HEIZKÖRPER Modifications - Goodies for KTM 1XX0 BigTwins
Discussion in 'Vendors' started by Martyred, Mar 13, 2018.
  1. Martyred
    Martyred Been here awhile Supporter
    Jul 13, 2013
    517
    Germany
    As the title says, this is all about useful (or just fancy) goodies for the KTM 1XX0 BigTwins. I will update this thread with all products I have in stock.
    Content, for easy navigation click on the product to see the details:
    Insured shipping is done via DHL worldwide and payment could be done via paypal or bank transfer (in Europe).
  2. Antikid
    Antikid Been here awhile Supporter
    Sep 28, 2009
    791
    Cincinnati
    I think I see my bike!! Cool beans. :happay
    The sidestand relocation bracket is awesome. I haven't touched it since I put it on.
    Martyred likes this.
  3. Martyred
    Jul 13, 2013
    517
    Germany
    Next update:
    KTM 1XX0 ADV Driver lowering footpeg brackets
    The kit consits of:
    • 2x adapter brackets 5mm carbon steel S355JO (powdercoated black)
    • 2x M8x16mm
    • 2x M8x20mm
    • 2x M8x10mm
    The kit is 30,00€ + shipping.
  4. Martyred
    Jul 13, 2013
    517
    Germany
    Next one is the
    KTM 1XX0 ADV High Fender bracket
    The kit consits of:
    • 1x adapter brackets 5mm Aluminium (powdercoated black)
    • 2x M6x40mm countersunk screws
    • 2x M8x30mm countersunk screws
    • 4x 15x12mm spacers
    • 2x 10x12mm spacers
    The kit is 35,00€ + shipping.
    Please note that you have to relocate your horn. For example to given positions:
    nick8800gts likes this.
  5. Martyred
    Jul 13, 2013
    517
    Germany
    Next one:
    KTM 1XX0 ADV Sidestand Relocation kit Version 2.5 S-Type / R-Type
    Please see the heavy duty kits
    Kits for the S- and T-Adventure models are ready to ship.
    Kits for the R-models are available as well...
    The S-type brackets differ a bit to the R-type ones in case of the bended angle to support the 690 Duke sidestand and they re-use the OEM magnet holder.
    S-type and R-type kits are now equipped with two typs of male and female spare 3pin plugs (cable extension or DIY bypass):
    • the old 3 pin (2013-2016)
    [​IMG] [​IMG]
    • the new 3 pin (2017- ... )
    [​IMG] [​IMG]
    So for those how are interested just a few informations in summery:
    Stage I Relocation kit 2.5 for 125,00€ with:
    (on SALE: 99€ instead of 125€)
    • Relocation bracket 2.5 (black powder coated)
    • male and female spare 3pin plugs (cable extension or DIY bypass)
    • with the mounting material (screws, washers etc.)
    The KTM OEM sidestand, spring etc. you have to purchase yourself...
    Stage II Relocation kit 2.5 for 250,00€ with:
    • Stage I Relocation kit 2.5
    • (for R-Type) KTM OEM sidestand 990 ADVENTURE L=302MM 06 KTM-Part-No: 6010302310030
    • (for S-Type) KTM OEM sidestand 690 DUKE KTM-Part-No: 7600302300033
    • special screw sidestand - SCHRAUBE F. SEITENST. M10X31,2 KTM-Part-No: 62503027200
    • special spring screw - SONDERSCHRAUBE STÄNDERFEDER KTM-Part-No: 61003028001
    • Spring 990 ADV 116 mm - FEDER L= 116 MM 05 KTM-Part-No: 61003024000
    Complete with KTM OEM sidestand, spring etc.
    Stage III Relocation kit 2.5 for 260,00€ with:
    • Stage II Relocation kit 2.5
    • right lowering footpeg plate
    Everything included!
    That is, what you get, if you order the complete kit Stage III (shown is Version 1.0 R-Type):
    *Please note: The sidestand relocation bracket doesn't work with the 1050/1090/1190/1290 ADV OEM sidestands!!!
    Compatible skidplates:
    • KTM OEM Skidplate
    • Altrider
    • Rumbux
    • Touratech
    • B&B
    • SW-Motech
    • Givi
    • Emperor
    If you are interested please write me a personal message with the type and stage you are looking for and your location for the shipping quatation.
    For installation please look here as well:
    First you have to dissassamble your sidestand including the console and the left footpeg, and - if you have - your skidplate. Afterwards remove the lower left screw from the tail frame.
    To adjust the sensor move the sensor bracket...
    Because some ask for the diffrence between R-type brackets and S-type brackets: For the S- and T- models: You need to reuse the OEM magnet holder which will than mounted directly to the relocation bracket...
    If you have choosen a stage III kit, you can add the right lowering footpeg bracket as well:
  6. Martyred
    Jul 13, 2013
    517
    Germany
    Next one:
    KTM 1XX0 ADV ToolTube bracket
    To mount a ToolTube properly to the ADV I have some brackets left over
    The kit consits of:
    • 1x ToolTube adapter brackets 5mm Aluminium (powdercoated black)
    • 2x M8x12mm screws
    • 1x M8x16mm screw
    • 3x washers
    Please note, that you have to reuse the original screw from the OEM case holder.
