Help with exporting from Furkot to Osmand
Discussion in 'GPS 101 - Which GPS For Me' started by ADVraider, May 28, 2019.
  1. ADVraider
    ADVraider Been here awhile
    Dec 20, 2014
    778
    West coast
    Im getting weird straight lines when I export a GPX file from Furkot to OSMand.
    It happens both on my iPhone and Android phone,
    When I export GPX into Osmand, it doesn;t follow roads, instead it draws straight lines across the Osmand map to the final destination
    Furkot planned route exported to GPX:
    Link: https://trips.furkot.com/ts/LwaSiX
    OSMand route after imported from dropbox, just a straight line across:
  2. ADVraider
    Dec 20, 2014
    778
    West coast
    Problem solved! Exported as "Tracks" and "routes" from Furkot and got accurate navigation in Osmand
  3. ADVraider
    Dec 20, 2014
    778
    West coast
    The routes still come out a bit weird. Osmand just takes a turn off the highway and gets right back to it. Is that normal?
  4. Caveman0709
    Caveman0709 n00b
    Jan 29, 2013
    8
    Western Maryland
    How many points are you plotting when exporting from Furkot? I think the max is 250. It will still give you weird lines in Osmand if you trip is very long, but the snap to roads option should help your navigation follow the gpx closely.
    ADVraider likes this.
  5. ADVraider
    Dec 20, 2014
    778
    West coast
    Got ya! I think I figured it out with the snap to roads option and exporting as a "track"
  6. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    31,476
    Nippon
    I have had OsmAnd take a 5300 mile track with no issues, and I assure you there were thousands of plots because that was when Furkot was gmaps engine and you had to fight the fastest/shortest routing protocol
    ...and snap to roads in the nav mode is crap it doesn't show you where.
    But yeah, if you use export as route you get straight lines all over the place, even when you export as a track OsmAnd used to treat it as a rotue and recalculate the whole mess so there would be oddities.
    ...I got around that by importing to locus first and exporting THAT, that would be exactly as I plotted.
    That being said I haven't used OSM regularly for a minute so they may have updated that.
  7. ADVraider
    Dec 20, 2014
    778
    West coast
    Thanks, yeah I've exported as "Track" and everything worked great! Are there instructions somewhere on how to import to Locus and then exporting a Locus GPX to OSM?
  8. flamingm0e
    flamingm0e Long timer
    Feb 21, 2017
    1,236
    Oklahoma
    You can just open the gpx file in Locus.
    Once you do whatever in Locus, just use the export button.
    #8
  9. ADVraider
    Dec 20, 2014
    778
    West coast
    Oh wow, thats super easy!
    Is there any advantage in going the Furkot --> Locus --> Osmand route vs. Furkot export as "Track" --> Osmand ?
    #9
  10. flamingm0e
    Feb 21, 2017
    1,236
    Oklahoma
    What are you using Locus for in this case?
    I'm not understanding why you would use locus here if your goal is to just use OsmAnd.
    Furkot export then open in OsmAnd. I don't know what benefits you perceive by using Locus in between. The only reason I could see is if you want to edit the route ON the phone,in which case I would just use locus for everything
    #10
  11. ADVraider
    Dec 20, 2014
    778
    West coast
    @Tripped1 metioned that he is exporting the file from Furkot to Locus first and then exporting it again from Locus to OsmAnd. This is done to avoid any erroneous routing from Furkot
    #11
  12. flamingm0e
    Feb 21, 2017
    1,236
    Oklahoma
    Oh. For the routing. I don't ever use routing. Gotcha.
    #12
  13. Sōul-ō
    Sōul-ō Been here awhile Supporter
    Sep 23, 2018
    189
    Denver
    Is this fixed? I'm working with an iPhone 11 pro. I just bought Osmand for a 3500-mile trip that I planned in Furkot. I exported as a gps track, but I've got the straight line syndrome... looking for a fix, off to dr google I go...
    #13
  14. Sōul-ō
    Sep 23, 2018
    189
    Denver
    I’m using an ios device, so no locus. Does anyone know of an ios method to accomplishing this same correction from furkot to osmand?
    #14
  15. flamingm0e
    Feb 21, 2017
    1,236
    Oklahoma
    The straight lines is from the low resolution track you exported. Do you have a subscription to Furkot? That's the only way you'll get high resolution tracks any more. Otherwise you get straight lines.
    #15
  16. Sōul-ō
    Sep 23, 2018
    189
    Denver
    I do have a sub to furkot. Is there a way to select high res on export?
    #16
  17. flamingm0e
    Feb 21, 2017
    1,236
    Oklahoma
    Yeah. When you go to do the export, select gpx, next, gpx, next, tracks, high resolution tracks, export
    #17
    Sōul-ō likes this.
  18. Sōul-ō
    Sep 23, 2018
    189
    Denver
    ...I'm amazed I missed that, but it completely fixed my issue. Thank you!
    #18
  19. Tripped1
    Aug 6, 2009
    31,476
    Nippon
    When I used Furkot I would get a good deal of ......deflection....I guess you would call it that would send OsmAnd into conniptions trying to re-route because it thought I got off track. THAT or it wouldn't set waypoints by order or distance just by location distance so anything with a loop or roads that passed near each other was a crap shoot, so I go around that by importing to Locus first, then setting locus's defaut export to the OsmAnds track folder......added bonus that it was faster to get recorded tracks to OsmAnd
    For a while I was using OsmAnd to navigate (its got a better map engine) and Locus Pro to record and manage files.
    Cant test at the moment though, have a horrible case of grounded, so no riding.
    #19
