1. Hey everyone, We’re going to start a weekly email to surface interesting threads in the forums. No worries, you can easily unsubscribe if you don’t find it interesting. If you’re like me, it’s nice to have someone willing to poke around a big community like ours and find the most interesting stuff. Saves time and I hate missing something great. It worked really well when we had someone discovering the best photos for the home page rotation back in the day. And if you have something fascinating to post, maybe this email does everyone some good by getting it noticed. Let us know what you think when you get it. Your feedback will make it better as we go (thread). Thanks! Baldy & rudy1220
    Dismiss Notice
Help with beta rev3
Discussion in 'Trials' started by COXR650L, May 18, 2018.
  1. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    I got my first trials bike, a 2000 beta Rev 3 270. Bike ran good when I got it. Typical older bike so I pulled some stuff apart to sort it out. While at it I pulled the carb and cleaned it. I set the float to what I read online with the tangs pointing at the piolt jet tower (the tangs were level when I opened it up) new plug etc.
    I get it all back together and it starts ok ride down the driveway, bike is running a little irratic with a high idle. Turn it off adjust the idle screw, start it back up and it begins reving uncontrollably. The kill switch will not even turn it off. Finally it turns off. Now when I try and start it all I get is an occasional back fire through the exhaust.
    I pulled the carb again and blew it out and cleaned the pilot. Still no change Tried raising the float level and again nothing.
    Plug is wet with fuel and getting spark.
    Any ideas?
  2. NMTrailboss
    NMTrailboss Team Dead End
    Mar 1, 2008
    8,397
    Albuquerque, NM
    Lineaway should be along shortly! :deal
    thegraydog likes this.
  3. Nobade
    Nobade Been here awhile
    May 30, 2012
    527
    Albuquerque, NM
    Sounds way too lean like you lowered the float level too much. Or partially plugged pilot jet, or an air leak somewhere.
    REALGRAVEROBBER likes this.
  4. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,093
    Pinch the throttle cable somewhere when you were putting things back together? Even if your float level is way off, the bike would just run lean, not rev uncontrollably. Same with a plugged jet.
    jonnyc21 and DyrWolf like this.
  5. Gordy
    Gordy Team Listo
    Dec 30, 2001
    29,264
    NM
    What do you mean " start it back up and it begins reving uncontrollably. The kill switch will not even turn it off. Finally it turns off".
    What did you do to finally get it shut down?
    You aren't confusing this with how a bike will momentarily rev up real high and then gradually shut off when the petcock (or supply) is shut off are you?
    The only way that bike will rev uncontrollably is if something is holding the slide up. Either your adjustment screw or the cable.
    jonnyc21 likes this.
  6. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    I pulled the carb for the 3rd time, recleaned it and put the float tangs back to roughly level. I put the old spark plug in again verified it was getting spark. It will not even try to start
    I have no explanation for why it ran the way it did. I seems the throttle was working smoothly and I rode it for a min or so. When I restarted to adjust the idle it revved up to around 5k rpm and stayed there for about 30 seconds while I tried to adjust it. The mixture screw and idle screw would not change the condition. While it was running the engine would cut out several times, only for a split second. I held the kill switch down and it did nothing. I turned the fuel off and it finally died.
    Now it won't even try to start other than a few random back fires
  7. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    2,111
    England On the Scotish border
    Start from scratch basics check Spark nice fat and blue, is fuel getting there and if it is as it still got crankcase compression?. It could be a issue separate from what you disturbed .
  8. Nobade
    May 30, 2012
    527
    Albuquerque, NM
    I wish that were the case with my old RD400 that blew up because it got leaned out so far I couldn't stop it due to plugged pilots. But yes, a stuck cable is a more likely cause I skipped over. Now it's gotten more interesting...
    #8
  9. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    Thanks for the help guys.
    Yes spark is blue and looks normal as far as I can tell. The plug is wet with gas when I pull it so I'm assuming it's getting fuel.
    I'm going to test the compression next, but I need a 90 degree elbow to fit under the tank. Headed to the hardware store now
    #9
  10. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,093
    Have you let it sit with the plug out since it last refused to start? It might just be unrelated flooded.
    #10
  11. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    12,172
    Dubuque, Iowa
    Next time it rev's out of control, just put a gloved hand or rag over the exhaust. It will die quickly without drama. Or if you're looking for a jolt, pull the spark plug cap off.
    #11
  12. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,131
    Boise aria
    Have you considered its running extra lean because the tank petcock is blocked? if it stopped quickly when you turned the fuel off then maybe its not getting all the fuel it needs? Maybe consider using a different fuel source to double check?
    Also consider a stuck needle in the floats?
    #12
  13. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    Well this one is beyond me. Fuel flows from the tank just fine, spark at the plug, plug is wet with fuel when I pull it, carb has been cleaned and blown out several times, and now I've even used starting fluid and nothing. I think all that's left is compression? Maybe it broke a ring.......
    The first hardware store did not have anything to make a 90deg fitting for my compression tester. As soon as I find something that will work I'll see what the compression number looks like. Not sure what else it could be.
    #13
  14. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    5,280
    Portales, New Mexico
    Line is in Turkey Rock, Colorado at a MWVTA event this weekend. Give him a bit of time.
    Not being a smartass here but... Slide in correctly? :dunno
    #14
    lineaway likes this.
  15. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    Yeah, I even checked that. Only fits one way. Haha. I'm not a professional mechanic, but have spent my entire life working on vehicles of some kind. I've had my fare share of dumbassery, but this seems pretty simple. I just can't figure out what Im missing, or possibly fucked up.....
    #15
  16. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,505
    nm
    You probably sheared a flywheel key. So was the carb over flowing that you tried ti fix a new bike? You need to make sure that you HEAR the slide hit bottom. Did you remove any wiring or the radiator? You might have a loose ground.
    #16
  17. Vintage pro
    Vintage pro Been here awhile
    Sep 26, 2013
    133
    Stallion Springs , Ca
    Go out and start the bike, does it run better with the choke to enrich the mixture, sounds like a airleak. The enriching will tell the story.
    #17
  18. heffergm
    heffergm Long timer
    Sep 22, 2014
    2,093
    Except as he mentioned it doesn't run at all.
    #18
    10K likes this.
  19. lineaway
    lineaway Long timer
    Oct 1, 2011
    8,505
    nm
    You can pop the top off the throttle assembly to make sure the slide bottoms. Being what happened you could now have a cold seize, which means you nipped the piston. Take off the front exhaust and look at the piston. It should be obvious on the exhaust side if you did this. Besides it gives the fuel time to evaporate.
    #19
  20. COXR650L
    COXR650L Long timer
    Nov 29, 2009
    2,100
    Denver
    Ill pull the header and check tomorrow, but I'm guessing your right. Idle was probably high with the carb pulled apart, maybe a bad ground on the kill switch so it didn't stop the engine, or a very lean condition from the float change, and revving a cold engine=o no.
    Let's hope top ends are too expensive.
    #20
