Helmet / bike camera (merged) mega threadfest...
Discussion in 'Equipment' started by AJ2, May 14, 2002.
  1. SgtDuster
    SgtDuster Long timer
    Feb 23, 2010
    4,496
    Province of Quebec!
    Contour HD
  2. Kingsized
    Kingsized Kingsized Adventurer
    Mar 22, 2012
    983
    Central MS
    I bought the Sony Action Cam about a week ago and have really enjoyed it. The Zeiss lens is really fantastic but the image stabilization is the biggest plus for me. Smooths out all the jitters. I bought an extra battery and use a 32g micro SD that can hold 4:30 hours of HD video.
    The waterproof case is very well made but I have one argument about it. There is a large water tight button which allows you to start/stop the camera. It needs two more smaller ones for the NEXT and PREV buttons. Then all functions could be adjusted with the case on. You can swap from HD to Slow or Super Slow or Interval pictures all from the outside. Fro folks who are water or snow skiing, your going to be opening it up, changing the settings and then closing it back into the case with moisture inside. (NOT GOOD)
    For my uses, it's perfect and better that the GoPro. The mounts are good. I mounted mine on the top of my helmet. They side helmet strap is ok but the angle is pitched down making your field of view far too low. I'll use it was a head band for non-helmet us.
    The Sony Action Cam is really nice for $199. and I'm happy I bought it!
  3. munchmeister
    munchmeister Grow'd Up Mini Trail
    Dec 17, 2003
    1,616
    Fort Collins, Colorado
    Would love to see some footage from you Sony, especially showing the stabilization. Sony has always had stabilization down pretty well, as well as exposure, so I'd love to see whatcha got.
  4. Kingsized
    Mar 22, 2012
    983
    Central MS
    I'm riding in the morning and will upload some when I get back. Another thing since you mentioned exposure is that it's said to be superior in low light situations. I saw a video a guy made using a GoPro and Action cam side by side and it is far better.
    http://www.youtube.com/watch?v=gSgK2KS0y6Q
    And a longer comparison between the two regarding image stabilization. I skipped through it cause it was boring. :lol3
    http://www.youtube.com/watch?v=OvfXWzmldYI
  5. MotoMinded
    MotoMinded Rally On Super Supporter
    Feb 19, 2006
    5,444
    COS
  6. Kingsized
    Mar 22, 2012
    983
    Central MS
    Well, I now have video but while it shows a steady video, the best comparison is the one I linked to that shows them side by side. It's really the best way to see what the stabilization is doing.
  7. munchmeister
    Dec 17, 2003
    1,616
    Doin a little research on the Sony, found that B&H Photo lists the WiFi version of the Action Cam as the AS-15. From what I can tell the wifi will connect with your phone, etc. running Sony's PlayMemories mobile app. It allows you to grab the video feed, to frame the shots, and allows you to upload the video after the ride using said app. That gets us past the problem of framing the shot. It uses a Sony NP-BX1 Rechargeable Lithium-Ion Battery, so you could buy a second one if you're planning a ride longer than 80 minutes of continuous shooting. The 120 FPS looks cool, Sony does a good job with low light and with the image stabilization, so it may be a good alternative to the GoPro and Contour stuff.
    http://youtu.be/Wu8MKceMve4
    Found a vid of the wifi on the AS-15
    http://youtu.be/ErO_WSgKm2o
  8. Storm Shadow
    Storm Shadow Thread Ninja
    Jan 9, 2011
    1,626
    Arashikage Clan
    http://au.oregonscientific.com/cat-Price-sub-$300--prod-ATC9K-HD-Action-Camera.html#
    what are these like, chargable battery, 1080p hd, and a remote control at 1/3 of the price of a GoPro?
  9. munchmeister
    Dec 17, 2003
    1,616
    The early, non-HD, versions were pretty much dismissed as being terrible. But, hey, everybody's getting on the HD wagon so there may be great improvements. Check out YouTube for some of the comparo's done with this camera, against the GoPro, etc. FWIW, to me it comes down to deciding what features you want. For me, some kind of screen was important. I hate it when I get back home from a ride and the framing was way off. With these super wide angle lenses, you get everything in, but everything also looks so damned small. Compare to your rear view mirror, which warns "objects may appear smaller than they really are..." Same is true for these little video cams. So, if your framing is off, you may end up with 3/4 of the screen showing sky, for example. DAMHIK ! :lol3
    If you are brand new and just wanting to get a feel for these, go cheap but don't expect too much. There is a reason GoPro has stayed at the top of the heap. It's now got about everything you could want... you just have to pay for it. Want a screen? They have a "backpack" for that. Want Wifi? They have a "backpack" for that too. But you'll end up spending closer to $500 than $300. I think that is why the Sony is getting some attention. And the others, too, such as the Replay, the Drift, etc. Sony is known for high quality video in their high end stuff so they oughta know how to build an "action" cam. One version, the Sony HDR-AS15, comes with Wifi, which allows your smartphone to act as your screen, for less moolaa than the GP. It's on the web for $268, & has their SteadyShot image stabilization, which might work well for motocycles. Don't have one, so don't know, but some of the web videos of the HDR-AS15 look pretty good.
