heh heh locked my key inside givi case, any ideas
Discussion in 'Equipment' started by when the road bends, Mar 16, 2008.
  1. when the road bends
    when the road bends hello
    Oct 19, 2007
    464
    Seattle
    The case is sitting here in my aparment. I thought it would be a safe place to keep the key and after closing it realized that the red button does not open the case, the key does.
    Is there a trick to open one of these cases without the key, short of a prybar?
  2. kootenay kid
    kootenay kid Lets Ride
    Oct 1, 2005
    2,615
    kootenays canada
    Shit, I never thought of that. Now that I think of it you have to turn the key before you can push the red button dont you? To get the lid off you need to take out some screws inside first. Hmmm, I think you probably know this, but I think you got a problem. Hopefully someone here has a good idea.
  3. jstcrashnthru
    jstcrashnthru Livin' the dream
    Oct 8, 2006
    1,236
    Omawhere?
    Where's the spare key? :doh
  4. Pax
    Pax shazam.
    Jul 22, 2006
    813
    Columbia MO
    Locksmith.
  5. when the road bends
    Oct 19, 2007
    464
    Seattle
    So far I've tried a lot of action and various keys around the house. No can open.
  6. Xeraux
    Xeraux Archvillain
    Sep 26, 2006
    31,785
    Where I need to be.
    It's probably a wafer tumbler of some sort. Seriously, you can probably pick it with two paperclips (one partially unbent with a little bend at the end for feeling the wafers and one not bent to put turning pressure on the tumbler) in about 10 seconds.
    If the key is double sided, you have to pick both sides of the lock while keeping pressure on the tumbler.
  7. SCQTT
    SCQTT Zwei Kolben
    May 16, 2005
    5,702
    Mike's Sky Rancho
    Grant, you're scaring me, stay away from my stuff :D
    BTW pick up my new X Challenge Sat the 22nd :clap Yes, this one will get dirty.
  8. Xeraux
    Xeraux Archvillain
    Sep 26, 2006
    31,785
    Where I need to be.
    :shog
    You getting from Performace?
    #8
  9. SCQTT
    SCQTT Zwei Kolben
    May 16, 2005
    5,702
    Mike's Sky Rancho
    No, I'm a Grass Roots kind of guy.
    Performance has one really cheap, but for some reason you can not get the current BMW incentive on it.
    #9
  10. Squanto!
    Squanto! Long timer Supporter
    Oct 4, 2005
    13,712
    Nashoba Valley
    Is there a number on the lock?
    #10
  11. moymurfs
    moymurfs Truth has become unacceptable.
    Jun 25, 2005
    2,642
    Northeast NC
    I would say either set it down and tell a 6year old not to touch it ....OR......maybe a locksmith.
    #11
  12. testrider
    testrider Been here awhile
    May 16, 2006
    125
    Los Angeles, California
    How did you lock your Givi case key inside the Givi case?
    My Givi cases cannot be locked without a key...
    #12
  13. Garand
    Garand Keeper of Useful Sarcasms
    Oct 14, 2004
    746
    NE OK
    Bump key?
    <object height="355" width="425">
    <embed src="http://www.youtube.com/v/pwTVBWCijEQ&hl=en" type="application/x-shockwave-flash" wmode="transparent" height="355" width="425"></object>
    #13
  14. Xeraux
    Xeraux Archvillain
    Sep 26, 2006
    31,785
    Where I need to be.
    Awesome. :thumb
    I don't even know why they consider Performance Plus a "BMW Dealership".
    #14
  15. AKStrom
    AKStrom Long timer Supporter
    Jun 5, 2006
    1,280
    South Seattle
    That was my question. There's no way that I can think of to do that with the E52 or E41 bags unless you've locked it with one of the keys in the tumbler and then lost/loaned out those keys.
    #15
  16. HaChayalBoded
    HaChayalBoded Brooklyn Bored
    Oct 11, 2006
    8,320
    BRC \ NYC
    Sorry David but HAHAHAHAHAHA!!!!!
    anyway, if you bring the case with you next weekend I could probably pick the lock for you. Should only take a second or two. Which series case is it?
    #16
  17. tedder
    tedder irregular
    Jun 8, 2004
    8,795
    Portland
    Which model are you talking about? And how does it lock without a key in the tumbler?
    I think the other comments are correct, the number is stamped on the outside of the lock. You can certainly get a replacement key, find someone with the same key, or get a locksmith to help out.
    AKStrom, if it's an E41 he can get in with the combo lock, and if he's forgotten the combo to that can just break that piece open and replace it. DAMHIK.
    #17
  18. when the road bends
    Oct 19, 2007
    464
    Seattle
    Thanks xerax,
    picked it with the two paperclips and a thin piece of steel coupled with a little blood.
    Ok, It took more than 10sec. But once you figure it out....
    It turns out to be unlockable without a key, so I must have locked it with another key last fall when I stored it, and then forgot that first key. Glad the other key was inside.
    #18
  19. AKStrom
    Jun 5, 2006
    1,280
    South Seattle
    That's true I suppose.
    It's Sunday afternoon though. He'll have plenty of time before tomorrow morning to start working on the combination.:D
    #19
  20. Xeraux
    Xeraux Archvillain
    Sep 26, 2006
    31,785
    Where I need to be.
    :thumb
    Yeah. It's scary once you see how easy it is to open locks like this.
    Jesse luggage only uses about 4 different keysets. The owner of BMW Motorcycles of Little Rock and I had the same keyset for our Jesses. When he lent me his bags I didn't even have to take his key. I just used my own!
    #20
