Help ID old compressor pump
Discussion in 'The Garage' started by divotdm, Nov 6, 2019.
  1. divotdm
    divotdm Been here awhile
    Jun 18, 2009
    534
    Kewaskum, WI
    Hi, this is for sale locally. Havent personally seen it yet. According to the seller there are no numbers on the pump. I am trying to find specs and see if parts are available. It seems to be a 2 stage. 2 hp motor which appears to be origional.
  2. Andiflip
    Andiflip Adventurer
    Mar 16, 2006
    53
    Dumaguete City , Philippines
    I would think it is a Webster or a Chinese knock off of one..
  3. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,538
    Va
    1 stage and probably slow yet adequate for topping off a tire.
    Two stage has a high-pressure and low-pressure pistons per cylinder.
    How much air do you need?
  4. concours
    concours WFO for 48 years
    Dec 2, 2008
    7,405
    NH USA
    3 stage. Follow the path of air from the filter (housing).
  5. divotdm
    Jun 18, 2009
    534
    Kewaskum, WI
    it looks like 2 of the cylinders have filter housings (one packed with white stuff ) which would be 1st stage, then the one without would be 2nd. i am guessing though. I found some old Speedaire pumps that look the same but are single stage
  6. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,746
    Anchorage, formerly Spenard (hub of the universe)
    looks Kellogg - American
  7. divotdm
    Jun 18, 2009
    534
    Kewaskum, WI
    Heres an old speedaire. Its close. Single stage though. Pump built by Champion.
  8. MacMcMacmac
    MacMcMacmac Reluctant Nihilist.
    Dec 7, 2012
    537
    Ottawa, Ontario
    As stated, this is a two stage Champion pump. If it is not worn out, it is a very good compressor. Grainger used Champions for their Dayton and apparently, some Speedaire units as well. Champion is now a Gardner Denver owned company.
    Those air filters do not fill me with confidence. See if you can pull the valves and do a quick inspection of the bores. Any excess scoring or oil on the piston crowns is bad news, although a light misting with some debris in it is not uncommon. Parts should be easy to source if you like a project. If you can get it to run, try closing off each filter with the palm of your hand and see if it draws a vacuum. This is a quick and dirty test for bad first stage valves.
    #8
  9. divotdm
    Jun 18, 2009
    534
    Kewaskum, WI
    Any idea what model the pump is? Im in for a project, but only if i can find parts and not too expensive.
    Thanks,
    Dave
    #9
  10. MacMcMacmac
    Dec 7, 2012
    537
    Ottawa, Ontario
    Closest match I can find is a Dayton Speedair 3Z176b, although that one has a reed valve head, not a poppet valve like this one. It's possible this has the same model number but it is an older style, or it may be a totally different model. Dollars to donuts it's the same below the heads. I don't know if you will get parts for something this old.
    #10
  11. YesRush
    YesRush Long timer
    Aug 17, 2014
    3,538
    Va
    that Dayton speedair is a champion
    #11
  12. baloneyskin daddy
    baloneyskin daddy bikaholic Super Supporter
    Oct 21, 2009
    3,890
    southcentral PA.
    Before you state throwing time and money at it ,flip it over and tap around on the bottom with a small hammer and make sure the tank isn't rusting through from the inside. You can hear the soft spots.
    #12
  13. MacMcMacmac
    Dec 7, 2012
    537
    Ottawa, Ontario
    Every pump in this thread is a Champion.
    #13
    YesRush likes this.
  14. divotdm
    Jun 18, 2009
    534
    Kewaskum, WI
    Think im gonna pass on this one. Cant find any parts or even the exact pump. Thanks for all the help. Plus seller has no way of running it to see if it even works.
    #14
