi.
    https://my-fobo.com/Product/FBULTRA
    #19
    cyclopathic likes this.
  20. miksu
    miksu Been here awhile
    Sep 28, 2009
    479
    Finland
    T-lock concept or tubliss installed in the same way. I dont see a need for the stupid tubliss rimlock.
    But to be honest, the actual slow and "technical" riding doesnt need tubliss nowhere near as much as high speed riding.
    #20