    Choices, choices. It's a wonderful world, ain't it?
  10. Storm Shadow
    Jan 9, 2011
    1,626
    Arashikage Clan
    Well ive got the atc3k which is good. Never had an issue with ir but the no screen thing. The atc9k has a laser to aim with and a screen.
    Your right with the go pro add ons. I like the fact this comes with a remote thats water proof too.
    Although im reading the fine print they remove the battery due to post restrictions. We will see. Half the rrp of 300 what i paid anyway. Plenty of chineese batteries for it 12 bux for 2 n charger car n wall though.
    send on a small touch screen by a guy with fat fingers
  11. Alloveroz
    Alloveroz RaceRecall
    Jul 15, 2012
    13
    Melbourne Victoria Australia
    Not a bad camera, bur really flimsy mounts. Broke em the second time I used it.
  12. Alloveroz
    Jul 15, 2012
    13
    Just been testing my new Sony Action Cam. Good little camera, but with one feature thats a dealbreaker for me. To turn the camera on from cold, you need to take it out of the housing! It's quite a snug fir and so you have to tilt it forward and prise it out of the case.
    It can be set to stay on, but that runs down the battery.
    How do they expect a person to take a camera out of a mud covered case and turn it on without getting mud everywhere, or worse still, dropping it in the dirt.
    This is typical of a design that was made by engineers with no practical experience.:huh
  13. Storm Shadow
    Jan 9, 2011
    1,626
    Arashikage Clan
    really, ive had the atc3000 and atc2000 mounts and have never had an issue, not the best or easiest attachment admitting
  14. robdogg
    robdogg turnip truck driver Supporter
    Jan 29, 2004
    2,242
    wren-tonne, WA
    huh... that sounds like it could be a PITA.. but then even with my GoPro, I am pretty sure when I know I want to film, and when I don't.. so a few extra seconds to remove it to turn it on doesn't sound to far fetched. Also, if the three hour battery life is anywhere near claimed (about three times more then I get with my GP), you can at least leave it on for quite a while without worrying about the batteries dying. Maybe it's something they could fix with a firmware update though.. like having the shutter button on the end, cause the camera to boot up if it's off; and add an auto shutoff feature (unless it already has?) if the camera is not used for a certain amount of time.
    I have a question about the mic/sound though. I hate how my GoPro picks up wind noise, but there's a company that makes a wind sock for the camera and others have made their own.. but with the stereo mic's mounted on the front of the Sony, I am thinking it's going to be a problem to cover the mic to reduce/eliminate wind noise. That's MY deal breaker.. cuz I like hearing the motor sounds, and not shrieking wind noise or some lame death metal band added to the clip, when watching my videos..
  15. Storm Shadow
    Jan 9, 2011
    1,626
    Arashikage Clan
    what programs are we using to edit the videos, ive been using the free windows movie maker, but want to do picture in picture
  16. NordieBoy
    NordieBoy Armature speller
    Dec 2, 2006
    7,244
    Kiwiland
    Mmmmmm......
    GoPro Hero 3 Black Series...
    30% smaller. 25% lighter. 2X faster processor. 4X higher resolution. Wi-Fi enabled.
    :evil
  17. CrustyD3mon
    CrustyD3mon Been here awhile
    Jan 4, 2010
    284
    seems amazing....probably my next camera....
    :D
  18. onefastrph
    onefastrph Shut up and ride.
    Apr 30, 2006
    291
    Ocomukowonowaukesha, WI
    Looping video. Time for an upgrade!
    Sent from my ADR6325 using Tapatalk 2
  19. Storm Shadow
    Jan 9, 2011
    1,626
    Arashikage Clan
    it loops, like a DVR crash cam?
  20. Alloveroz
    Jul 15, 2012
    13
    AVS Video editor is a great little program that will do PIP etc. You can download a trial version and it's around $40 to buy
