Here We Go Again - Yet Another BMW R1150GS Adventure/Ural Sidecar Renovation
Discussion in 'Hacks' started by mikepa, Feb 5, 2020.
  1. mikepa
    mikepa SideCzarist Supporter
    Dec 10, 2001
    861
    Seattle, WA in the Great Pacific NorthWET (USA)
    An interlude . . . .
    Massive spring cleaning, mission accomplished. Now sanitary and ready for a final brake system install and wiring up the tub. Celebrated with a hefty MadHatten double!
  2. Flyin' Monkeys
    Flyin' Monkeys Wicked Witch Airlines
    Apr 10, 2019
    442
    Emerald City
    A shop THAT clean and organized, is the Sign of a Sick Mind :zilla
  3. mikepa
    Dec 10, 2001
    861
    Hey, I resemble that remark! You shudda' seen it for the last three weeks.
    brstar and Flyin' Monkeys like this.
  4. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,629
    Same trailer, different park, FL
    That's just not right..... :jjen
    Flyin' Monkeys, mikepa and davebig like this.
  5. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    2,018
    Southwest Washington
    Mike, please don’t post pics like that again, once is enough. I am now going to have nightmares maybe for the rest of my life after going into my garage / shop.
    DaFoole, CVAN, brstar and 5 others like this.
  6. Miggins1
    Miggins1 Been here awhile Supporter
    Jun 13, 2013
    177
    Cheshire, England
    I daren't post a picture of my garage - it might see you off Mike!
    mikepa and rg sw wa. like this.
  7. mikepa
    Dec 10, 2001
    861
    OK, after a brief hiatus from wiring, with an orderly shop (after weeks of crap everywhere, can't find the tool I'm looking for, and where did I put that part), it's back to our regular programming.
    Yes, I know, you've seen the photos previously, but these are the real deal, the final product, wiring on the the tub is now honestly, truly 100% complete, so here's what the final result looks like:
    From left to right: the stock fuse/relay box, now minus the ABS relay. Next, the Blue Sea Systems fuse block, fully populated, with one spare available. Next, the cover for the Blue Sea panel. Finally, the terminal block which branches the load relay trigger, R/H turn signals, relay trigger for the auxiliary driving lights, front running light, rear tail light and brake light for the bike and sidecar:
    Close-up of the fused power distribution block:
    Close of with the cover in place:
    Close-up of the tail terminal block, now with the harness for the sidecar wired up:
    And with that done, time to cut a big hole in the sidecar for the wiring connector. Made a quick template in hope of only having to cut the hole only once <g>:
    Ready to start the final phase of not only the total re-wire of all accessory circuits, but the entire refit itself. It's all downhill from here (I hope):
  8. mikepa
    Dec 10, 2001
    861
    Finally able to button-up the bike today. Was finally able to remove the black tape the criminal former owner taped over the flashing ABS lights (as I yanked the entire ABS system to include all the plumbing), go the new brake flushed and bled. Installed the fuel tank. She started up, and we were able to do a throttle body sync, the last remaining service task! It's starting to look like an adventure rig again!:
  9. Flyin' Monkeys
    Apr 10, 2019
    442
    Emerald City
    O M G...I found a flaw......alert the sidecar Po-Lease.....I found a flaw :fpalm
    Mike, in this picture, look at the Tie-Wrap in the one o'clock position of the picture, the Tie-Wrap that is on the upper frame rail, or technically on the right side upper frame, and see that this one specific Tie-Wrap needs to be rotated 180 degrees, so that the "tang" of the Tie-Wrap is not UP, but is located DOWN, like all the other Tie-Wraps are.
    Makes a big difference when working on vehicles, as one could snag the back of their hand on the "tang", and scrap the skin.
    And, while this 2nd thing is not a "flaw", may I suggest that you fab a "cover" to go over that "tail terminal block", much the same as there is a cover on the Blue Sea terminal block ?
    phreakingeek, DRONE, BJMoose and 2 others like this.
  10. mikepa
    Dec 10, 2001
    861
    OM-Effing-G! Missed that one, thanks for heading off a potential ER visit! And on the 2nd, though 12V systems are far less sensitive to shorts due to moisture, and water is non-conductive, others have suggested the same (and thanks for the recommendation!) so I am going to modify the clear cover from a Pelican Microcase, photos to come!
    Before (hopefully you noticed the stainless steel tang):
    After (practice safe cable-tying) :
    phreakingeek, DRONE, zookster and 4 others like this.
  11. masegraves
    masegraves Adventurer Supporter
    Aug 29, 2018
    57
    Chicago, IL
    mikepa likes this.
  12. mikepa
    Dec 10, 2001
    861
    OK Gang, are we happy now? Re-purposed the cover of a Pelican Mico case to make a rain cover for the tail terminal strip. I'll sleep better at night!:
    DaFoole, phreakingeek, DRONE and 5 others like this.
  13. mikepa
    Dec 10, 2001
    861
    Sidecar harness and disconnect installed. Not pretty, but brutally functional. Connector has a strong clamp on the jacket, and I sealed it against water intrusion by packing it in butyl bedding compound, it's probably waterproof as a result:
    DaFoole, phreakingeek, DRONE and 6 others like this.
  14. norton(kel)
    norton(kel) Long timer
    Apr 13, 2010
    3,448
    Berthoud CO.
    Mike, are you cutting your cable ties? If you twist them off rather then cut them, there is no sharp edge:-)
    rg sw wa. likes this.
  15. mikepa
    Dec 10, 2001
    861
    Answer (and yes, it's adjustable for proper tensioning before trimming the tail):
    I use Thomas & Betts UV-stabilized cable-ties with a stainless locking tang:
    Unlike Home Depot cable-ties, they don't have teeth so can be precisely tensioned and significantly stronger:
    They're molded from nylon (polyamide). Twisting the tail off is not optimal. It takes about six turns, and as nylon is a tough material, it elongates and doesn't break like cheaper cable-ties:
    Why? It's how I was trained. I also use torque wenches :
    DaFoole, BJMoose, DRONE and 5 others like this.
  16. wilfred
    wilfred juvenile delinquent Super Supporter Supporter
    Mar 13, 2004
    1,350
    Planet earth
    A beautiful resurrection, the bike looks familiar. It's in better hands.
    mikepa likes this.
  17. rg sw wa.
    Feb 9, 2011
    2,018
    :clap
    mikepa likes this.
  18. mikepa
    Dec 10, 2001
    861
    Finally, starting wiring inside the tub! Wire spools in the trunk lead through external connector:
    Here's what it looks like from the other side (in the trunk):
    Shop may have received a good spring cleaning, but the immediate work area is always a mess of stuff:
  19. brstar
    brstar Long timer
    Aug 17, 2007
    2,681
    Shoalwater Western Australia
    Love the T handle on the plug.
    Such a simple solution to a common annoying problem. Like disconnecting a trailer in the dark on a cold night with mud and grit effectively locking the connection up tight.
    Which is how the feelings are with a little knuckle abuse as it finally lets go.
    DRONE, Bobmws, mikepa and 1 other person like this.
  20. norton(kel)
    Apr 13, 2010
    3,448
    Berthoud CO.
    Thanks Mike for the tie info! Nice torque wrench’s !!
    BJMoose and mikepa like this.