    That's the tube:
  7. Martyred
    Jul 13, 2013
    517
    Germany
    Next one:
    KTM 1XX0 ADV ABS Rings 44T set
    To compensate the speedo incorrectness the modified pair of ABS rings has 44 holes instead of 48 holes from the OEM ABS rings.
    The set consits of:
    • 1x front ABS ring 44T made of 2mm carbon steel S355JO (powdercoated black)
    • 1x rear ABS ring 44T made of 2mm carbon steel S355JO (powdercoated black)
    The set is 60,00€ + shipping.
    tonyubsdell and nick8800gts like this.
  8. Martyred
    Jul 13, 2013
    517
    Germany
    Next one:
    KTM 1XX0 ADV pillion lowering footpeg brackets
    For lowering the pillion/ passenger footpegs there are two different bracket typs available, depending on the Muffler/ exhaust you are running. If you are using a HOLAN pannier rack either the "large" or the "small" bracket isn't suitable due to the mounting point of the rack on the OEM pillion footpeg position!
    The "large" bracket:
    The "large" kit consits of:
    • 2x large brackets
    • 4x washers
    • 4x M8x40mm screws
    • 4x 15mm spacer
    The kit is 60,00€ + shipping.
    *Please note, that the "large" kit is suitable for Leovince-, EndyBrutale-, Barrett-, Fuel- und Yoshimura-exhaust​
    The "small" bracket:
    The "small" kit consits of:
    • 2x small brackets
    • 4x washers
    • 4x M8x25mm screws
    The kit is 50,00€ + shipping.
    *Please note, that the "small" kit is suitable for the OEM-, Remus-, Arrow-, Akrapovic- and Wings exhaust​
    #8
  9. Bike Guy
    Bike Guy Been here awhile
    May 20, 2005
    956
    sierra foothills, hwy 49
    I’m impressed with your hard work and dedication. Saved to my favs
    #9
    lukeinlondon and Martyred like this.
  10. nick8800gts
    nick8800gts Adventurer
    Sep 1, 2016
    22
    Ordered the lowering rider pegs... Loving it till today... Great stuff n good quality..
    Sent from my ONEPLUS A3003 using Tapatalk
    #10
  11. charlie264
    charlie264 Long timer
    Oct 27, 2007
    11,794
    Blighty
    Nice work.
    #11
  12. Norberto
    Norberto n00b
    Apr 17, 2018
    1
    Italy
    Hello! I have a 1190 Adv R 2016 with stock exhaust. Which one should I order? Thanks
    #12
  13. Hopey
    Hopey Hopey
    Jun 14, 2011
    256
    Australia
    Wings with Arrow headers ceramic coating
    Hopey
    #13
  14. Arnokite
    Arnokite n00b
    Jun 5, 2018
    1
    france
    Hi,
    i have 1090R and i want to order this kit, how can i do to order ?
    i'am from France.
    Best regards
    #14
  15. Martyred
    Jul 13, 2013
    517
    Germany
    You got a PM (personal message)
    Gesendet von meinem SM-G930F mit Tapatalk
    #15
  16. Georgios
    Georgios Been here awhile
    May 3, 2009
    424
    Hi Martyred,
    can you construct something to lower the exhaust can temporalily? My idea is to have a full pannier on the right side, not this cut out stuff. It should be something that can be simple rebuild after a trip. Any ideas?
    Thanks.
    #16
  17. herb b
    herb b n00b
    Feb 7, 2017
    9
    How do you send a PM? Thanks
    #17
  18. Martyred
    Jul 13, 2013
    517
    Germany
    Next update:
    KTM 1190 ADV STHEADBRACE 1.0
    The kit consits of:
    • STHEADBRACE steering head mounting points enhancement, made of S355 steel CNC routed and black powdercoated
    • mounting material
    The kit is 350,00€ + shipping.
    Install order:
    So the first thing is you have to dissassambe everything from your front after you took off the fairing and the fuel tank.
    Unmount the steering lock
    Take the STHEADBRACE and disassemble one half by loosen the bottem block and one side screw:
    Prepare the included M8x50 screws with a spring ring and a brass spacer:
    Place one half of the STHEADBRACE like shown and fix it with the M8x50 screw. Make sure your wirings are placed without pressure:
    Take now the other halfs upper part and place and fix iton the other side:
    Use the side M6x25 screw to fix the long part in place:
    Now fix the bottem block by using the previous M6x25 screws:
    Use the shorter M6 U-shape metal strap at the lower part and fix them:
    Now insert the stearing lock and screw in the M8x50 screws and fix the lock with the M8 selfsecuring nuts:
    Now install the upper longer M6 U-shape metal strap:
    Tighten everything:
    #18
    Wodger63, peter_tux and Antikid like this.
  19. lukeinlondon
    lukeinlondon 1290SA/XADV
    Feb 8, 2010
    955
    London
    Received my lowering pegs. Looks great, pleasure dealing with you. Am subscribed so I will be keeping an eye on your products
    #19
  20. Martyred
    Jul 13, 2013
    517
    Germany
    #20
    F650Dakar_Norway likes this.
